Copy TIME & DATE to clipboard does not work on wayland
Sometimes i use “copy to clipboard” from the RIGHT CLICK menu of the time in the panel. Works fine with x11. It does not work with wayland.
I can confirm this.
This is strange. I was able to copy from the available formats one time just now, but subsequent attempts failed.
I could reproduce it as well
https://bugs.kde.org/show_bug.cgi?id=490803
Most plasma components has a button Report a Bug… on the about page for the component which will take you to the relevant bugtracker to report it.
so it isnt a manjaro problem, it is KDE wide?
why did nobody notice?
btw “clipboard empty” is not correct. the previous copied thing still exists.
Yes.
Because not many people use that functionality, perhaps?
I have never used it, until now;
and can also confirm that this fails on Wayland.
However, the data does show in the Clipboard widget; after clicking the Clipboard widget icon (not the entry) the data pastes as expected; but fails without this intermediary.
2460517.21380
