cat /etc/lsb-release
DISTRIB_ID="ManjaroLinux"
DISTRIB_RELEASE="23.0.0"
DISTRIB_CODENAME="Ultima Thule"
DISTRIB_DESCRIPTION="Manjaro Linux"
inxi -Fxz
Kernel: 5.15.114-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1 Desktop: GNOME v: 44.1
Type: Convertible System: HP product: HP ENVY x360 Convertible 15m-ds0xxx v: N/A
serial: <superuser required>
Mobo: HP model: 85DD v: 40.36 serial: <superuser required> UEFI: AMI v: F.18 date: 11/07/2019
ID-1: BAT0 charge: 32.4 Wh (61.6%) condition: 52.6/52.6 Wh (100.0%) volts: 15.4 min: 15.4
model: 313-54-41-A SA04055XL status: discharging
Device-1: hid-0018:04F3:2401.0001-battery model: ELAN2514:00 04F3:2401 charge: N/A status: N/A
Info: quad core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB L2: 2 MiB L3: 4 MiB
Speed (MHz): avg: 1315 high: 1612 min/max: 1400/2100 boost: enabled cores: 1: 1400 2: 1612
3: 1217 4: 1209 5: 1340 6: 1233 7: 1263 8: 1250 bogomips: 33549
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-5 bus-ID: 04:00.0 temp: 42.0 C
Display: wayland server: X.Org v: 23.1.1 with: Xwayland v: 23.1.1 compositor: gnome-shell
driver: X: loaded: amdgpu unloaded: modesetting dri: radeonsi gpu: amdgpu
resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Vega 8 Graphics (raven LLVM 15.0.7 DRM
3.42 5.15.114-2-MANJARO) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 04:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard driver: snd_pci_acp3x
v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 04:00.6
API: ALSA v: k5.15.114-2-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.70 status: off
Server-3: PulseAudio v: 16.1 status: active
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Hewlett-Packard
driver: rtw_8822be v: N/A port: f000 bus-ID: 02:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB bus-ID: 3-2:2
Local Storage: total: 238.47 GiB used: 168.61 GiB (70.7%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC501 HFM256GDJTNG-8310A size: 238.47 GiB
temp: 37.9 C
ID-1: / size: 224.71 GiB used: 168.61 GiB (75.0%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
System Temperatures: cpu: 42.6 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 301 Uptime: 12m Memory: available: 5.67 GiB used: 2.25 GiB (39.6%) Init: systemd
Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1720 Client: Unknown Client: octopi inxi: 3.3.27
mhwd -li -d
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
Warning: no installed configs for USB devices found!
journalctl -b -p err
Jun 05 02:35:54 issun systemd[1]: Failed to start Control Group configuration service.
Jun 05 02:35:54 issun kernel: amd_pmc AMD0004:00: SMU debugging info not supported on this platform
Jun 05 02:35:54 issun kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xd7cd8000-0xd7cd8fff flags 0x200] vs d7cd8000 4000
Jun 05 02:35:54 issun kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xd7cdc000-0xd7cdcfff flags 0x200] vs d7cdc000 4000
Jun 05 02:35:54 issun kernel: lis3lv02d: unknown sensor type 0x0
Jun 05 02:35:56 issun bluetoothd[996]: src/plugin.c:plugin_init() Failed to init vcp plugin
Jun 05 02:35:56 issun bluetoothd[996]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jun 05 02:35:56 issun bluetoothd[996]: src/plugin.c:plugin_init() Failed to init bap plugin
Jun 05 02:36:03 issun gdm-password][1425]: gkr-pam: unable to locate daemon control file
Jun 05 02:36:04 issun systemd[1457]: Failed to start Application launched by gnome-session-binary.
Jun 05 02:36:07 issun systemd[1457]: Failed to start Application launched by gnome-session-binary.
Jun 05 02:36:09 issun fingerprint-polkit-agent[2010]: Could not register listener "/fingerprintgui/PolicyKit1/AuthenticationAgent". Aborting.
