嗨,我下载CSGO后,打开它,只出现一个黑屏的程序,然后就停止运行了,我用bing中国搜索manjaro csgo,这并没有给我解决方案,希望你们能解决
系统规格
Host: connor-tobefilledbyoem Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 13.2.1 Desktop: KDE Plasma v: 5.27.7 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Intel model: X79-2011 serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 03/19/2020
Info: 8-core model: Intel Xeon E5-2689 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 512 KiB L2: 2 MiB L3: 20 MiB
Speed (MHz): avg: 1502 high: 3600 min/max: 1200/3600 cores: 1: 1841
2: 1200 3: 1200 4: 2594 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200
11: 1200 12: 1200 13: 3600 14: 1612 15: 1200 16: 1200 bogomips: 83025
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP108 [GeForce GT 1030] driver: nvidia v: 390.157
arch: Pascal bus-ID: 03:00.0
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 driver: X:
loaded: nvidia gpu: nvidia resolution: 1920x1080~60Hz
API: OpenGL v: 4.6.0 NVIDIA 390.157 renderer: GeForce GT 1030/PCIe/SSE2
direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.1
API: ALSA v: k6.1.49-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.78 status: off
Server-3: PulseAudio v: 16.1 status: active
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: 00:e0:4c:08:72:d9
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A
mac: 00:50:56:c0:00:01
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A
mac: 00:50:56:c0:00:08
Local Storage: total: 704.24 GiB used: 417.07 GiB (59.2%)
ID-1: /dev/sda vendor: Seagate model: ST3500413AS size: 465.76 GiB
ID-2: /dev/sdb vendor: Big Reservoir model: BR 256GB size: 238.47 GiB
ID-1: / size: 34.15 GiB used: 9.17 GiB (26.9%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 598.8 MiB used: 288 KiB (0.0%) fs: vfat
dev: /dev/sdb1
ID-3: /home size: 136.63 GiB used: 40.01 GiB (29.3%) fs: ext4
dev: /dev/sdb6
ID-4: /opt size: 34.15 GiB used: 384.9 MiB (1.1%) fs: ext4 dev: /dev/sdb2
ID-5: /var size: 11.71 GiB used: 5.79 GiB (49.4%) fs: ext4 dev: /dev/sdb5
ID-1: swap-1 type: partition size: 16 GiB used: 1.8 MiB (0.0%)
dev: /dev/sdb4
System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 46%
Processes: 327 Uptime: 1h 36m Memory: total: 16 GiB available: 15.54 GiB
used: 7.72 GiB (49.6%) Init: systemd Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 1197 Shell: Zsh v: 5.9 inxi: 3.3.29
