Consistent crashing
Hello Manjaro Forums!
I’m pretty new to all of this Linux stuff. i was honestly tired of having a company have my OS on a leash so i starting trying Linux. i started first with mint and had crashing problems that were not present on windows so instead i changed OS again. The problem however still persists so any help will be greatly appreciated. Below are some specs i could pull up and crash logs.
System specs:
  Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=7f884a41-bccd-45fe-bfb3-037a35e89719 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Convertible System: HP product: HP Envy x360 2-in-1 Laptop 15-fh0xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 8BE9 v: 75.40 serial: <superuser required>
    part-nu: 7H1T1UA#ABA uuid: <superuser required> UEFI: Insyde v: F.08
    date: 04/29/2024
  ID-1: BAT1 charge: 53.7 Wh (100.0%) condition: 53.7/55.7 Wh (96.5%)
    volts: 17.1 min: 15.0 model: Hewlett-Packard PABAS0241231 type: Li-ion
    serial: <filter> status: full
  System RAM: total: 16 GiB available: 14.94 GiB used: 3.13 GiB (21.0%)
  Device-1: Bottom - on board type: LPDDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 4266 MT/s volts: min: 0.6 max: 0.6
    width (bits): data: 32 total: 32 manufacturer: Samsung
    part-no: K4UBE3D4AB-MGCL serial: N/A
  Device-2: Bottom - on board type: LPDDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA50000F
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1924 min/max: 400/4546 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1924 2: 1924 3: 1924
    4: 1924 5: 1924 6: 1924 7: 1924 8: 1924 9: 1924 10: 1924 11: 1924 12: 1924
    13: 1924 14: 1924 15: 1924 16: 1924 bogomips: 63919
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Hewlett-Packard
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 04:00.0 chip-ID: 1002:15e7 class-ID: 0300 temp: 36.0 C
  Device-2: Luxvisions Innotech HP Wide Vision 5MP Camera
    driver: hid-sensor-hub,usbhid,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 30c9:00ab class-ID: fe01
    serial: <filter>
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x3da3 built: 2021
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.576 y: 0.345
    green: x: 0.345 y: 0.573 blue: x: 0.157 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 18.1.8 DRM 3.59 6.11.10-2-MANJARO) device-ID: 1002:15e7
    memory: 500 MiB unified: no
  API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.8-arch1.1
    device-ID: 1002:15e7 surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Logitech Blue Microphones
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 046d:0ab7 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
    vendor: Hewlett-Packard driver: rtw89_8852ce v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c852
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 0bda:c85c
  Local Storage: total: 476.94 GiB used: 232.23 GiB (48.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HP02AN00 temp: 22.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 232.23 GiB (49.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 7f884a41-bccd-45fe-bfb3-037a35e89719
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 6B57-5274
  Device-1: 1-2:2 info: Razer USA Basilisk V3 type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0099 class-ID: 0300
  Device-2: 1-3:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
    interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0bda:c85c class-ID: e001 serial: <filter>
  Device-3: 1-4:4 info: Luxvisions Innotech HP Wide Vision 5MP Camera
    type: video,HID driver: hid-sensor-hub,usbhid,uvcvideo interfaces: 6 rev: 2.0
    chip-ID: 30c9:00ab class-ID: fe01 serial: <filter>
  Device-1: 3-2:3 info: Logitech Blue Microphones type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    chip-ID: 046d:0ab7 class-ID: 0300 serial: <filter>
  System Temperatures: cpu: 44.1 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (rpm): N/A
  Packages: 1371 pm: pacman pkgs: 1355 libs: 456 tools: pamac,yay pm: flatpak
    pkgs: 16
    1: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    2: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    4: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    6: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 355
  1: cpu: 19.7% command: vesktop.bin pid: 1705 mem: 557.0 MiB (3.6%)
  2: cpu: 13.5% command: brave pid: 2632 mem: 218.0 MiB (1.4%)
  3: cpu: 3.9% command: vesktop.bin pid: 1729 mem: 87.1 MiB (0.5%)
  4: cpu: 2.3% command: brave pid: 1889 mem: 250.0 MiB (1.6%)
  5: cpu: 2.0% command: brave pid: 1837 mem: 238.8 MiB (1.5%)
  Memory top: 5 of 355
  1: mem: 557.0 MiB (3.6%) command: vesktop.bin pid: 1705 cpu: 19.7%
  2: mem: 373.4 MiB (2.4%) coDec 06 13:05:22 robin-envy kernel: hid-generic 0003:1532:0099.0005: No inputs registered, leaving
Dec 06 13:05:22 robin-envy kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1421: comm mount: bad orphan inode 25428804
Dec 06 13:05:22 robin-envy kernel: ext4_test_bit(bit=835, block=101711888) = 0
Dec 06 13:05:22 robin-envy kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1421: comm mount: bad orphan inode 25428762
Dec 06 13:05:22 robin-envy kernel: ext4_test_bit(bit=793, block=101711888) = 0
Dec 06 13:05:23 robin-envy kernel: rtw89_8852ce 0000:01:00.0: MAC has already powered on
Dec 06 13:05:25 robin-envy kernel: amdgpu 0000:04:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Dec 06 13:05:57 robin-envy pipewire[1064]: spa.alsa: front:3c: snd_pcm_drop: No such device
Dec 06 13:05:57 robin-envy pipewire[1064]: spa.alsa: front:3p: snd_pcm_drop: No such device
mmand: brave pid: 1761 cpu: 1.9%
  3: mem: 342.4 MiB (2.2%) command: plasmashell pid: 1064 cpu: 0.6%
  4: mem: 252.2 MiB (1.6%) command: brave pid: 2067 cpu: 1.4%
  5: mem: 250.0 MiB (1.6%) command: brave pid: 1889 cpu: 2.3%
  Processes: 355 Power: uptime: 9m states: freeze,mem,disk suspend: s2idle
    image: 5.95 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
Crash logs pulled from earlier boot crash (Used “journalctl --boot=-1 --priority=3 --catalog --no-pager” to acquire)
again any help will be appreciated since part of my livelihood depends on this laptop. thank you!
Edit:thanks for the help hopefully this is more insightfull
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
sudo inxi --verbosity=8 --filter --width
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
    Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Welcome to the Manjaro community.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