Jun 05 02:36:11 issun gnome-software[2007]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 05 02:36:12 issun systemd-coredump[2284]: Process 2007 (gnome-software) of user 1000 dumped core.
Stack trace of thread 2007:
#0 0x00007fd3eba06408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007fd3eba06703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007fd3eba06975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007fd3eba06c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007fd3ebc3d00a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007fd3ebc41e8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007fd3ebc43230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x0000555562840670 gs_shell_get_query_license_type (gnome-software + 0x6e670)
#8 0x000055556282eb25 n/a (gnome-software + 0x5cb25)
#9 0x00007fd3ebb07210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#10 0x00007fd3ebb352f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#11 0x00007fd3ebb25095 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32095)
#12 0x00007fd3ebb25324 g_signal_emit (libgobject-2.0.so.0 + 0x32324)
#13 0x000055556281b574 n/a (gnome-software + 0x49574)
#14 0x00007fd3ebbfc3f4 n/a (libgio-2.0.so.0 + 0xa83f4)
#15 0x00007fd3ebc0008d n/a (libgio-2.0.so.0 + 0xac08d)
#16 0x00007fd3ebe65edd n/a (libgnomesoftware.so.20 + 0x63edd)
#17 0x00007fd3ebbfc3f4 n/a (libgio-2.0.so.0 + 0xa83f4)
#18 0x00007fd3ebc0008d n/a (libgio-2.0.so.0 + 0xac08d)
#19 0x00007fd3ebe59121 n/a (libgnomesoftware.so.20 + 0x57121)
#20 0x00007fd3ebe5d7da n/a (libgnomesoftware.so.20 + 0x5b7da)
#21 0x00007fd3ebbfc3f4 n/a (libgio-2.0.so.0 + 0xa83f4)
#22 0x00007fd3ebbfc42d n/a (libgio-2.0.so.0 + 0xa842d)
#23 0x00007fd3eba0253b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#24 0x00007fd3eba5f219 n/a (libglib-2.0.so.0 + 0xb7219)
#25 0x00007fd3eba011a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#26 0x00007fd3ebc303be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#27 0x00005555627f68d6 main (gnome-software + 0x248d6)
#28 0x00007fd3eac19850 n/a (libc.so.6 + 0x23850)
#29 0x00007fd3eac1990a __libc_start_main (libc.so.6 + 0x2390a)
#30 0x00005555627f69b5 _start (gnome-software + 0x249b5)
Stack trace of thread 2039:
#0 0x00007fd3eacf92ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007fd3eba587b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007fd3eb9ccfb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007fd3eba33f9e n/a (libglib-2.0.so.0 + 0x8bf9e)
#4 0x00007fd3eba2f315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007fd3eac7d44b n/a (libc.so.6 + 0x8744b)
#6 0x00007fd3ead00e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 2041:
#0 0x00007fd3eacf3c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007fd3eba5f17f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007fd3eba01c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007fd3ebc62d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
Stack trace of thread 2244:
#2 0x00007fd3eba011a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007fd3ebe6b02f n/a (libgnomesoftware.so.20 + 0x6902f)
Stack trace of thread 2101:
#1 0x00007fd3eba58d03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007fd3eb9ccf83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007fd3eba349fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Stack trace of thread 2048:
#3 0x00007fd3e40d5fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 2040:
#3 0x00007fd3eba011f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 2245:
Stack trace of thread 2246:
Stack trace of thread 2248:
Jun 04 19:46:34 issun gnome-software[5617]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 04 19:46:36 issun systemd-coredump[5796]: Process 5617 (gnome-software) of user 1000 dumped core.
