Control (video game) won't register input after opening menus and doesn't show up as a running application
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
  Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: F21 date: 02/08/2018
  System RAM: total: 16 GiB available: 15.57 GiB used: 4.02 GiB (25.8%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD4-3000 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001129
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2800 min/max: 1550/3200 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2800 2: 2800 3: 2800
    4: 2800 5: 2800 6: 2800 7: 2800 8: 2800 9: 2800 10: 2800 11: 2800 12: 2800
    bogomips: 76670
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
    lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
    driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 08:00.0 chip-ID: 10de:1c02 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
    s-diag: 1252mm (49.29")
  Monitor-1: DVI-D-0 pos: primary,left res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27.01")
    modes: N/A
  Monitor-2: HDMI-0 pos: right res: mode: 1920x1080 hz: 75 scale: 100% (1)
    dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
    memory: 2.93 GiB
  API: Vulkan v: 1.4.303 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1060 3GB driver: N/A device-ID: 10de:1c02 surfaces: xcb,xlib
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: nvidia-smi
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte
    bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Blue Microphones Yeti Nano
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: b58e:0005 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off with: nsmd status: off tools: N/A
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-media-session
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-jack
    type: module tools: pacat,pactl,pavucontrol
    lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
    driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
  Report: hciconfig ID: hci0 rfk-id: 1 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
  Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
    link-mode: peripheral accept
  Local Storage: total: 3.41 TiB used: 1.37 TiB (40.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 167.97 GiB (73.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 40809886-d17c-433b-876f-89a03d053b64
    used: 80.3 MiB (26.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
    uuid: E832-7B45
  ID-3: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
    size: 915.82 GiB (98.31%) used: 853.09 GiB (93.2%) fs: ext4 dev: /dev/sdd
    maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
  ID-4: /run/media/nicholas/second disk raw-size: 434.51 GiB
    size: 426.62 GiB (98.18%) used: 235.09 GiB (55.1%) fs: ext4 dev: /dev/sdc2
    maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
  ID-5: /run/media/nicholas/third-disk raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 147.98 GiB (8.1%) fs: ext4 dev: /dev/sda
    maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
  ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
    uuid: 14863704-322a-453c-b7a5-87bba34bb094
  Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Device-1: 3-2:2 info: Blue Microphones Yeti Nano type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    chip-ID: b58e:0005 class-ID: 0300 serial: <filter>
  Device-2: 3-3:3 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
  Device-3: 3-4:4 info: Ducky One 3̠ type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
    serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 42.4 C mobo: 29.0 C
  Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-3: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.29
  Processes: 348 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.22 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 2529 pm: pacman pkgs: 2515 libs: 630 tools: gnome-software,pamac
    pm: flatpak pkgs: 5 pm: snap pkgs: 9 Compilers: clang: 18.1.8 gcc: 14.2.1
    Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.37
I just installed Control with Wine through Lutris. Game boots up just fine, I can press escape and skip a couple opening screens and once it gets to the title screen then the keyboard won’t be recognized. I plugged in a controller and the icon changed on the “press [button] to play” but neither the controller or keyboard input would do anything.
When tabbing out of the program it didn’t show up on my currently running applications. Any ideas? Thank you!
edit: It was hard searching for problems with this game due to its title (the word “control” is pretty common with computer applications…) but I did find a Reddit post with the same issue. Seems like using GeForce experience or running as admin can work on Windows. Not sure how to replicate that in linux!
edit2: While not a fix for the original problem, I did install Control through Heroic instead of Lutris and it works fine!
I remember having the same problem. This was because I first needed an internet connection with Control before I could play. This was the case on Linux and Windows. I used the GOG version. After this initial internet connection I can play offline. I suspect you are using an old version of the game that is not patched.
That could be it! I see a patch on GOG and I’m going to try installing that and see what happens. If you have a resource handy on how to do this and would like to share that would be awesome, otherwise I’m going to look up how to install patches through Lutris/Wine because I’ve never done it before. Thanks for the info!
edit: Tried the patch from GOG, it was already installed so that didn’t fix it.
Well I used the gog offline installer and it works. I can start the game just fine without issue. I am using the Bottles flatpak. Install it, run, works just fine. :man_shrugging:
I’ll try that and see what happens. Thanks again.
Do you use Bottles for most games? I honestly don’t care that much for Lutris and only use it for GoG and if Bottles works fine I might just switch.
Well, I don’t play often and usually only older games. Bottles was enough for me. Lutris had too many setting options for me. A big plus is the database with install scripts, which you don’t have in bottles. Everyone as he needs it. :man_shrugging:
