CounterStrike GO (and probably some other Games) Framelags
Hi,
Since Operation Riptide I had huge performance Issues regarding CS:GO. Many lags but worst of all: trying to use the mic was nearly impossible. Turns out it’s the compositor’s “fault”.
So if you are using for example KDE and having problems every time a shader renders (i.e. smokes, HE etc.), my best guess is to set your compositor to the lowest possible setting (or disable it if you’re fine with the sideeffects like screentearing).
If you don’t know where to find the settings: just click your Manjaro-Button (Startmenu) and type “compositor”. The rest will explain itself :wink:
I already noticed the compositor impacting my performance on other games like Deus Ex Mankind devided but CS:GO is nearly impossible to play with default settings now (OpenGL 2.0 and best Scaling).
This post is just to help people without going in to technical details.
Don’t know if that’s the correct Category, please move if it’s in the wrong place
That’s the problem to me, your post doesn’t explain anything and is widely vague on the problem and solution.
Maybe my description was too vague. I try to clarify it.
My Problem:
Poor performance in some games, especially in CS:GO since recent updates.
My framerate in CS drops everytime any effect begins to render (for example smoke grenades) and if I try to use the microphone the game freezes completely for around 3-4 seconds.
My solution after a bit of research and experimenting:
Lowering the compositor settings.
I got the best results when setting the Scalingmethod down (my Manjaro is localized, so I don’t know what “Pixelig” in German translates to).
My System:
inxi --admin --verbosity=7 --filter --no-host --width         ✔
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=a6c6f552-5849-456d-8da0-e6557f5ebcff rw quiet apparmor=1
  amd_iommu=on rd.driver.pre=vfio-pci kvm.ignore_msrs=1 security=apparmor
  resume=UUID=10a7d3e9-e7a6-4558-88f8-f5fc4256a056 udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 4021 date: 08/09/2021
  RAM: total: 31.27 GiB used: 3.2 GiB (10.2%)
  Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
  L2: 6 MiB bogomips: 182448
  Speed: 2201 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
  1: 2201 2: 2055 3: 2197 4: 2196 5: 3598 6: 2054 7: 2044 8: 2542 9: 2131
  10: 2152 11: 2198 12: 2202 13: 2054 14: 2199 15: 2200 16: 2197 17: 2200
  18: 4473 19: 2046 20: 2042 21: 2196 22: 2198 23: 2195 24: 2200
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  conditional, RSB filling
  Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
  v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0c:00.0
  chip-ID: 10de:1b81 class-ID: 0300
  Device-2: AMD Tahiti XT [Radeon HD 7970/8970 OEM / R9 280X] vendor: XFX Pine
  driver: vfio-pci v: 0.2 alternate: radeon,amdgpu bus-ID: 0d:00.0
  chip-ID: 1002:6798 class-ID: 0300
  Device-3: Microdia AUKEY PC-W3 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-1:2 chip-ID: 0c45:636d class-ID: 0102 serial: <filter>
  Screen-1: 0 s-res: 7680x1440 s-dpi: 107 s-size: 1824x342mm (71.8x13.5")
  s-diag: 1856mm (73.1")
  Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 109
  size: 597x336mm (23.5x13.2") diag: 685mm (27")
  Monitor-2: DP-0 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2")
  diag: 685mm (27")
  Monitor-3: DP-2 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
  diag: 685mm (27")
  OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
  Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
  driver: snd_hda_intel v: kernel bus-ID: 05:00.0 chip-ID: 1102:0012
  class-ID: 0403
  Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 0c:00.1 chip-ID: 10de:10f0
  class-ID: 0403
  Device-3: AMD Tahiti HDMI Audio [Radeon HD 7870 XT / 7950/7970]
  vendor: XFX Pine driver: vfio-pci v: 0.2 alternate: snd_hda_intel
  bus-ID: 0d:00.1 chip-ID: 1002:aaa0 class-ID: 0403
  Device-4: AMD Starship/Matisse HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 0f:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Device-5: Microdia AUKEY PC-W3 type: USB driver: snd-usb-audio,uvcvideo
