Hi,
I’m trying to install Manjaro on an EFI system that currently holds Windows 10 and Ubuntu on a two partition LVM group (/ and /home). I’d like to reuse my /home to keep gnome and app configs, as well as data, so my plan was to just format the root volume and mount existing /home and /boot/efi.
However, after setting the manual partitioning scheme on Calamares it blows me with an error (translating from Spanish):
Installer failed when formatting partition /dev/vant/root on drive ‘vant’
Create ext4 filesystem on partition /dev/vant/root
Job: clear filesystem from /dev/vant/root
Job: create ext4 filesystem on /dev/vant/root
Command: mkfs.ext4 -qF /dev/vant/root
I read around and it seems that I’m following all the checklist from the guide titled “Dual boot Manjaro and Windows”, I can’t include links in my post. Including Intel RST and Optane, but skipping all formatting steps and swap partition.
Any ideas? System info below:
$ inxi -Fza
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=es_ES keytable=es
tz=Europe/Madrid misobasedir=manjaro misolabel=MANJARO_GNOME_202 quiet
systemd.show_status=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Laptop System: Notebook product: N14xWU v: N/A serial: <filter>
Chassis: No Enclosure type: 10 serial: <filter>
Mobo: Notebook model: N14xWU serial: <filter> UEFI: American Megatrends
v: 1.05.02 date: 03/26/2018
ID-1: BAT0 charge: 35.0 Wh condition: 35.0/35.3 Wh (99%) volts: 13.0/11.4
model: Notebook BAT type: Li-ion serial: <filter> status: Full
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 6144 KiB
bogomips: 28808
Speed: 700 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 702 2: 743
3: 740 4: 747 5: 782 6: 705 7: 797 8: 745
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: CLEVO/KAPOK driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus ID: 1-4:3 chip ID: 04f2:b649
Display: wayland server: X.org 1.20.10 compositor: gnome-shell
driver: i915 note: display driver n/a - try sudo/root display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.11-3-MANJARO
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: e000 bus ID: 3a:00.1
chip ID: 10ec:8168
IF: enp58s0f1 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: e000
bus ID: 3b:00.0 chip ID: 8086:2526
IF: wlp59s0 state: up mac: <filter>
Device-3: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
bus ID: 1-5:4 chip ID: 8087:0025
Local Storage: total: 238.12 GiB used: 207.9 MiB (0.1%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA1000M8240G size: 223.57 GiB
block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
serial: <filter> rev: E8FK11.L scheme: GPT
ID-2: /dev/sda type: USB model: General USB Flash Disk size: 14.55 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1100
scheme: MBR
ID-1: / raw size: N/A size: 11.64 GiB used: 207.9 MiB (1.7%) fs: overlay
source: ERR-102
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 275 Uptime: 29m Memory: 15.52 GiB used: 1.79 GiB (11.5%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1246 lib: 321
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.08
$ LANG=C sudo parted -l
Model: General USB Flash Disk (scsi)
Disk /dev/sda: 15.6GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2816MB 2820MB 4194kB primary esp
Model: KINGSTON SA1000M8240G (nvme)
Disk /dev/nvme0n1: 240GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 boot, esp
2 538MB 140GB 140GB lvm
3 140GB 140GB 16.8MB Microsoft reserved partition msftres
4 140GB 240GB 99.4GB ntfs Basic data partition msftdata
5 240GB 240GB 545MB ntfs hidden, diag
$ LANG=C sudo efibootmgr -v
BootCurrent: 0004
Timeout: 1 seconds
BootOrder: 0003,0004,0001,0000,0002
Boot0000* Windows Boot Manager HD(1,GPT,2f85e27b-dc95-4e1d-a385-31823a572442,0x800,0x100000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot0001* ubuntu HD(1,GPT,2f85e27b-dc95-4e1d-a385-31823a572442,0x800,0x100000)/File(\EFI\UBUNTU\SHIMX64.EFI)
Boot0002* Xen VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0003* UEFI: General USB Flash Disk 1100 PciRoot(0x0)/Pci(0x14,0x0)/USB(0,0)/CDROM(1,0x53e904,0x8000)..BO
Boot0004* UEFI: General USB Flash Disk 1100, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(0,0)/HD(1,MBR,0x0,0x53e904,0x2000)..BO
$ test -d /sys/firmware/efi && echo efi || echo bios
efi
Thanks a lot!
