Thanks for the reply!
Here is the output of inxi -Fza:
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=212ac3a4-68a9-4ac8-9db5-19ae6f64237e rw rootflags=subvol=@
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20FCS3GL00 v: ThinkPad X1 Carbon 4th
Mobo: LENOVO model: 20FCS3GL00 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N1FET78W (1.52 )
date: 12/27/2021
ID-1: BAT0 charge: 36.3 Wh (100.0%) condition: 36.3/52.1 Wh (69.7%)
volts: 16.9 min: 15.2 model: SMP 00HW029 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 425 high: 500 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 500 2: 400 3: 400 4: 400
bogomips: 20004
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 13d3:5248
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x173d built: 2014 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: off with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 238.47 GiB used: 171.64 GiB (72.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLN256HCHP-000L7
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2L6Q scheme: GPT
ID-1: / raw-size: 36.13 GiB size: 36.13 GiB (100.00%)
used: 28.32 GiB (78.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
used: 9.7 MiB (1.9%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 201.83 GiB size: 201.83 GiB (100.00%)
used: 143.32 GiB (71.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 37.0 C pch: 35.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Processes: 252 Uptime: 1h 15m wakeups: 2 Memory: total: 8 GiB note: est.
available: 7.49 GiB used: 2.75 GiB (36.8%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: clang: 16.0.6 Packages:
pm: pacman pkgs: 1795 libs: 482 tools: pamac pm: flatpak pkgs: 0 Shell: Bash
v: 5.2.21 running-in: gnome-terminal inxi: 3.3.31
And here are the lines from /var/log/pacman.log. I’m not 100% sure whether the problems started after the updates on 2023-12-21 or 2023-12-22, so I added both. See [2023-12-21T13:29:02+0100] [PAMAC] synchronizing package lists[2023-12-21T13:2 - Pastebin.com
A bit more specific about the issues I’m facing: most programs that are affected just don’t start. For example, in the terminal (errors unfortunately are in Dutch):
[sander@deimos ~]$ gimp
Segmentatiefout (geheugendump gemaakt)
[sander@deimos ~]$ electron22
Busfout (geheugendump gemaakt)
[sander@deimos ~]$ gnome-calendar
Firefox does start, but it crashes its tab as soon as I load any page, and it shows me the standard firefox “Gah. Your tab just crashed.” error page. In the terminal I see this error at the moment the tab crashes:
[Parent 8974, IPC I/O Parent] WARNING: process 9245 exited on signal 7: file /build/firefox/src/firefox-121.0/ipc/chromium/src/base/process_util_posix.cc:265
If any other data or info is needed, just let me know and I’ll post it here!
