Console: italian keyboard layout with one key wrong
Hi all,
sorry for the stupid question; but I’m facing a strange behaviour.
I have an italian qwerty keyboard and everything work correctly in KDE Plasma: konsole application sees the correct characters using bash or zsh.
Strangely activating the console (CTRL+ALT+F3) the only key I cannot type is the dash (-).
The key is the one near the right shift. This key types dash (-) and with shift types underscore (_)
On the console it types slash (/) and with shift types underscore (_)
All the other keys (normal and with shift) type what is expected.
What can i do?
Make sure you use the correct keymap in /etc/vconsole.conf
cat /etc/vconsole.conf
 $ localectl list-keymaps | grep it
it
it-ibm
it2
mac-it
If you list the content of ~/.config/plasma-localerc you may get a hint
When you have found the correct name
localectl set-keymap <keymap>
I’ll try to gather informations.
Issuing the commands in konsole (plasma) I have
vconsole.conf
    ~  cat /etc/vconsole.conf         ✔
KEYMAP=it2
list-keymaps
    ~  localectl list-keymaps | grep it         ✔
it
it-ibm
it2
mac-it
plasma-localerc
    ~  cat ~/.config/plasma-localerc         ✔
[Formats]
LANG=it_IT.UTF-8
Maybe I didn’t explain myself
In Plasma all keyboard mappings are correct also for the key in the red box.
And this happens only when I switch to the character console (CTRL+ALT+F3) terminal
In this terminal the key in the red box types the slash (/) .
All the italian characters (green boxes) are correct and only the lower rightmost key is wrong (but the SHIFT+this-key is correct).
Strangely ALTGR+this-key gives the dash (-)
Any hint?
I can’t say - but since you are using it2 - changing to it cannot be much different
localectl set-keymap it
Thanks
I’ll go on using ALTGR
BTW I only needed the dash for issuing sudo pacman -Syu :slightly_smiling_face:
I believe “it” would indeed be the correct layout, going by what Wikipedia says. :point_down:
https://upload.wikimedia.org/wikipedia/commons/thumb/7/7c/KB_Italian.svg/630px-KB_Italian.svg.png
Just do what @ManjaroDevOps said, and then you’ll have the correct keyboard layout everywhere. :wink:
Sorry going to the link gives
Wikipedia does not have an article with this exact name. Please search for Italian keyboard layouthttps://en.wikipedia.org/wiki/Italian keyboard layout in Wikipedia to check for alternative titles or spellings.
Do you have any idea where to find the layouts for “it” and “it2”?
My apologies — it was an error in the copy/pasting of the link in my post. I’ve corrected it now. The link should now work. :wink:
Yes. Now the link is correct.
I read the article but every reference to italian key excludes the dash/underscore key
The header for the it2 keymap explains the changes and why - is mapped to /
