Connection problems with one router
At my workplace wifi works ok. But at home, it simply cannot connect to my ISP provided router. Other devices can connect and use that. Using plasma, if that matters
mhwd-kernel -li
Currently running: 6.12.62-1-MANJARO (linux612)
   * linux612
mhwd -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
inxi -Nxxx
    vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: 7000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: speed: 5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
Journalctl output when trying to connect to One-962B' and then switching back to pihentagy:
dec 21 23:30:19 powerplant NetworkManager[728]: <info>  [1766356219.9128] audit: op="statistics" interface="wlp2s0" ifindex=3 args="2000" pid=1166 uid=1000 result="success"
dec 21 23:30:19 powerplant kded6[1111]: Failed to notify "Created too many similar notifications in quick succession"
dec 21 23:30:27 powerplant systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
dec 21 23:30:28 powerplant wpa_supplicant[848]: wlp2s0: Reject scan trigger since one is already pending
dec 21 23:30:28 powerplant NetworkManager[728]: <info>  [1766356228.4402] manager: NetworkManager state is now CONNECTED_GLOBAL
dec 21 23:30:28 powerplant systemd[1]: Starting Network Manager Script Dispatcher Service...
dec 21 23:30:28 powerplant systemd[1]: Started Network Manager Script Dispatcher Service.
dec 21 23:30:35 powerplant geoclue[1011]: Failed to query location: Query location SOUP error: Unknown Error
dec 21 23:30:38 powerplant systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
dec 21 23:30:42 powerplant geoclue[1011]: Failed to query location: Query location SOUP error: Unknown Error
dec 21 23:33:04 powerplant baloo_file_extractor[39656]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloo'")
dec 21 23:33:05 powerplant rtkit-daemon[1007]: Supervising 12 threads of 8 processes of 1 users.
dec 21 23:33:06 powerplant NetworkManager[728]: <info>  [1766356386.6500] audit: op="statistics" interface="wlp2s0" ifindex=3 args="2000" pid=1166 uid=1000 result="success"
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.0430] device (wlp2s0): disconnecting for new activation request.
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.0430] device (wlp2s0): state change: activated -> deactivating (reason 'new-activation', managed-type: 'full')
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.0435] audit: op="connection-activate" uuid="d4801cc6-4aac-4c36-99db-d9b4127c72e0" name="One-962B" pid=1166 uid=1000 result="success"
dec 21 23:33:09 powerplant systemd[1]: Starting Network Manager Script Dispatcher Service...
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.0578] audit: op="statistics" interface="wlp2s0" ifindex=3 args="0" pid=1166 uid=1000 result="success"
dec 21 23:33:09 powerplant systemd[1]: Started Network Manager Script Dispatcher Service.
dec 21 23:33:09 powerplant kernel: wlp2s0: deauthenticating from 94:0c:6d:a9:fc:de by local choice (Reason: 3=DEAUTH_LEAVING)
dec 21 23:33:09 powerplant wpa_supplicant[848]: nl80211: send_event_marker failed: Source based routing not supported
dec 21 23:33:09 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=94:0c:6d:a9:fc:de reason=3 locally_generated=1
dec 21 23:33:09 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
dec 21 23:33:09 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.5114] device (wlp2s0): supplicant interface state: completed -> disconnected
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.5114] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> disconnected
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.5115] device (wlp2s0): state change: deactivating -> disconnected (reason 'new-activation', managed-type: 'full')
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.5117] dhcp4 (wlp2s0): canceled DHCP transaction
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.5117] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.5117] dhcp4 (wlp2s0): state changed no lease
dec 21 23:33:09 powerplant geoclue[1011]: Failed to query location: Could not connect to www.googleapis.com: Network is unreachable
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.6686] device (wlp2s0): set-hw-addr: set MAC address to 52:24:46:A9:F0:0B (scanning)
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.7396] device (wlp2s0): Activation: starting connection 'One-962B' (d4801cc6-4aac-4c36-99db-d9b4127c72e0)
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.7403] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.7403] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> interface_disabled
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.7406] device (wlp2s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.7407] manager: NetworkManager state is now CONNECTING
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8083] device (wlp2s0): set-hw-addr: reset MAC address to F4:4E:B4:8D:32:FB (preserve)
dec 21 23:33:09 powerplant geoclue[1011]: WiFi scan failed
dec 21 23:33:09 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-SCAN-FAILED ret=-100
dec 21 23:33:09 powerplant kded6[1111]: Failed to notify "Created too many similar notifications in quick succession"
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8715] device (wlp2s0): state change: prepare -> config (reason 'none', managed-type: 'full')
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8717] device (wlp2s0): Activation: (wifi) access point 'One-962B' has security, but secrets are required.