Stack trace of thread 5617:
#0 0x00007f3c5fe32408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007f3c5fe32703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007f3c5fe32975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007f3c5fe32c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007f3c6006900a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007f3c6006de8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007f3c6006f230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x000055f76199068b n/a (gnome-software + 0x6b68b)
#8 0x000055f7619908ea n/a (gnome-software + 0x6b8ea)
#9 0x00007f3c5ea534f6 n/a (libffi.so.8 + 0x74f6)
#10 0x00007f3c5ea4ff5e n/a (libffi.so.8 + 0x3f5e)
#11 0x00007f3c5ea52b73 ffi_call (libffi.so.8 + 0x6b73)
#12 0x00007f3c5ff39515 g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x1a515)
#13 0x00007f3c5ff33210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#14 0x00007f3c5ff612f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#15 0x000055f76194d2ee n/a (gnome-software + 0x282ee)
#16 0x00007f3c6009e8ce n/a (libgio-2.0.so.0 + 0x11e8ce)
#17 0x00007f3c60083268 n/a (libgio-2.0.so.0 + 0x103268)
#18 0x00007f3c5fe2e53b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#19 0x00007f3c5fe8b219 n/a (libglib-2.0.so.0 + 0xb7219)
#20 0x00007f3c5fe2d1a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#21 0x00007f3c6005c3be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#22 0x000055f7619498d6 main (gnome-software + 0x248d6)
#23 0x00007f3c5f045850 n/a (libc.so.6 + 0x23850)
#24 0x00007f3c5f04590a __libc_start_main (libc.so.6 + 0x2390a)
#25 0x000055f7619499b5 _start (gnome-software + 0x249b5)
Stack trace of thread 5767:
#0 0x00007f3c5f11fc0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007f3c5fe8b17f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007f3c5fe2d1a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007f3c6029702f n/a (libgnomesoftware.so.20 + 0x6902f)
#4 0x00007f3c5fe5b315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007f3c5f0a944b n/a (libc.so.6 + 0x8744b)
#6 0x00007f3c5f12ce40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 5661:
#2 0x00007f3c5fe2dc7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007f3c6008ed3c n/a (libgio-2.0.so.0 + 0x10ed3c)
Stack trace of thread 5688:
#3 0x00007f3c58501fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 5654:
#0 0x00007f3c5f1252ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007f3c5fe847b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007f3c5fdf8fb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007f3c5fe5ff9e n/a (libglib-2.0.so.0 + 0x8bf9e)
Stack trace of thread 5655:
#3 0x00007f3c5fe2d1f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 5765:
Stack trace of thread 5760:
#1 0x00007f3c5fe84d03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007f3c5fdf8f83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007f3c5fe609fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Stack trace of thread 5766:
Stack trace of thread 5768:
Stack trace of thread 5741:
#0 0x00007f3c5f750507 n/a (libgtk-4.so.1 + 0x154507)
#1 0x00007f3c5f74656a n/a (libgtk-4.so.1 + 0x14a56a)
#2 0x00007f3c5f7465f6 n/a (libgtk-4.so.1 + 0x14a5f6)
#3 0x00007f3c5fa804ef n/a (libgtk-4.so.1 + 0x4844ef)
#4 0x00007f3c5f7451d6 n/a (libgtk-4.so.1 + 0x1491d6)
#5 0x00007f3c6002c21c n/a (libgio-2.0.so.0 + 0xac21c)
#6 0x00007f3c5fe609a3 n/a (libglib-2.0.so.0 + 0x8c9a3)
#7 0x00007f3c5fe5b315 n/a (libglib-2.0.so.0 + 0x87315)
#8 0x00007f3c5f0a944b n/a (libc.so.6 + 0x8744b)
#9 0x00007f3c5f12ce40 n/a (libc.so.6 + 0x10ae40)
Jun 04 19:47:21 issun gnome-software[5991]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 04 19:47:22 issun systemd-coredump[6124]: Process 5991 (gnome-software) of user 1000 dumped core.
