Hi,
I just switched to Manjaro and are running an Dell Precision with both Intel iGPU and a Nvidia RTX2000A. I tried installing the proprietary drivers with the auto install and ended up with a non working display server. Uninstalling the drivers via chroot
failed. I just installed the system today, so the quickest solution was going f…it and reinstall again. Now, how do I setup this correctly?
The goal would be to use the Nvidia GPU for Steam.
Output of inxi
Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA107GLM [RTX A2000 Mobile] driver: nouveau v: kernel
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell v: 43.3 driver: gpu: i915 resolution: 1920x1200~60Hz
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics (TGL GT1)
Last try to uninstall the drivers again which didnt work for reference
[manjaro-gnome /]# sudo mhwd -r pci video-nvidia
Error: config 'video-nvidia' is not installed!
[manjaro-gnome /]# sudo mhwd -l
> 0000:01:00.0 (0302:10de:25b8) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
> 0000:00:02.0 (0300:8086:9a60) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
[manjaro-gnome /]# sudo mhwd -r pci video-hybrid-intel-nvidia-prime
> Removing video-hybrid-intel-nvidia-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-hybrid-intel-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
checking dependencies...
:: removing nvidia-utils breaks dependency 'nvidia-utils' required by cuda
Error: pacman failed!
Error: script failed!