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8717] device (wlp2s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8718] sup-iface[32d342aade0a6b3f,2,wlp2s0]: wps: type pbc start...
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8789] device (wlp2s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8790] device (wlp2s0): state change: prepare -> config (reason 'none', managed-type: 'full')
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8791] device (wlp2s0): Activation: (wifi) connection 'One-962B' has security, and secrets exist.  No new secrets needed.
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8791] Config: added 'ssid' value 'One-962B'
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8791] Config: added 'scan_ssid' value '1'
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8791] Config: added 'bgscan' value 'simple:30:-70:86400'
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8791] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.8791] Config: added 'psk' value '<hidden>'
dec 21 23:33:09 powerplant wpa_supplicant[848]: wlp2s0: WPS-CANCEL
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.9161] device (wlp2s0): supplicant interface state: interface_disabled -> disconnected
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.9161] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> disconnected
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.9237] device (wlp2s0): supplicant interface state: disconnected -> scanning
dec 21 23:33:09 powerplant NetworkManager[728]: <info>  [1766356389.9237] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
dec 21 23:33:10 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
dec 21 23:33:10 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-REGDOM-BEACON-HINT before freq=5200 max_tx_power=2000 no_ir=1
dec 21 23:33:10 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-REGDOM-BEACON-HINT after freq=5200 max_tx_power=2000
dec 21 23:33:11 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
dec 21 23:33:11 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-REGDOM-BEACON-HINT before freq=5240 max_tx_power=2000 no_ir=1
dec 21 23:33:11 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-REGDOM-BEACON-HINT after freq=5240 max_tx_power=2000
dec 21 23:33:19 powerplant systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
dec 21 23:33:30 powerplant wpa_supplicant[848]: wlp2s0: SME: Trying to authenticate with 90:5c:44:f6:e1:2b (SSID='One-962B' freq=2462 MHz)
dec 21 23:33:30 powerplant kernel: wlp2s0: authenticate with 90:5c:44:f6:e1:2b (local address=f4:4e:b4:8d:32:fb)
dec 21 23:33:30 powerplant NetworkManager[728]: <info>  [1766356410.6021] device (wlp2s0): supplicant interface state: scanning -> authenticating
dec 21 23:33:30 powerplant NetworkManager[728]: <info>  [1766356410.6021] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
dec 21 23:33:30 powerplant kernel: wlp2s0: send auth to 90:5c:44:f6:e1:2b (try 1/3)
dec 21 23:33:30 powerplant kernel: wlp2s0: send auth to 90:5c:44:f6:e1:2b (try 2/3)
dec 21 23:33:30 powerplant kernel: wlp2s0: send auth to 90:5c:44:f6:e1:2b (try 3/3)
dec 21 23:33:30 powerplant kernel: wlp2s0: authentication with 90:5c:44:f6:e1:2b timed out
dec 21 23:33:30 powerplant wpa_supplicant[848]: wlp2s0: Added BSSID 90:5c:44:f6:e1:2b into ignore list, ignoring for 10 seconds
dec 21 23:33:30 powerplant NetworkManager[728]: <info>  [1766356410.9968] device (wlp2s0): supplicant interface state: authenticating -> disconnected
dec 21 23:33:30 powerplant NetworkManager[728]: <info>  [1766356410.9968] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
dec 21 23:33:31 powerplant NetworkManager[728]: <info>  [1766356411.0970] device (wlp2s0): supplicant interface state: disconnected -> scanning
dec 21 23:33:31 powerplant NetworkManager[728]: <info>  [1766356411.0970] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.0373] device (wlp2s0): disconnecting for new activation request.
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.0374] device (wlp2s0): state change: config -> deactivating (reason 'new-activation', managed-type: 'full')
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.0374] manager: NetworkManager state is now CONNECTED_LOCAL
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.0377] audit: op="connection-activate" uuid="105928a3-683f-4996-8813-3f55ffd6d711" name="pihentagy" pid=1166 uid=1000 result="success"
dec 21 23:33:34 powerplant systemd[1]: Starting Network Manager Script Dispatcher Service...
dec 21 23:33:34 powerplant systemd[1]: Started Network Manager Script Dispatcher Service.