Stack trace of thread 5991:
#0 0x00007fc3e5218408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007fc3e5218703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007fc3e5218975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007fc3e5218c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007fc3e544f00a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007fc3e5453e8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007fc3e5455230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x000055c98a7b8670 gs_shell_get_query_license_type (gnome-software + 0x6e670)
#8 0x000055c98a7a6b25 n/a (gnome-software + 0x5cb25)
#9 0x00007fc3e5319210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#10 0x00007fc3e53472f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#11 0x00007fc3e5337095 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32095)
#12 0x00007fc3e5337324 g_signal_emit (libgobject-2.0.so.0 + 0x32324)
#13 0x000055c98a793574 n/a (gnome-software + 0x49574)
#14 0x00007fc3e540e3f4 n/a (libgio-2.0.so.0 + 0xa83f4)
#15 0x00007fc3e541208d n/a (libgio-2.0.so.0 + 0xac08d)
#16 0x00007fc3e5677edd n/a (libgnomesoftware.so.20 + 0x63edd)
#17 0x00007fc3e540e3f4 n/a (libgio-2.0.so.0 + 0xa83f4)
#18 0x00007fc3e541208d n/a (libgio-2.0.so.0 + 0xac08d)
#19 0x00007fc3e566b121 n/a (libgnomesoftware.so.20 + 0x57121)
#20 0x00007fc3e566f7da n/a (libgnomesoftware.so.20 + 0x5b7da)
#21 0x00007fc3e540e3f4 n/a (libgio-2.0.so.0 + 0xa83f4)
#22 0x00007fc3e540e42d n/a (libgio-2.0.so.0 + 0xa842d)
#23 0x00007fc3e521453b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#24 0x00007fc3e5271219 n/a (libglib-2.0.so.0 + 0xb7219)
#25 0x00007fc3e52131a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#26 0x00007fc3e54423be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#27 0x000055c98a76e8d6 main (gnome-software + 0x248d6)
#28 0x00007fc3e442b850 n/a (libc.so.6 + 0x23850)
#29 0x00007fc3e442b90a __libc_start_main (libc.so.6 + 0x2390a)
#30 0x000055c98a76e9b5 _start (gnome-software + 0x249b5)
Stack trace of thread 6094:
#0 0x00007fc3e4505c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007fc3e527117f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007fc3e52131a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007fc3e567d02f n/a (libgnomesoftware.so.20 + 0x6902f)
#4 0x00007fc3e5241315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007fc3e448f44b n/a (libc.so.6 + 0x8744b)
#6 0x00007fc3e4512e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6075:
#0 0x00007fc3e51ff932 n/a (libglib-2.0.so.0 + 0x45932)
#1 0x00007fc3e5200568 g_hash_table_insert (libglib-2.0.so.0 + 0x46568)
#2 0x00007fc3e4e77f22 n/a (libgtk-4.so.1 + 0x495f22)
#3 0x00007fc3e4b3662a n/a (libgtk-4.so.1 + 0x15462a)
#4 0x00007fc3e4b2c56a n/a (libgtk-4.so.1 + 0x14a56a)
#5 0x00007fc3e4b2c5f6 n/a (libgtk-4.so.1 + 0x14a5f6)
#6 0x00007fc3e4e664ef n/a (libgtk-4.so.1 + 0x4844ef)
#7 0x00007fc3e4b2b1d6 n/a (libgtk-4.so.1 + 0x1491d6)
#8 0x00007fc3e541221c n/a (libgio-2.0.so.0 + 0xac21c)
#9 0x00007fc3e52469a3 n/a (libglib-2.0.so.0 + 0x8c9a3)
#10 0x00007fc3e5241315 n/a (libglib-2.0.so.0 + 0x87315)
#11 0x00007fc3e448f44b n/a (libc.so.6 + 0x8744b)
#12 0x00007fc3e4512e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6030:
#2 0x00007fc3e5213c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007fc3e5474d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
Stack trace of thread 6022:
#3 0x00007fc3e52131f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 6095:
Stack trace of thread 6054:
#3 0x00007fc3dd8e7fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 6021:
#0 0x00007fc3e450b2ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007fc3e526a7b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007fc3e51defb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007fc3e5245f9e n/a (libglib-2.0.so.0 + 0x8bf9e)
Stack trace of thread 6086:
#1 0x00007fc3e526ad03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007fc3e51def83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007fc3e52469fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Stack trace of thread 6091:
Stack trace of thread 6093:
Jun 04 19:47:24 issun gnome-software[6203]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 04 19:47:24 issun systemd-coredump[6228]: Process 6203 (gnome-software) of user 1000 dumped core.
