Converting odt files to pdf
I have a small script, which converts odt to pdf files:
find /home/armin/Dokumente/Briefepdf/ -name "*.odt"  -exec ./odt2pdf.sh "{}"  \;
exit
and
#! /bin/bash
libreoffice --headless --convert-to pdf --outdir $(dirname "$1") "$1"
exit
During operatio, the output of the script is:
Could not find Java Runtime enviroment
How to solve this ?
Install it?
sudo pacman -Syu jre-openjdk
Why install it explicitly when it’s always a dependency?
❯ pacman -Si libreoffice-{fresh,still} | grep java-
Optional Deps   : java-runtime: adds java support
                  java-environment>=17: required by extension-wiki-publisher and extension-nlpsolver
By the way, in case one did not know, jre-openjdk / jreXX-openjdk provides java-runtime.
It really should be done this way:
sudo pacman -Syu  #  Always make sure one is up to date
sudo pacman -S --asdeps  java-runtime  # Choose preferred version
An alternative solution for converting odt to *pdf using pandoc. This could be scripted as needed, however, the downside is that latex would also need to be installed for .pdf output:
1. Install pandoc:
sudo pacman -S pandoc
2. Convert .odt to .pdf (example):
pandoc -s HelloWorld.odt -o HelloWorld.pdf
pandoc -s "Hello World.odt" -o "Hello World.pdf"
More examples here.
Cheers.
Libreoffice is also a java-free solution if users disable the JRE in libreoffice.
(as shown above its not actually a required dependency … its an optional one)
You can change this in the LO interface under Settings > Advanced.
You can also augment the configuration file in your HOME.
~/.config/libreoffice/[0-9]/user/config/javasettings_Linux_X86_64.xml
<enabled xsi:nil="false">false</enabled>
I also checked after ripping out java and the headless conversion works fine.
$ sudo pacman -Rdd jre-openjdk-headless
Packages (1) jre-openjdk-headless-22.0.2.u9-1
Total Removed Size:  145.31 MiB
:: Do you want to remove these packages? [Y/n]
No Java environment is set as default anymore
(1/1) removing jre-openjdk-headless        [##################################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
$ libreoffice --headless --convert-to pdf testdoc.odt
convert ~/Documents/testdoc.odt as a Writer document -> ~/Documents/testdoc.pdf using filter : writer_pdf_Export
I know we are talking about the function of a script here, but no java is needed to export an .odt file as pdf in LibreOffice. File-Export As-Export as pdf.
I don’t get the point of a script. Is it to batch convert?
Yes, it is.
Indeed. User has java runtime environment enabled for libreoffice … while not having a jre installed.
