Hello, after last upgrade the Java Virtual Machine its broken,
When I launch a jar file:
Picked up _JAVA_OPTIONS: -Dawt.useSystemAAFontSettings=on -Dswing.aatext=true -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel -Dswing.crossplatformlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel export
Unrecognized option: export
I don know how to fix, any help?
thank you
This looks explicit to me: you should check in your jar launcher where this export option comes from.
hi, yes, export option crash the java virtual machine. I realized using root, java virtual machine works, but dangerous
Already I reinstalled java , but the problem still exist
I really don’t know how to check jar launcher, since it happens with all jar I have ex:jdownloader, freerapid javacpc etc… any command line works, same error
thank you
It seems some options may be globally added. Check the following files:
~/.bashrc
/etc/profile.d/jre.sh
https://wiki.archlinux.org/index.php/Java#Tips_and_tricks
hi, I checked in ~/.bashrc and /etc/profile.d/jre.sh, everything fine, so I checked ~/.profile and found the error, export line misstype.
thank you very much, totally solved
