I was trying to use the Matplotlib module from Python, but every time i try to execute a function that should open a new window, it works, but returns qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
in the terminal.
I think that it doesn’t like the fact that i use wayland, but do you have any idea about how to solve that ?
A script that displays the error :
import matplotlib.pyplot as plt
import numpy as np
x = np.arange(0, 1)
plt.plot(x, x*x)
plt.show()
The output of inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=64c7e4aa-2dae-4fbe-83d2-3f806bd40ac8 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_wayland vt: 2
Type: Laptop System: LENOVO product: 82LN v: IdeaPad 5 15ALC05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 15ALC05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709WIN
serial: <superuser required> UEFI: LENOVO v: H2CN23WW date: 12/13/2021
ID-1: BAT0 charge: 57.7 Wh (92.2%) condition: 62.6/70.0 Wh (89.4%)
volts: 16.8 min: 15.2 model: Celxpert L19C4PF1 type: Li-poly
serial: <filter> status: discharging cycles: 85
RAM: total: 5.72 GiB used: 5.34 GiB (93.4%)
RAM Report:
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1656 high: 2525 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2525 2: 1616
3: 1638 4: 1698 5: 1397 6: 1595 7: 1807 8: 1445 9: 1784 10: 1408 11: 1397
12: 1398 13: 1399 14: 1696 15: 1826 16: 1881 bogomips: 57505
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositors: 1: kwin_wayland 2: kwin_x11 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.32-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822
class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 8 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 189.73 GiB (39.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ512MEE1OWX size: 476.94 GiB block-size: physical: 512 B
rev: 2.1C0628 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 237.85 GiB size: 233.05 GiB (97.99%)
used: 45.75 GiB (19.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 64c7e4aa-2dae-4fbe-83d2-3f806bd40ac8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 28.6 MiB (11.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 4ED7-C9AA
ID-3: /run/media/nora/Windows-SSD raw-size: 237.85 GiB
size: 237.85 GiB (100.00%) used: 143.96 GiB (60.5%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows-SSD
uuid: 466CDAAD6CDA9751
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: 5802DBE802DBC960
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Syntek Integrated Camera type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 50.0 C
Processes: 381 Uptime: 1d 3h 17m wakeups: 6 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1203
lib: 341 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
