Hi,
I’m using a raw developer called Filmulator on 2 machines with Manjaro Openbox, both updated to the latest, and kernel 5.10 (on this pc I’m writing now, can’t check the other but it should be the same).
Filmulator stopped running, and launching it from the terminal I get this error message:
/usr/include/c++/11.1.0/bits/stl_vector.h:1045: std::vector<_Tp, _Alloc>::reference std::vector<_Tp, _Alloc>::operator[](std::vector<_Tp, _Alloc>::size_type) [with _Tp = double; _Alloc = std::allocator<double>; std::vector<_Tp, _Alloc>::reference = double&; std::vector<_Tp, _Alloc>::size_type = long unsigned int]: Assertion '__n < this->size()' failed.
zsh: abort (core dumped) filmulator
On the other pc I installed Darktable, but then I got the same error message (or something very similar, but again with the “core dumped” bit. RawTherapee instead seems to be working (at least on this one I’m writing now…).
Any idea? Any way to fix this?
thanks!
