In any case, the cpu is stuck at boost clock. It never goes to base clock. shows these values at rest. It was also observed in earlier manjaro versions.
Motherboard: MSI b650 Tomahawk
Manjaro: 24.0.1 (kernel 6.9.2-1)
Info is probably inaccurate, check:
watch -n1 'cat /proc/cpuinfo | grep "cpu MHz\|processor"'
and
grep -R "." /sys/devices/system/cpu/cpu0/cpufreq/
Share it also here. Thanks.
processor : 0
cpu MHz : 545.000
processor : 1
cpu MHz : 4948.504
processor : 2
cpu MHz : 545.000
processor : 3
cpu MHz : 4949.534
processor : 4
cpu MHz : 545.000
processor : 5
cpu MHz : 545.000
processor : 6
cpu MHz : 545.000
processor : 7
cpu MHz : 545.000
processor : 8
cpu MHz : 4947.945
processor : 9
cpu MHz : 545.000
processor : 10
cpu MHz : 545.000
processor : 11
cpu MHz : 545.000
grep -R "." /sys/devices/system/cpu/cpu0/cpufreq/ ✔
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences:performance
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_highest_perf:166
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:545000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors:performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:performance
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq:5170000
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_lowest_nonlinear_freq:2988000
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_max_freq:5170000
/sys/devices/system/cpu/cpu0/cpufreq/related_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:4939933
/sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed:<unsupported>
/sys/devices/system/cpu/cpu0/cpufreq/affected_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:5170000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency:0
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference:performance
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:amd-pstate-epp
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_hw_prefcore:enabled
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_prefcore_ranking:186
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq:545000
Here is the output. Not all of them have a core boost (4 of 12).
The cpu scaling governor is set on performance. That might be the issue I don’t wonder that it won’t scale down.
sudo cpupower frequency-set --governor powersave
Usually powersave
should be the default. Did you change that?
Thanks. (I didn’t set it up.)
