Hi! I’ve updated system and cleared some python cache packages in .cache and after that I cant load qt applications. It gives
qt.core.plugin.factoryloader: checking directory path "/usr/bin/platforms" ...
qt.core.library: "/usr/lib/qt6/plugins/platforms/libqxcb.so" loaded library
Authorization required, but no authorization protocol specified
qt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
inxi
em:
Kernel: 5.15.162-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=9359aa8c-6ab5-47b5-8278-32c0e2105b1e rw quiet apparmor=1
Desktop: KDE Plasma v: 6 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X7400PC_N7400PC
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X7400PC v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: X7400PC.300
date: 02/25/2022
ID-1: BAT0 charge: 37.9 Wh (79.8%) condition: 47.5/63.0 Wh (75.3%)
power: 21.1 W volts: 12.0 min: 12.0 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 301
System RAM: total: 16 GiB available: 15.33 GiB used: 6.8 GiB (44.4%)
Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A1G44AB0-CWE
serial: N/A
Device-2: Controller1-ChannelA type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 1589 high: 3812 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1182 2: 2730 3: 923
4: 1027 5: 992 6: 1037 7: 1016 8: 3812 bogomips: 52856
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nvidia v: 550.100 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 bus-ID: 0000:01:00.0
chip-ID: 10de:25a2 class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 13d3:5458
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: Samsung 0x4154 built: 2020 res: 2880x1800 dpi: 242
gamma: 1.2 size: 302x189mm (11.89x7.44") diag: 356mm (14") ratio: 16:10
modes: 2880x1800
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia inactive: wayland,x11,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.1.3-manjaro1.1
note: incomplete (EGL sourced) renderer: Mesa Intel Xe Graphics (TGL GT2),
NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2, llvmpipe (LLVM 18.1.8 256
bits)
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k5.15.162-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF-ID-1: br-b45b8f31853b state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: outline-tun0 state: up speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IF-ID-4: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-5: veth563d2ef state: up speed: 10000 Mbps duplex: full mac: <filter>
Info: services: mld, NetworkManager, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 409.84 GiB (43.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 41.9 C
scheme: GPT
ID-1: / raw-size: 562.95 GiB size: 553.04 GiB (98.24%)
used: 409.79 GiB (74.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 9359aa8c-6ab5-47b5-8278-32c0e2105b1e
used: 46.2 MiB (15.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: E2CC-5486
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 389.81 GiB fs: ntfs label: N/A
uuid: 6AB0AFBCB0AF8D5F
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 821 MiB fs: ntfs label: N/A
uuid: 1EBAAB74BAAB46DD
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:3 info: IMC Networks USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:5458 class-ID: fe01 serial: <filter>
Device-2: 3-7:4 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-3: 3-8:5 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c6e class-ID: 0000
Device-4: 3-10:6 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (rpm): cpu: 4300
Processes: 323 Power: uptime: 1h 54m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.12 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 2501 pm: pacman pkgs: 2431 libs: 518 tools: pamac pm: appimage
pkgs: 0 pm: flatpak pkgs: 57 pm: snap pkgs: 13 Compilers: clang: 18.1.8
gcc: 14.1.1 alt: 13 Shell: fish v: 3.7.1 running-in: wezterm-gui
inxi: 3.3.35
Dolphin launch
qt.core.plugin.factoryloader: checking directory path "/usr/lib/qt/plugins/platforms" ...
