0n0w1c
30 January 2022 14:07
1
sudo pacman -Ru --nodeps pulseaudio pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-bluetooth pulseaudio-pa pulseaudio-alsa pulseaudio-ctl manjaro-pulse && sudo pacman -S manjaro-pipewire
This no longer works due to package changes. I did a install of i3wm via the manjaro-arm-installer and it installed pulseaudio, no pipewire packages are installed. What is the proper way to remove pulseaudio and replace it with pipewire?
try the first recommended way first;
@realmain
Hi,
I was reading through the thread in the process of removing pulseaudio and changing to Pipewire. If I read everything correctly can you confirm these steps are correct:
Installing Pipewire on Arch Linux
(1) Uninstall pulseaudio:
sudo pacman -R pipewire-pulse
sudo pacman -R manjaro-pulse
sudo pacman -R pulseaudio
If the previous not works then:
sudo pacman -Rdd pulseaudio pulseaudio-alsa pulseaudio-bluetooth pulseaudio-ctl pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc …
0n0w1c
30 January 2022 14:29
3
The older instructions refer to packages that no longer exist: manjaro-pulse, manjaro-pipewire, etc.
Nor do I have them installed:
$ pacman -Ss manjaro | grep installed
core/filesystem 2021.02-2 [installed]
core/manjaro-arm-keyring 20210807-1 [installed]
core/manjaro-hotfixes 2018.08-6 [installed]
core/manjaro-keyring 20210910-2 [installed]
core/manjaro-release 22.01-1 [installed]
core/manjaro-system 20220115-1 [installed]
core/pacman-mirrors 4.23.2-2 [installed]
extra/plymouth-theme-manjaro 1-1 [installed]
community/adapta-maia-theme 3.94.0.149-2 [installed]
community/artwork-manjaro-arm-i3 20190121-1 [installed]
community/conky-i3-pinebook 20200308-1 (i3-manjaro) [installed]
community/dmenu-manjaro 5.0-2 (i3-manjaro) [installed]
community/i3-arm-scripts 20200312-1 [installed]
community/i3exit 20201126-1 (i3-manjaro) [installed]
community/i3status-manjaro 2.13-3 (i3-manjaro) [installed]
community/manjaro-arm-i3-settings 20200920-1 [installed]
community/manjaro-arm-wallpapers 20220109-1 [installed]
community/papirus-maia-icon-theme 20200702-2 [installed]
community/rpi4-post-install 20211125-3 [installed]
community/st-manjaro 1:0.8.2.r31.g51e19ea-1 [installed]
community/sterminal 0.11-1 [installed]
community/vertex-maia-themes 20180519-4 [installed]
community/xcursor-maia 20160417-1 [installed]
Looking at what pulse packages are installed:
$ pacman -Ss pulse | grep installed
extra/libpulse 15.0-1 [installed]
extra/pavucontrol 1:5.0-1 [installed]
extra/pulseaudio 15.0-1 [installed]
extra/pulseaudio-alsa 1:1.2.6-2 [installed]
extra/pulseaudio-bluetooth 15.0-1 [installed]
Strit
30 January 2022 14:32
4
If you simply install pipewire-pulse
(and replace the packages it mentions) it should use a pipewire service instead of pulseaudio on reboot.
system
Closed
2 February 2022 04:46
6
