Corectrl symbol lookup error
Hi, i upgraded corectrl to the latest version (1.3.8.1) but it won’t start: it says "
[mosco@matebook ~]$ corectrl
corectrl: symbol lookup error: /usr/lib/libcorectrl.so: undefined symbol: _ZN4pugi10xml_writerD2Ev
Downgrading to previous version works, but i wanna try to understand how to fix this issue.
Can anyone help me?
Found this :
This is an older version for the non-systemd Artix Linux
Ensure your system is completely up-to-date
sudo pacman-mirrors --continent && sudo pacman -Syu
Thanks for the answers guys.
I tried to upgrade as you said, but no luck…
do you have other suggestions?
:thinking:
Remove the app - update your system - reinstall the app - if that doesn’t do it - hmm?
:thinking:
I test on unstable branch - so one could speculate - which Manjaro branch is your system based on?
pacman-mirrors -G
As the version is the same for all branches - there must be other things in play - but I have no idea what that might be.
it says “stable”
i’ll try to remove and reinstall.
[EDIT] the issue is still here…
