hello
not sure if it’s since i changed to the 6.1 Kernel,
but i just checked the cpu clock speed with these commands:
watch -n1 "grep \"^[c]pu MHz\" /proc/cpuinfo"
watch -n1 cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_cur_freq
and i get the minimum speed on all clocks(2200 MHz)with random spikes on different cores to the Max speed(4200MHz).
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
performance
performance
performance
performance
performance
performance
performance
performance
performance
performance
performance
performance
cpupower frequency-info
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 800 MHz - 4.10 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 800 MHz and 4.10 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 2.20 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
I’d like all cores to run at full speed all the time like it was before.
inxi -Fazy --no-host
Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=a445c87d-e6a9-47fd-9601-614f3b3e7781 rw quiet apparmor=1
security=apparmor resume=UUID=29e42246-1548-46dd-91f5-17d1f76c7bfd
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX705GD_FX705GD v: 1.0
serial:
Mobo: ASUSTeK model: FX705GD v: 1.0 serial:
UEFI: American Megatrends v: FX705GD.306 date: 05/25/2020
ID-1: BAT0 charge: 54.1 Wh (100.0%) condition: 54.1/64.1 Wh (84.4%)
volts: 15.5 min: 15.6 model: Simplo SDI ICR18650 type: Li-ion
serial: status: full cycles: 41
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 2200 min/max: 800/4100 scaling: driver: intel_pstate
governor: performance cores: 1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200
7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200 bogomips: 52815
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:4 chip-ID: 13d3:56a2 class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x429d built: 2018 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac:
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 54.38 GiB (11.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3512GJ
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: rev: E8FK11.C temp: 45.9 C scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 54.38 GiB (11.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 54.0 C pch: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 265 Uptime: 29m wakeups: 1 Memory: 15.48 GiB
used: 2.68 GiB (17.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1475 libs: 403 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.24
Thanks.
EDIT:
i don’t have TLP.
should in add intel_pstate=active to Grub?
or is it just a case of wrong reporting buy those two commands mentioned above?
