Controller not working
I’m using a generic ps3 controller, for some reason it doesn’t work, i tried to look at the lsusb and he doesn’t seen to be recognised, i also tried “sudo dmesg -w” and nothing is shown by the controller.
Hi @migs3663 and welcome to the Manjaro community.
I’m sure a Forum Member will offer advice when they are able. In the meantime, please help them to help you;
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Well, if the system doesn’t see anything from
lsusb
sudo dmesg -w
journalctl -f
when you plug it in and unplug it
then there are only few possible reasons:
  • the USB port is broken
  • the controller is broken
  • the cable is broken
Eliminate the first option by testing the port with another device.
Check the controller on another machine for the other two :man_shrugging:
Thanks, i gonna try to test the controller on a friend pc when i get a chance to see if it’s the controller or maybe the cable that it’s not working