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqlinuxfb.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqlinuxfb.so, metadata=
"IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
"MetaData": {
"Keys": [
"linuxfb"
"archlevel": 0,
"className": "QLinuxFbIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqlinuxfb.so:
Plugin uses incompatible Qt library (5.15.0) [release]
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqlinuxfb.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqwayland-xcomposite-glx.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-xcomposite-glx.so, metadata=
"MetaData": {
"Keys": [
"wayland-xcomposite-glx"
"archlevel": 0,
"className": "QWaylandXCompositeGlxPlatformIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqwayland-xcomposite-glx.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqwayland-xcomposite-glx.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqwayland-egl.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-egl.so, metadata=
"MetaData": {
"Keys": [
"wayland-egl"
"archlevel": 0,
"className": "QWaylandEglPlatformIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqwayland-egl.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqwayland-egl.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqwayland-generic.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-generic.so, metadata=
"MetaData": {
"Keys": [
"wayland"
"archlevel": 0,
"className": "QWaylandIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqwayland-generic.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqwayland-generic.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqminimalegl.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqminimalegl.so, metadata=
"MetaData": {
"Keys": [
"minimalegl"
"archlevel": 0,
"className": "QMinimalEglIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqminimalegl.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqminimalegl.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqvnc.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqvnc.so, metadata=
"MetaData": {
"Keys": [
"vnc"
"archlevel": 0,
"className": "QVncIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqvnc.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqvnc.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqwayland-xcomposite-egl.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-xcomposite-egl.so, metadata=
"MetaData": {
"Keys": [
"wayland-xcomposite-egl"
"archlevel": 0,
"className": "QWaylandXCompositeEglPlatformIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqwayland-xcomposite-egl.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqwayland-xcomposite-egl.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqoffscreen.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqoffscreen.so, metadata=
"MetaData": {
"Keys": [
"offscreen"
"archlevel": 0,
"className": "QOffscreenIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqoffscreen.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqoffscreen.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqeglfs.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqeglfs.so, metadata=
"MetaData": {
"Keys": [
"eglfs"
"archlevel": 0,
"className": "QEglFSIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqeglfs.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqeglfs.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqxcb.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqxcb.so, metadata=
"MetaData": {
"Keys": [
"xcb"
"archlevel": 0,
"className": "QXcbIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqxcb.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqxcb.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: looking at "/usr/lib/qt/plugins/platforms/libqminimal.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt/plugins/platforms/libqminimal.so, metadata=
"MetaData": {
"Keys": [
"minimal"
"archlevel": 0,
"className": "QMinimalIntegrationPlugin",
"debug": false,
"version": 331520
qt.core.plugin.loader: In /usr/lib/qt/plugins/platforms/libqminimal.so:
qt.core.plugin.factoryloader: "The plugin '/usr/lib/qt/plugins/platforms/libqminimal.so' uses incompatible Qt library. (5.15.0) [release]"
not a plugin
qt.core.plugin.factoryloader: checking directory path "/usr/lib/qt6/plugins/platforms" ...
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqlinuxfb.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqlinuxfb.so, metadata=
"MetaData": {
"Keys": [
"linuxfb"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("linuxfb")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqvkkhrdisplay.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqvkkhrdisplay.so, metadata=
"MetaData": {
"Keys": [
"vkkhrdisplay"
"archlevel": 1,
"className": "QVkKhrDisplayIntegrationPlugin",
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("vkkhrdisplay")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqwayland-egl.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqwayland-egl.so, metadata=
"MetaData": {
"Keys": [
"wayland-egl"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("wayland-egl")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqwayland-generic.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqwayland-generic.so, metadata=
"MetaData": {
"Keys": [
"wayland"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("wayland")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqminimalegl.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqminimalegl.so, metadata=
"MetaData": {
"Keys": [
"minimalegl"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("minimalegl")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqvnc.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqvnc.so, metadata=
"MetaData": {
"Keys": [
"vnc"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("vnc")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqoffscreen.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqoffscreen.so, metadata=
"MetaData": {
"Keys": [
"offscreen"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("offscreen")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqeglfs.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqeglfs.so, metadata=
"MetaData": {
"Keys": [
"eglfs"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("eglfs")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqxcb.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqxcb.so, metadata=
"MetaData": {
"Keys": [
"xcb"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("xcb")
qt.core.plugin.factoryloader: looking at "/usr/lib/qt6/plugins/platforms/libqminimal.so"
qt.core.plugin.loader: Found metadata in lib /usr/lib/qt6/plugins/platforms/libqminimal.so, metadata=
"MetaData": {
"Keys": [
"minimal"
"archlevel": 1,
"debug": false,
"version": 395008
qt.core.plugin.factoryloader: Got keys from plugin meta data QList("minimal")
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, vkkhrdisplay, wayland-egl, wayland, minimalegl, vnc, offscreen, eglfs, xcb, minimal.