  Device-6: RODE Microphones RODE AI-1 type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:4 chip-ID: 19f7:000a
  class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.38 running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 06:00.0
  chip-ID: 8086:2723 class-ID: 0280
  IF: wlp6s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
  port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
  port: c000 bus-ID: 08:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:8
  Local Storage: total: 16.37 TiB used: 3.19 TiB (19.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
  lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 40.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
  model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
  rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
  type: SSD serial: <filter> rev: 1B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000NM000A-2KE101
  size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: HDD rpm: 7200 serial: <filter> rev: SB2D scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT2000MX500SSD1
  type: SSD serial: <filter> rev: 032 scheme: GPT
  ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD20EZRZ-00Z5HB0
  type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: GPT
  ID-7: /dev/sde maj-min: 8:64 vendor: Crucial model: CT2000MX500SSD1
  type: SSD serial: <filter> rev: 033 scheme: GPT
  ID-8: /dev/sdf maj-min: 8:80 vendor: Crucial model: CT960BX500SSD1
  size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: R022 scheme: GPT
  ID-9: /dev/sdh maj-min: 8:112 type: USB vendor: Generic
  model: USB3.0 CRW -SD size: 29.12 GiB block-size: physical: 512 B
  logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS40 rev: 1.05
  dev-links: cdrom
  ID-1: / raw-size: 896.83 GiB size: 881.68 GiB (98.31%)
  used: 119.54 GiB (13.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: a6c6f552-5849-456d-8da0-e6557f5ebcff
  label: NO_LABEL uuid: CBF9-225D
  ID-3: /run/media/best/2TB_SSD_Crucial raw-size: 1.82 TiB
  size: 1.79 TiB (98.37%) used: 445.4 GiB (24.3%) fs: ext4 dev: /dev/sdc1
  maj-min: 8:33 label: 2TB_SSD_Crucial
  uuid: 20e5b60e-7dc1-4404-b1a9-3825086ce53b
  ID-4: /run/media/best/8TB_Exos raw-size: 7.28 TiB size: 7.22 TiB (99.20%)
  used: 2.64 TiB (36.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: 8TB_Exos
  uuid: 57c1c0a7-2aeb-4a0f-96a1-58faf43019dd
  ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
  uuid: 10a7d3e9-e7a6-4558-88f8-f5fc4256a056
  ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 300 MiB fs: vfat label: N/A
  uuid: 9B03-4F61
  ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 896.74 GiB fs: ext4 label: N/A
  uuid: 19e091c4-abc4-4be8-b07f-f351dec819a1
  ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 34.47 GiB fs: swap label: N/A
  uuid: 6679d245-16d1-41c9-8082-40aaf87ed154
  ID-4: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: ext4 label: 2TB_WD
  uuid: b43477ed-c5df-48a3-adf5-905c42a39f1a
  ID-5: /dev/sde2 maj-min: 8:66 size: 883.74 GiB fs: ext4
  label: 1TB_Part_Crucial uuid: 30d67c5b-6f01-4e6c-94e4-1aed51354f0c
  ID-6: /dev/sdf1 maj-min: 8:81 size: 100 MiB fs: vfat label: N/A
  uuid: 2EA2-511B
  ID-7: /dev/sdf2 maj-min: 8:82 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-8: /dev/sdf3 maj-min: 8:83 size: 893.63 GiB fs: ntfs label: N/A
  uuid: E60EC1470EC1120B
  ID-9: /dev/sdf4 maj-min: 8:84 size: 515 MiB fs: ntfs label: N/A
  uuid: D0CC475ACC473A4C
  ID-10: /dev/sdh1 maj-min: 8:113 size: 29.12 GiB fs: ext4 label: enc
  uuid: 0f67fec3-2665-4300-90e0-ce0a7ac30606
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 1-1:2 info: Microdia AUKEY PC-W3 type: Video,Audio
  power: 500mA chip-ID: 0c45:636d class-ID: 0102 serial: <filter>
  Hub-2: 1-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-3.1:5 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
  type: Keyboard,HID driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300 serial: <filter>
  Device-2: 1-3.3:7 info: Logitech G502 Proteus Spectrum Optical Mouse
  type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
  serial: <filter>