Stack trace of thread 6203:
#0 0x00007fb5b277c408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007fb5b277c703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007fb5b277c975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007fb5b277cc64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007fb5b29b300a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007fb5b29b7e8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007fb5b29b9230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x000056216871868b n/a (gnome-software + 0x6b68b)
#8 0x00005621687188ea n/a (gnome-software + 0x6b8ea)
#9 0x00007fb5b139d4f6 n/a (libffi.so.8 + 0x74f6)
#10 0x00007fb5b1399f5e n/a (libffi.so.8 + 0x3f5e)
#11 0x00007fb5b139cb73 ffi_call (libffi.so.8 + 0x6b73)
#12 0x00007fb5b2883515 g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x1a515)
#13 0x00007fb5b287d210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#14 0x00007fb5b28ab2f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#15 0x00005621686d52ee n/a (gnome-software + 0x282ee)
#16 0x00007fb5b29e88ce n/a (libgio-2.0.so.0 + 0x11e8ce)
#17 0x00007fb5b29cd268 n/a (libgio-2.0.so.0 + 0x103268)
#18 0x00007fb5b277853b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#19 0x00007fb5b27d5219 n/a (libglib-2.0.so.0 + 0xb7219)
#20 0x00007fb5b27771a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#21 0x00007fb5b29a63be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#22 0x00005621686d18d6 main (gnome-software + 0x248d6)
#23 0x00007fb5b198f850 n/a (libc.so.6 + 0x23850)
#24 0x00007fb5b198f90a __libc_start_main (libc.so.6 + 0x2390a)
#25 0x00005621686d19b5 _start (gnome-software + 0x249b5)
Stack trace of thread 6207:
#0 0x00007fb5b1a69c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007fb5b27d517f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007fb5b27771a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007fb5b27771f2 n/a (libglib-2.0.so.0 + 0x591f2)
#4 0x00007fb5b27a5315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007fb5b19f344b n/a (libc.so.6 + 0x8744b)
#6 0x00007fb5b1a76e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6218:
#3 0x00007fb5ac035fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 6208:
#2 0x00007fb5b2777c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007fb5b29d8d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
Stack trace of thread 6206:
#0 0x00007fb5b1a6f2ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007fb5b27ce7b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007fb5b2742fb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007fb5b27a9f9e n/a (libglib-2.0.so.0 + 0x8bf9e)
Stack trace of thread 6222:
#1 0x00007fb5b27ced03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007fb5b2742f83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007fb5b27aa9fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Jun 04 19:47:28 issun gnome-software[6241]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 04 19:47:28 issun systemd-coredump[6280]: Process 6241 (gnome-software) of user 1000 dumped core.
