Could virtual interface affect optical drive accuracy?
There was a topic (in the german section, I believe) that covered installing and using the original program
exact audio copy
via the use of wine.
Another forum member even created a fully working script to install it.
I’ll look for it - perhaps I’ll find it.
edit:
this is the thread and the link to the post with the script:
Wine : EAC ( Exact audio copy ) fehlen Plugins - #11 by megavolt
perhaps it helps you
Indeed - thank you! I’ll check it out.
It didn’t seem like you were open to other options.
I use freac, it has a Linux version and works just fine.
