HELLO GUYS
THIS MESSAGE IS SHOWN TO ME
HOW CAN I SOLVE IT
core is up to date
extra is up to date
community 6.6 MiB 364 KiB/s 00:19 [################################################] 100%
multilib is up to date
:: Starting full system upgrade…
error: could not open file /var/lib/pacman/local/pacman-mirrors-4.20.0-3/desc: No such file or directory
resolving dependencies…
warning: could not fully load metadata for package pacman-mirrors-4.20.0-3
error: failed to prepare transaction (invalid or corrupted package)
I guess
sudo touch /var/lib/pacman/local/pacman-mirrors-4.20.0-3/desc
sudo pacman -Syu pacman-mirrors
and then
sudo pacman-mirrors -f 5 && sudo pacman -Syyu ?
Feel free to correct me / improve it.
STILL THE SAME
Stop typing in caps.
Do you know what you might have done to have caused this?
Did you do partial updates? Did you install packages via sudo pacman -S instead of sudo pacman -Syu?
dude im copying all commands, after i use your line its shown to me
[ahmadkamal@ahmadkamal-pc ~]$ sudo pacman -S
[sudo] password for ahmadkamal:
error: no targets specified (use -h for help)
sudo find /var/cache/pacman/pkg/ -iname "*.part" -delete
then try update again.
I never told you to use my commands. I asked you a question to determined what might have happened, which you haven’t answered yet.
i didnt use them i update using app center
