Trying to run pacman -Syuu / pamac update is making the update system to memory leak, resulting in a session crash
I already ran pacman-mirrors -g and pacman -Scc
Moderator edit: Screenshots removed. You “fixed” it so they’re useless anyway.
Post actual preformatted text, not images of text.
There is a couple of other topics with relation to processes and memory usage with pamac Search results for 'pamac memory' - Manjaro Linux Forum
Until the matter is resolved by the developer - the solution is to disable AUR usage
## Allow Pamac to search and install packages from AUR:
#EnableAUR
Apparently this specific issue was fixed and I could do the upgrade normally.
