Cp: cannot create regular file Permission denied
This is the log
$ pamac update -a --force-refresh
Preparing...
Refreshing core.db...
Refreshing extra.db...
Refreshing community.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing community.files...
Refreshing multilib.files...
Refreshing AUR...
cp: cannot create regular file '/var/tmp/pamac/dbs/sync/community.files': Permission denied
cp: cannot create regular file '/var/tmp/pamac/dbs/sync/core.files': Permission denied
cp: cannot create regular file '/var/tmp/pamac/dbs/sync/extra.files': Permission denied
Warning: firefox: local (104.0-1) is newer than extra (103.0.2-1)
Warning: firefox-i18n-en-us: local (104.0-1) is newer than extra (103.0.2-1)
Warning: grub: local (2.06.r297.g0c6c1aff2-1) is newer than core (2.06.r261.g2f4430cc0-1)
Warning: inxi: local (3.3.21.1-1) is newer than community (3.3.20.1-1)
Warning: libopenmpt: local (0.6.5-1) is newer than extra (0.6.4-1)
Warning: libpciaccess: local (0.16-4) is newer than extra (0.16-3)
Warning: linux518: local (5.18.19-3) is newer than core (5.18.19-2)
Warning: linux518-headers: local (5.18.19-3) is newer than core (5.18.19-2)
Warning: linux518-nvidia: local (515.65.01-6) is newer than extra (515.65.01-5)
Warning: linux518-virtualbox-host-modules: local (6.1.36-11) is newer than extra (6.1.36-10)
Warning: linux518-zfs: local (2.1.5-19) is newer than extra (2.1.5-18)
Warning: mpd: local (0.23.9-1) is newer than extra (0.23.8-1)
Warning: opera: local (90.0.4480.54-1) is newer than community (90.0.4480.48-1)
Warning: pahole: local (1.24-1) is newer than extra (1.23-1)
Warning: python-astroid: local (2.12.3-1) is newer than community (2.12.2-1)
Warning: sdl2: local (2.24.0-1) is newer than extra (2.0.22-2)
Warning: sdl2_image: local (2.6.2-1) is newer than extra (2.6.1-1)
Warning: snapd-glib: local (1.61-1) is newer than extra (1.60-1)
Warning: sof-firmware: local (2.2.1-1) is newer than extra (2.2-1)
Warning: x264: local (3:0.164.r3095.baee400-4) is newer than extra (3:0.164.r3095.baee400-2)
Nothing to do.
When I received the same cp errors, I saw the permissions were different than the .db files and assumed that was the problem. I’m not so sure anymore. It happened only the once, and I’m not sure why.
Those files are recreated in /var/lib/pacman/sync/ with paman -Fy and pamac appears to copy them as needed (and evidently with a few hiccups) :slight_smile:
Fixed upstream.
Nothing was fixed upstream. Please try again.
Works now no idea why.
