Consistent freeze on Linux
First time posting here and I don’t have much experience with Linux. To be honest it’s my first time writing on a forum so i’m sorry for bad formatting and bold statements/assumptions.
I want to run a dual boot configuration on my Dell Latitude 7480 with win 10 and linux however no matter what distro i choose (tried Ubuntu 22.04 LTS, PopOs and Manjaro) I manage to boot into linux but after a while the system completely freezes, the cursor doesn’t move and the caps lock led blinks. Win 10 works fine.
I installed win 10 first (partition table below), updated drivers and flashed manjaro with rufus in DD mode on my usb drive (there were compatibility issues rufus said). Successfully installed Manjaro and updated 2.0 GiB worth of apps and packages + updated kernel from 5.15.125 to 6.1.44 with few warnings (pics below related). After 30-60 mins came the first freeze and from that point I couldn’t get as far as few seconds after logging in before totally freezing. Tried to boot in fallback initramfs in both kernel versions but the problem persisted. On Ubuntu I once booted in recovery mode an all seemed to work fine but the system was stripped to the bone.
Moderator edit: Removed useless pictures.
Tried to install Manjaro on a totally clean disk but nothing changed from what happened in the paragraph above. At this point the culprit must be the BIOS or hardware incompatibilities (by the way i’m using GRUB 2.06.r261.g2f4430cc0-3) but I contacted a couple of Latitude 7480 users and their device worked smoothly on Ubuntu (their laptop came preinstalled with Ubuntu)
For now that’s all comes to mind. thanks for your time!
Edit:
provided log
  Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=acb7d180-c28e-4681-a549-032e9e43bff1 rw quiet apparmor=1
    security=apparmor udev.log_priority=3 processor.max_cstate=1
    intel_idle.max_cstate=0 i915.enable_dc=0
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Dell product: Latitude 7480 v: N/A
  Mobo: Dell model: 021PX9 v: A00 serial: <superuser required> UEFI: Dell
    v: 1.32.1 date: 07/05/2023
  ID-1: BAT0 charge: 19.7 Wh (38.3%) condition: 51.4/53.3 Wh (96.4%) volts: 7.5
    min: 7.4 model: LGC-LGC7.78 DELL 2X39G type: Li-ion serial: <filter>
    status: charging
  System RAM: total: 32 GiB available: 31.23 GiB used: 2.46 GiB (7.9%)
  Info: model: Intel Core i7-7600U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
    family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF4
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 747 high: 789 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 722 2: 714 3: 789 4: 764
    bogomips: 23209
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:6715
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: eDP-1 model: LG Display 0x0543 built: 2016 res: 2560x1440 hz: 60
    dpi: 210 gamma: 1.2 size: 310x174mm (12.2x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 2560x1440
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_skl
    bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.77 status: off tools: pw-cli
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 953.87 GiB used: 14.19 GiB (1.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HALR-000L7
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5L2QEXA7 temp: 35.9 C
    scheme: GPT
  ID-1: / raw-size: 244.03 GiB size: 239.14 GiB (98.00%) used: 14.16 GiB (5.9%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: acb7d180-c28e-4681-a549-032e9e43bff1
    used: 25.3 MiB (26.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: ACA2-187C
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 709.22 GiB fs: ntfs label: N/A
    uuid: 5C72AC0272ABDED0
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 522 MiB fs: ntfs label: N/A
    uuid: 961ECB3A1ECB1263
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Microdia Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:6715 class-ID: 0e02
  Device-2: 1-7:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Device-3: 1-8:4 info: Elan Micro Touchscreen type: HID
    driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
    chip-ID: 04f3:22d8 class-ID: 0300
  Device-4: 1-10:5 info: Broadcom 5880 type: smart card driver: N/A
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0a5c:5832 class-ID: 0b00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 53.0 C pch: 49.0 C mobo: 51.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 209 Uptime: 2m wakeups: 4255 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1159 libs: 351 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.29
type or paste code here
Hello @Rosenlied :wink:
That sounds like an issue with “low power mode” of the CPU or the iGPU. Maybe the RAM is defect?
However… you can limit the CPU and iGPU to certain cstates.
processor.max_cstate=1 intel_idle.max_cstate=0  i915.enable_dc=0
That are kernel parameters, which needs to be applied on boot time. That ensures, that the CPU/GPU will never go into sleep mode. See if freezes appear when this is applied (of course it will drain more battery and should only be used for testing here.)
  • Grub Boot Menu (when you boot the computer): Press E when the menu shows up and add them on the line which starts with linux . [temorary]
  • Grub Config: Edit /etc/default/grub and append the kernel parameters between the quotes in the GRUB_CMDLINE_LINUX_DEFAULT line and run sudo update-grub. [permanent]
That would be my first attempt to try fixing a freeze. It could also just that the Desktop Environment (KDE,GNOME,XFCE, etc) is just too much for your GPU/CPU, especially the OpenGL effects, but I guess that shouldn’t be the case here, since it comes with W10.
If possible please provide some substantial system information:
inxi -v7azy
Thanks.
Dell Latitude 7280/7380/7480 System BIOS version: 1.32.1
Status: Critical Date: 09 Aug 2023
https://www.dell.com/support/home/en-uk/product-support/product/latitude-14-7480-laptop/drivers .
Do you use swap ?
What kernel do you use ?
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Thanks megavolt for replying!
I just tried your fix and managed to break the 4-seconds-barrier but i’ll wait a bit before declaring victory, Thanks again for the support!
i already updated the bios to that date, so it should be working fine(?)
Thanks for the reply!
