When I try to run any Appimage or Superproductivity app I got core dump, but I can run them when I log as a different user.
It seems somethng is missing in my user account but I don´t know how to fix it.
journalctl gives me
set 30 11:01:24 ryzen3 systemd[10978]: Started superProductivity.
set 30 11:01:24 ryzen3 kernel: nvme0n1: Read(0x2) @ LBA 50667528, 8 blocks, Unrecovered Read Error (sct 0x2 / sc 0x>
set 30 11:01:24 ryzen3 kernel: critical medium error, dev nvme0n1, sector 50667528 op 0x0:(READ) flags 0x0 phys_seg>
set 30 11:01:24 ryzen3 systemd[1]: Started Process Core Dump (PID 23896/UID 0).
My system is:
Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
root=UUID=f628bae7-a967-4e74-96c5-ffafa3035fa5 rw rootflags=subvol=@ quiet
splash resume=UUID=8631cf73-9d5e-4b0f-ba44-92c1d0ef7f0a
udev.log_priority=3 ipv6.disable=1
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop System: Gigabyte product: AB350M-DS3H V2 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350M-DS3H V2-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F52g date: 07/27/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2066 high: 3154 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3154 2: 1278
3: 1278 4: 2554 bogomips: 28756
Type: spec_rstack_overflow mitigation: SMT disabled
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1 empty: HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 43.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: DVI-D-1 model: AOC 2470W serial: <filter> built: 2018
res: 1920x1080 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.7-1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven LLVM 16.0.6
DRM 3.54 6.5.3-1-MANJARO) device-ID: 1002:15d8 memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.264 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.1.7-1
device-ID: 1002:15d8 surfaces: xcb,xlib
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.3-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
vendor: Gigabyte driver: r8169 v: kernel modules: r8168 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.2:3
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.27 TiB used: 1.01 TiB (79.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: ADATA SX6000LNP
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V9002s77 temp: 42.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
scheme: GPT
ID-1: / raw-size: 200.39 GiB size: 200.39 GiB (100.00%)
used: 81.97 GiB (40.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 608 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 953.87 GiB size: 953.87 GiB (100.00%)
used: 947.72 GiB (99.4%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/log raw-size: 200.39 GiB size: 200.39 GiB (100.00%)
ID-1: swap-1 type: partition size: 32 GiB used: 2.14 GiB (6.7%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 43.9 C mobo: 35.0 C gpu: amdgpu temp: 43.0 C
Fan Speeds (rpm): N/A
Processes: 350 Uptime: 1h 20m wakeups: 2 Memory: total: 16 GiB note: est.
available: 13.57 GiB used: 5.92 GiB (43.6%) Init: systemd v: 254
Packages: 1588 pm: pacman pkgs: 1561 libs: 416 tools: pamac,yay pm: flatpak
pkgs: 21 pm: snap pkgs: 6 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.30
I installed my system on two separate disk, root is installed on a SSD and /home is on a nvme.
pacman -Qk 2>/dev/null | grep -v ’ 0 missing files’
audit: 208 total files, 4 missing files
bolt: 32 total files, 1 missing file
cups: 941 total files, 2 missing files
flatpak: 215 total files, 1 missing file
fwupd: 3878 total files, 1 missing file
geoclue: 116 total files, 1 missing file
gvfs: 333 total files, 1 missing file
manjaro-hotfixes: 7 total files, 1 missing file
manjaro-zsh-config: 91 total files, 1 missing file
nfs-utils: 124 total files, 3 missing files
packagekit: 303 total files, 1 missing file
polkit: 217 total files, 1 missing file
systemd: 1365 total files, 1 missing file
sudo smartctl -x /dev/nvme0n1p1
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.5.3-1-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: ADATA SX6000LNP
Serial Number: 2L08292B5QNG
Firmware Version: V9002s77
PCI Vendor/Subsystem ID: 0x10ec
IEEE OUI Identifier: 0x00e04c
Controller ID: 1
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 1.024.209.543.168 [1,02 TB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 00e04c 1d18ada315
Local Time is: Sat Sep 30 12:11:24 2023 -03
Firmware Updates (0x02): 1 Slot
Optional Admin Commands (0x0007): Security Format Frmw_DL
Optional NVM Commands (0x0014): DS_Mngmt Sav/Sel_Feat
Log Page Attributes (0x03): S/H_per_NS Cmd_Eff_Lg
Maximum Data Transfer Size: 32 Pages
Warning Comp. Temp. Threshold: 115 Celsius
Critical Comp. Temp. Threshold: 120 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 8.00W - - 0 0 0 0 0 50000
1 + 4.00W - - 1 1 1 1 0 50000
2 + 3.00W - - 2 2 2 2 0 50000
3 - 0.0500W - - 3 3 3 3 4000 50000
4 - 0.0080W - - 4 4 4 4 8000 100000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 42 Celsius
Available Spare: 100%
Available Spare Threshold: 32%
Percentage Used: 1%
Data Units Read: 17.798.987 [9,11 TB]
Data Units Written: 24.561.562 [12,5 TB]
Host Read Commands: 389.778.298
Host Write Commands: 294.643.259
Controller Busy Time: 0
Power Cycles: 243
Power On Hours: 2.159
Unsafe Shutdowns: 17
Media and Data Integrity Errors: 19
Error Information Log Entries: 457
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Error Information (NVMe Log 0x01, 8 of 8 entries)
No Errors Logged
Self-tests not supported