Stack trace of thread 6241:
#0 0x00007fcaf0738408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007fcaf0738703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007fcaf0738975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007fcaf0738c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007fcaf096f00a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007fcaf0973e8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007fcaf0975230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x000055d2973a668b n/a (gnome-software + 0x6b68b)
#8 0x000055d2973a689a n/a (gnome-software + 0x6b89a)
#9 0x00007fcaef3594f6 n/a (libffi.so.8 + 0x74f6)
#10 0x00007fcaef355f5e n/a (libffi.so.8 + 0x3f5e)
#11 0x00007fcaef358b73 ffi_call (libffi.so.8 + 0x6b73)
#12 0x00007fcaf083f515 g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x1a515)
#13 0x00007fcaf0839210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#14 0x00007fcaf08672f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#15 0x000055d2973632ee n/a (gnome-software + 0x282ee)
#16 0x00007fcaf09a48ce n/a (libgio-2.0.so.0 + 0x11e8ce)
#17 0x00007fcaf0989268 n/a (libgio-2.0.so.0 + 0x103268)
#18 0x00007fcaf073453b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#19 0x00007fcaf0791219 n/a (libglib-2.0.so.0 + 0xb7219)
#20 0x00007fcaf07331a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#21 0x00007fcaf09623be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#22 0x000055d29735f8d6 main (gnome-software + 0x248d6)
#23 0x00007fcaef94b850 n/a (libc.so.6 + 0x23850)
#24 0x00007fcaef94b90a __libc_start_main (libc.so.6 + 0x2390a)
#25 0x000055d29735f9b5 _start (gnome-software + 0x249b5)
Stack trace of thread 6252:
#0 0x00007fcaf071fcf0 g_str_equal (libglib-2.0.so.0 + 0x45cf0)
#1 0x00007fcaf0720af2 g_hash_table_remove (libglib-2.0.so.0 + 0x46af2)
#2 0x00007fcaf07876ab g_variant_type_info_unref (libglib-2.0.so.0 + 0xad6ab)
#3 0x00007fcaf07785e3 g_variant_unref (libglib-2.0.so.0 + 0x9e5e3)
#4 0x00007fcaf098ba36 n/a (libgio-2.0.so.0 + 0x105a36)
#5 0x00007fcaf08474a4 g_object_unref (libgobject-2.0.so.0 + 0x224a4)
#6 0x00007fcaf099e557 n/a (libgio-2.0.so.0 + 0x118557)
#7 0x00007fcaf092e3f4 n/a (libgio-2.0.so.0 + 0xa83f4)
#8 0x00007fcaf092e42d n/a (libgio-2.0.so.0 + 0xa842d)
#9 0x00007fcaf073453b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#10 0x00007fcaf0791219 n/a (libglib-2.0.so.0 + 0xb7219)
#11 0x00007fcaf0733c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#12 0x00007fcaf0994d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
#13 0x00007fcaf0761315 n/a (libglib-2.0.so.0 + 0x87315)
#14 0x00007fcaef9af44b n/a (libc.so.6 + 0x8744b)
#15 0x00007fcaefa32e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6250:
#0 0x00007fcaefa2b2ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007fcaf078a7b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007fcaf06fefb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007fcaf0765f9e n/a (libglib-2.0.so.0 + 0x8bf9e)
#4 0x00007fcaf0761315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007fcaef9af44b n/a (libc.so.6 + 0x8744b)
#6 0x00007fcaefa32e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6263:
#1 0x00007fcaf078ad03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007fcaf06fef83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007fcaf07669fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Stack trace of thread 6259:
#0 0x00007fcaefa25c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007fcaf079117f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007fcaf07331a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007fcae93f4fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 6251:
#3 0x00007fcaf07331f2 n/a (libglib-2.0.so.0 + 0x591f2)
Jun 04 19:47:29 issun gnome-software[6314]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 04 19:47:29 issun systemd-coredump[6345]: Process 6314 (gnome-software) of user 1000 dumped core.