fish: Job 1, 'dolphin' terminated by signal
ldd /usr/lib/qt/plugins/platforms/libqxcb.so
linux-vdso.so.1 (0x00007ffed89a6000)
libQt5XcbQpa.so.5 => /usr/lib/libQt5XcbQpa.so.5 (0x00007f1fe2318000)
libQt5Gui.so.5 => /usr/lib/libQt5Gui.so.5 (0x00007f1fe1c98000)
libQt5Core.so.5 => /usr/lib/libQt5Core.so.5 (0x00007f1fe175f000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007f1fe14da000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007f1fe12ee000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x00007f1fe129e000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00007f1fe11d3000)
libQt5DBus.so.5 => /usr/lib/libQt5DBus.so.5 (0x00007f1fe1154000)
libX11-xcb.so.1 => /usr/lib/libX11-xcb.so.1 (0x00007f1fe114f000)
libxcb-icccm.so.4 => /usr/lib/libxcb-icccm.so.4 (0x00007f1fe1148000)
libxcb-image.so.0 => /usr/lib/libxcb-image.so.0 (0x00007f1fe1142000)
libxcb-shm.so.0 => /usr/lib/libxcb-shm.so.0 (0x00007f1fe113d000)
libxcb-keysyms.so.1 => /usr/lib/libxcb-keysyms.so.1 (0x00007f1fe1136000)
libxcb-randr.so.0 => /usr/lib/libxcb-randr.so.0 (0x00007f1fe1124000)
libxcb-render-util.so.0 => /usr/lib/libxcb-render-util.so.0 (0x00007f1fe111e000)
libxcb-render.so.0 => /usr/lib/libxcb-render.so.0 (0x00007f1fe110f000)
libxcb-shape.so.0 => /usr/lib/libxcb-shape.so.0 (0x00007f1fe1109000)
libxcb-sync.so.1 => /usr/lib/libxcb-sync.so.1 (0x00007f1fe1100000)
libxcb-xfixes.so.0 => /usr/lib/libxcb-xfixes.so.0 (0x00007f1fe10f5000)
libxcb-xinerama.so.0 => /usr/lib/libxcb-xinerama.so.0 (0x00007f1fe10f0000)
libxcb-xkb.so.1 => /usr/lib/libxcb-xkb.so.1 (0x00007f1fe10d1000)
libxcb-xinput.so.0 => /usr/lib/libxcb-xinput.so.0 (0x00007f1fe10ac000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007f1fe1081000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007f1fe0f43000)
libSM.so.6 => /usr/lib/libSM.so.6 (0x00007f1fe0f37000)
libICE.so.6 => /usr/lib/libICE.so.6 (0x00007f1fe0f1b000)
libxkbcommon-x11.so.0 => /usr/lib/libxkbcommon-x11.so.0 (0x00007f1fe0f12000)
libxkbcommon.so.0 => /usr/lib/libxkbcommon.so.0 (0x00007f1fe0eca000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00007f1fe0d7c000)
libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x00007f1fe0d4f000)
libGL.so.1 => /usr/lib/libGL.so.1 (0x00007f1fe0cc7000)
libpng16.so.16 => /usr/lib/libpng16.so.16 (0x00007f1fe0c8d000)
libz.so.1 => /usr/lib/libz.so.1 (0x00007f1fe0c74000)
libharfbuzz.so.0 => /usr/lib/libharfbuzz.so.0 (0x00007f1fe0b5a000)
libmd4c.so.0 => /usr/lib/libmd4c.so.0 (0x00007f1fe0b44000)
libm.so.6 => /usr/lib/libm.so.6 (0x00007f1fe0a57000)
libsystemd.so.0 => /usr/lib/libsystemd.so.0 (0x00007f1fe0964000)
libdouble-conversion.so.3 => /usr/lib/libdouble-conversion.so.3 (0x00007f1fe094d000)
libicui18n.so.75 => /usr/lib/libicui18n.so.75 (0x00007f1fe05d1000)
libicuuc.so.75 => /usr/lib/libicuuc.so.75 (0x00007f1fe03d7000)
libpcre2-16.so.0 => /usr/lib/libpcre2-16.so.0 (0x00007f1fe0345000)
libzstd.so.1 => /usr/lib/libzstd.so.1 (0x00007f1fe0264000)
/usr/lib64/ld-linux-x86-64.so.2 (0x00007f1fe2494000)
libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00007f1fe023b000)
libbz2.so.1.0 => /usr/lib/libbz2.so.1.0 (0x00007f1fe0228000)
libbrotlidec.so.1 => /usr/lib/libbrotlidec.so.1 (0x00007f1fe0219000)
libdbus-1.so.3 => /usr/lib/libdbus-1.so.3 (0x00007f1fe01c8000)
libxcb-util.so.1 => /usr/lib/libxcb-util.so.1 (0x00007f1fe01c0000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007f1fe01bb000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007f1fe01b3000)
libuuid.so.1 => /usr/lib/libuuid.so.1 (0x00007f1fe01a9000)
libpcre2-8.so.0 => /usr/lib/libpcre2-8.so.0 (0x00007f1fe010a000)
libGLdispatch.so.0 => /usr/lib/libGLdispatch.so.0 (0x00007f1fe0050000)
libGLX.so.0 => /usr/lib/libGLX.so.0 (0x00007f1fe001e000)
libgraphite2.so.3 => /usr/lib/libgraphite2.so.3 (0x00007f1fdfffc000)
libcap.so.2 => /usr/lib/libcap.so.2 (0x00007f1fdfff0000)
libicudata.so.75 => /usr/lib/libicudata.so.75 (0x00007f1fde29f000)
libbrotlicommon.so.1 => /usr/lib/libbrotlicommon.so.1 (0x00007f1fde27a000)
