Could anyone help me with a calibrated profile for my specific laptop screen?
I have this machine:
    System:    Host: manjaro Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 Desktop: GNOME 3.36.6
           Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: FX503VD v: 1.0 serial: <superuser/root required>
           Mobo: ASUSTeK model: FX503VD v: 1.0 serial: <superuser/root required>
           UEFI: American Megatrends v: FX503VD.308 date: 04/29/2019
Battery:   ID-1: BAT1 charge: 52.2 Wh condition: 52.2/64.4 Wh (81%)
CPU:       Topology: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP L2 cache: 6144 KiB
           Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Intel HD Graphics 630 driver: i915 v: kernel
           Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 450.66
           Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
           Display: x11 server: X.org 1.20.8 driver: modesetting FAILED: nvidia
           resolution: <xdpyinfo missing>
           OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.7
Audio:     Device-1: Intel CM238 HD Audio driver: snd_hda_intel
           Sound Server: ALSA v: k5.8.6-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp2s0 state: down mac: 18:31:bf:97:a4:f4
           Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
           IF: wlp4s0 state: up mac: 1a:d4:79:fc:bc:90
Drives:    Local Storage: total: 1.20 TiB used: 218.59 GiB (17.8%)
           ID-1: /dev/mmcblk0 vendor: Samsung model: SP64G size: 59.48 GiB
           ID-2: /dev/sda vendor: A-Data model: SU800NS38 size: 238.47 GiB
           ID-3: /dev/sdb vendor: Seagate model: ST1000LX015-1U7172 size: 931.51 GiB
Partition: ID-1: / size: 233.24 GiB used: 45.99 GiB (19.7%) fs: ext4 dev: /dev/sda2
Swap:      ID-1: swap-1 type: file size: 10.00 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:   System Temperatures: cpu: 46.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 209 Uptime: 3h 36m Memory: 15.52 GiB used: 5.83 GiB (37.6%) Shell: Bash
           inxi: 3.1.05
And this panel B156HAN06.1 HW1A
Thank you.
Hey,
Not sure i follow the request. Is about a predefined *.icc file or how to go about calibrating it?
The color profiles from a color spectrum perspective, by gamut values (relative range) goes like this:
CIE 1976 < sRGB < AdobeRGB < NTSC - so the NTSC holds the most such number, but in your case, that panel has 262K 45% NTSC. That means around 78-80% sRGB that most systems use now as default, but also is less than half of colors of what 100% NTSC can actually provide.
Of course that doesn’t influence the actual quality of the pictures on screen, but still is a limitate range of colors.
Because of those numbers i wonder what kind of backlight that panel has. With a Cold-Cathode Fluorescent Light should give around 70% NTSC, and that is an average. The professional non-wide gamut panels start at about 85% …
Since you are in Gnome, loading the default sRGB profile should give you kind of the best result.
What I’m actually asking is if anyone happens to have the exact same panel I have and if they calibrated it via a hardware colorimeter. In which case I would like them to share there profile so I can apply it to my screen in Gnome.
However I’ve since learned that it doesn’t actually work like this and wear and tear impacts color reproduction and acuracy.