Stack trace of thread 6314:
#0 0x00007f94ff880408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007f94ff880703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007f94ff880975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007f94ff880c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007f94ffab700a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007f94ffabbe8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007f94ffabd230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x0000557690e4568b n/a (gnome-software + 0x6b68b)
#8 0x0000557690e458ea n/a (gnome-software + 0x6b8ea)
#9 0x00007f94fe4a14f6 n/a (libffi.so.8 + 0x74f6)
#10 0x00007f94fe49df5e n/a (libffi.so.8 + 0x3f5e)
#11 0x00007f94fe4a0b73 ffi_call (libffi.so.8 + 0x6b73)
#12 0x00007f94ff987515 g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x1a515)
#13 0x00007f94ff981210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#14 0x00007f94ff9af2f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#15 0x0000557690e022ee n/a (gnome-software + 0x282ee)
#16 0x00007f94ffaec8ce n/a (libgio-2.0.so.0 + 0x11e8ce)
#17 0x00007f94ffad1268 n/a (libgio-2.0.so.0 + 0x103268)
#18 0x00007f94ff87c53b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#19 0x00007f94ff8d9219 n/a (libglib-2.0.so.0 + 0xb7219)
#20 0x00007f94ff87b1a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#21 0x00007f94ffaaa3be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#22 0x0000557690dfe8d6 main (gnome-software + 0x248d6)
#23 0x00007f94fea93850 n/a (libc.so.6 + 0x23850)
#24 0x00007f94fea9390a __libc_start_main (libc.so.6 + 0x2390a)
#25 0x0000557690dfe9b5 _start (gnome-software + 0x249b5)
Stack trace of thread 6322:
#0 0x00007f94feb732ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007f94ff8d27b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007f94ff846fb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007f94ff8adf9e n/a (libglib-2.0.so.0 + 0x8bf9e)
#4 0x00007f94ff8a9315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007f94feaf744b n/a (libc.so.6 + 0x8744b)
#6 0x00007f94feb7ae40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6327:
#0 0x00007f94feb6dc0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007f94ff8d917f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007f94ff87b1a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007f94f8750fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 6323:
#3 0x00007f94ff87b1f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 6324:
#2 0x00007f94ff87bc7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007f94ffadcd3c n/a (libgio-2.0.so.0 + 0x10ed3c)
Stack trace of thread 6328:
#1 0x00007f94ff8d2d03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007f94ff846f83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007f94ff8ae9fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Jun 04 19:47:32 issun gnome-software[6361]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 04 19:47:33 issun systemd-coredump[6451]: Process 6361 (gnome-software) of user 1000 dumped core.
Stack trace of thread 6361:
#0 0x00007fc28d6f5408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007fc28d6f5703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007fc28d6f5975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007fc28d6f5c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007fc28d92c00a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007fc28d930e8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007fc28d932230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x0000557f44e9e68b n/a (gnome-software + 0x6b68b)
#8 0x0000557f44e9e89a n/a (gnome-software + 0x6b89a)
#9 0x00007fc28c3164f6 n/a (libffi.so.8 + 0x74f6)
#10 0x00007fc28c312f5e n/a (libffi.so.8 + 0x3f5e)
#11 0x00007fc28c315b73 ffi_call (libffi.so.8 + 0x6b73)
#12 0x00007fc28d7fc515 g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x1a515)
#13 0x00007fc28d7f6210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#14 0x00007fc28d8242f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#15 0x0000557f44e5b2ee n/a (gnome-software + 0x282ee)
#16 0x00007fc28d9618ce n/a (libgio-2.0.so.0 + 0x11e8ce)
#17 0x00007fc28d946268 n/a (libgio-2.0.so.0 + 0x103268)
#18 0x00007fc28d6f153b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#19 0x00007fc28d74e219 n/a (libglib-2.0.so.0 + 0xb7219)
#20 0x00007fc28d6f01a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#21 0x00007fc28d91f3be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#22 0x0000557f44e578d6 main (gnome-software + 0x248d6)
#23 0x00007fc28c908850 n/a (libc.so.6 + 0x23850)
#24 0x00007fc28c90890a __libc_start_main (libc.so.6 + 0x2390a)
#25 0x0000557f44e579b5 _start (gnome-software + 0x249b5)
Stack trace of thread 6384:
#0 0x00007fc28c9e82ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007fc28d7477b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007fc28d6bbfb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007fc28d722f9e n/a (libglib-2.0.so.0 + 0x8bf9e)
#4 0x00007fc28d71e315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007fc28c96c44b n/a (libc.so.6 + 0x8744b)
#6 0x00007fc28c9efe40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6389:
#0 0x00007fc28c9e2c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007fc28d74e17f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007fc28d6f01a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007fc285bb0fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 6394:
#1 0x00007fc28d747d03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007fc28d6bbf83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007fc28d7239fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Stack trace of thread 6385:
#3 0x00007fc28d6f01f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 6386:
#2 0x00007fc28d6f0c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007fc28d951d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
Jun 04 19:47:34 issun gnome-software[6535]: Settings schema 'org.gnome.software' does not contain a key named 'show-only-free-apps'
Jun 04 19:47:35 issun systemd-coredump[6586]: Process 6535 (gnome-software) of user 1000 dumped core.