  Device-3: 1-4:4 info: RODE Microphones RODE AI-1 type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  speed: 12 Mb/s power: 500mA chip-ID: 19f7:000a class-ID: 0300
  serial: <filter>
  Hub-3: 1-5:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-6:8 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 05e3:0612 class-ID: 0900
  Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 3-4:3 info: ASUSTek AURA LED Controller type: HID
  driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
  chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Device-2: 3-5:4 info: Genesys Logic Multislot Card Reader/Writer
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
  speed: 480 Mb/s power: 500mA chip-ID: 05e3:0716 class-ID: 0806
  serial: <filter>
  Hub-7: 3-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 4-1:2 info: Realtek USB3.0 Card Reader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
  chip-ID: 0bda:0306 class-ID: 0806 serial: <filter>
  Hub-9: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  System Temperatures: cpu: 32.2 C mobo: N/A gpu: nvidia temp: 54 C
  Processes: 436 Uptime: 3h 36m wakeups: 0 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages:
  pacman: 1555 lib: 474 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
  running-in: konsole inxi: 3.3.06
According to other forums, I’m not the only one who got this Problem recently, so this is what works best for me
That’s weird, I don’t see the connection with your microphone and the compositor settings. Also if you start the System Settings from the terminal with systemsettings5, it should be in english, great to share screenshots or communicate a specific setting so everyone can find what it is.
For the shader thing, to me it sounds like it generates the shader, there is a setting in Steam called Shader Pre-caching maybe it can help you.
Seemed weird to me too, but I guess it’s caused by the “overlay” during microphone usage. Still seems a bit odd but I can’t find any other explanation to why changes in the compositor would affect this.
Opening the systemsettings via terminal doesn’t change the language for me but I can attach a screenshot with the settings that work best for me in german. The order of the Menus should be the same.
Still can’t figure out the translation of this Scale-method, but I know the other two are “Accurate” and “Smooth”. If you can tell me how the setting is called in english, I will add it to the TLDR :slight_smile:
Good point but I don’t think you can generate those shaders beforehand. I got Shader-Precaching on all the time :thinking:
BTW: Funny thing I found out during experimenting: I tried to watch a Youtube Video (WQHD) in firefox, while opera was showing a random website and scrolling on a website in chromium (chromium was the active window). Every browser was on a different display. On default compositor settings, the Video startet lagging a bit while scrolling in chromium. With my current settings, everything works smooth and without any tearing.
TLDR: Changing the Scale Method to “Crisp” in the compositor mostly fixed the Problem for me.
OK, I have changed something on my side, probably in my .bashrc file I have export LANG=C so it affects the terminal. The available value in English are Crisp/Smooth/Accurate I guess you have Crisp (in French for me Crisp is “Direct” and for you in German it is “Pixelated” :rofl:)
Good point but I still see it as part of the game rendering so it shouldn’t interfere if it is part of the game itself. I don’t know.
Anyway this is the setting I have too in my compositor for the scaling (but I have ‘balanced’ for the latency, I will try the other ones to see if I can spot differences, I noticed some weirdness with multiple Firefox windows in the past, in the scenario you described, that could still be a good tip :+1:)
I know that sometimes information gets lost in translation but this is funny :joy:
No front to the translation team, they are doing an amazing job :wink:
Interesting. Haven’t thought anybody else in this forum would see this behavior in Firefox (due to the conditions to trigger it).
Thanks again for helping me with the translation and to make this Post more informative :slightly_smiling_face:
