Running the command sudo Pacman -Syyu shows this error continuously
$ sudo pacman -Syyu
core 169.1 KiB 3.51 MiB/s 00:00 [########################################] 100%
extra 1855.1 KiB 1568 KiB/s 00:01 [########################################] 100%
community 6.9 MiB 2.89 MiB/s 00:02 [########################################] 100%
multilib 182.0 KiB 211 KiB/s 00:01 [########################################] 100%
error: could not read db 'community' (Damaged tar archive)
My output of this command inxi --admin --verbosity=7 --filter --width is:
$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=da027d79-76b4-4862-a2e6-d7879265fe40 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: H310M S2H 2.0 v: x.x
serial: <superuser required> UEFI: American Megatrends v: F11
date: 03/08/2019
RAM: total: 7.64 GiB used: 3.56 GiB (46.5%)
RAM Report:
Info: model: Intel Core i3-8100 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28808
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Gigabyte
driver: i915 v: kernel ports: active: DP-1 empty: HDMI-A-1,HDMI-A-2,HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e91 class-ID: 0300
Device-2: Cubeternet GL-UPC822 UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-1:2 chip-ID: 1e4e:0102 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: intel gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: DP-1 mapped: DP1 model: LG (GoldStar) HD serial: <filter>
built: 2019 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.20 running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-2087b46bb274 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
Local Storage: total: 111.79 GiB used: 93.05 GiB (83.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: GALAX model: GAMER L TA1D0120A
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61.3 scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DH16ABSH rev: YL32
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%)
used: 93.05 GiB (85.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: da027d79-76b4-4862-a2e6-d7879265fe40
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: C8C1-D9D0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Cubeternet GL-UPC822 UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 100mA
Device-2: 1-7:3 info: A4Tech USB Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 09da:c10a class-ID: 0301
Device-3: 1-8:4 info: SiGma Micro Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1c4f:0026 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 27.8 C mobo: 16.8 C
Processes: 243 Uptime: 17m wakeups: 7 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1891 pacman: 1886 lib: 413
flatpak: 5 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.15
How can I solve this please?