Stack trace of thread 6535:
#0 0x00007f1340359408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#1 0x00007f1340359703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#2 0x00007f1340359975 g_logv (libglib-2.0.so.0 + 0x5e975)
#3 0x00007f1340359c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#4 0x00007f134059000a n/a (libgio-2.0.so.0 + 0xe900a)
#5 0x00007f1340594e8d g_settings_get_value (libgio-2.0.so.0 + 0xede8d)
#6 0x00007f1340596230 g_settings_get_boolean (libgio-2.0.so.0 + 0xef230)
#7 0x00005628ab1f968b n/a (gnome-software + 0x6b68b)
#8 0x00005628ab1f98ea n/a (gnome-software + 0x6b8ea)
#9 0x00007f133ef7a4f6 n/a (libffi.so.8 + 0x74f6)
#10 0x00007f133ef76f5e n/a (libffi.so.8 + 0x3f5e)
#11 0x00007f133ef79b73 ffi_call (libffi.so.8 + 0x6b73)
#12 0x00007f1340460515 g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x1a515)
#13 0x00007f134045a210 g_closure_invoke (libgobject-2.0.so.0 + 0x14210)
#14 0x00007f13404882f8 n/a (libgobject-2.0.so.0 + 0x422f8)
#15 0x00005628ab1b62ee n/a (gnome-software + 0x282ee)
#16 0x00007f13405c58ce n/a (libgio-2.0.so.0 + 0x11e8ce)
#17 0x00007f13405aa268 n/a (libgio-2.0.so.0 + 0x103268)
#18 0x00007f134035553b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#19 0x00007f13403b2219 n/a (libglib-2.0.so.0 + 0xb7219)
#20 0x00007f13403541a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#21 0x00007f13405833be g_application_run (libgio-2.0.so.0 + 0xdc3be)
#22 0x00005628ab1b28d6 main (gnome-software + 0x248d6)
#23 0x00007f133f56c850 n/a (libc.so.6 + 0x23850)
#24 0x00007f133f56c90a __libc_start_main (libc.so.6 + 0x2390a)
#25 0x00005628ab1b29b5 _start (gnome-software + 0x249b5)
Stack trace of thread 6543:
#0 0x00007f133f64c2ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007f13403ab7b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007f134031ffb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007f1340386f9e n/a (libglib-2.0.so.0 + 0x8bf9e)
#4 0x00007f1340382315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007f133f5d044b n/a (libc.so.6 + 0x8744b)
#6 0x00007f133f653e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 6547:
#0 0x00007f133f646c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007f13403b217f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007f13403541a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007f133912bfde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 6551:
#1 0x00007f13403abd03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007f134031ff83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007f13403879fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Stack trace of thread 6544:
#3 0x00007f13403541f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 6545:
#2 0x00007f1340354c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007f13405b5d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
I’ve tried resetting the resume device parameter to my swap part, but I don’t know what else I can do. Sometimes when I try to resume, I get no backlight, sometimes I get a backlight and no image, and other times, the screen graphics will be garbled and the screen will turn off again. In all the above cases I have to longpress the power button to restart. I just want to be able to close my laptop’s lid and suspend/resume normally,