dec 21 23:33:34 powerplant NetworkManager[728]: <warn>  [1766356414.0882] device (wlp2s0): Deactivation failed: GDBus.Error:fi.w1.wpa_supplicant1.NotConnected: This interface is not connected
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.0882] device (wlp2s0): state change: deactivating -> disconnected (reason 'new-activation', managed-type: 'full')
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.2027] device (wlp2s0): set-hw-addr: set MAC address to C6:26:06:39:A8:E8 (scanning)
dec 21 23:33:34 powerplant wpa_supplicant[848]: wlp2s0: Removed BSSID 90:5c:44:f6:e1:2b from ignore list (clear)
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.2725] device (wlp2s0): Activation: starting connection 'pihentagy' (105928a3-683f-4996-8813-3f55ffd6d711)
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.2730] device (wlp2s0): supplicant interface state: scanning -> inactive
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.2730] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> inactive
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.2731] device (wlp2s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.2731] manager: NetworkManager state is now CONNECTING
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.3350] device (wlp2s0): set-hw-addr: reset MAC address to F4:4E:B4:8D:32:FB (preserve)
dec 21 23:33:34 powerplant kded6[1111]: Failed to notify "Created too many similar notifications in quick succession"
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.3982] device (wlp2s0): state change: prepare -> config (reason 'none', managed-type: 'full')
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.3984] device (wlp2s0): Activation: (wifi) access point 'pihentagy' has security, but secrets are required.
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.3984] device (wlp2s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.3988] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.3988] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4064] device (wlp2s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4065] device (wlp2s0): state change: prepare -> config (reason 'none', managed-type: 'full')
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4067] device (wlp2s0): Activation: (wifi) connection 'pihentagy' has security, and secrets exist.  No new secrets needed.
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4067] Config: added 'ssid' value 'pihentagy'
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4067] Config: added 'scan_ssid' value '1'
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4067] Config: added 'bgscan' value 'simple:30:-70:86400'
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4067] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4068] Config: added 'psk' value '<hidden>'
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4397] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.4397] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
dec 21 23:33:34 powerplant wpa_supplicant[848]: wlp2s0: SME: Trying to authenticate with 94:0c:6d:a9:fc:de (SSID='pihentagy' freq=2452 MHz)
dec 21 23:33:34 powerplant kernel: wlp2s0: authenticate with 94:0c:6d:a9:fc:de (local address=f4:4e:b4:8d:32:fb)
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.6956] device (wlp2s0): supplicant interface state: inactive -> authenticating
dec 21 23:33:34 powerplant kernel: wlp2s0: send auth to 94:0c:6d:a9:fc:de (try 1/3)
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.6956] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> authenticating
dec 21 23:33:34 powerplant wpa_supplicant[848]: wlp2s0: Trying to associate with 94:0c:6d:a9:fc:de (SSID='pihentagy' freq=2452 MHz)
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.7014] device (wlp2s0): supplicant interface state: authenticating -> associating
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.7015] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
dec 21 23:33:34 powerplant kernel: wlp2s0: authenticated
dec 21 23:33:34 powerplant kernel: wlp2s0: associate with 94:0c:6d:a9:fc:de (try 1/3)
dec 21 23:33:34 powerplant kernel: wlp2s0: RX AssocResp from 94:0c:6d:a9:fc:de (capab=0x431 status=0 aid=24)
dec 21 23:33:34 powerplant wpa_supplicant[848]: wlp2s0: Associated with 94:0c:6d:a9:fc:de
dec 21 23:33:34 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
dec 21 23:33:34 powerplant kernel: wlp2s0: associated
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.7431] device (wlp2s0): supplicant interface state: associating -> associated
dec 21 23:33:34 powerplant NetworkManager[728]: <info>  [1766356414.7432] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> associated
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.5417] device (wlp2s0): supplicant interface state: associated -> 4way_handshake
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.5417] device (p2p-dev-wlp2s0): supplicant management interface state: associated -> 4way_handshake
dec 21 23:33:35 powerplant wpa_supplicant[848]: wlp2s0: WPA: Key negotiation completed with 94:0c:6d:a9:fc:de [PTK=CCMP GTK=TKIP]
dec 21 23:33:35 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 94:0c:6d:a9:fc:de completed [id=0 id_str=]
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.6112] device (wlp2s0): supplicant interface state: 4way_handshake -> completed
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.6112] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "pihentagy"
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.6112] device (p2p-dev-wlp2s0): supplicant management interface state: 4way_handshake -> completed
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.6117] device (wlp2s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.6120] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.6202] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.111, acd pending
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.7823] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.111
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.7878] policy: set 'pihentagy' (wlp2s0) as default for IPv4 routing and DNS
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.7988] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.7996] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.7997] device (wlp2s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.7998] manager: NetworkManager state is now CONNECTED_SITE
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.8000] device (wlp2s0): Activation: successful, device activated.
dec 21 23:33:35 powerplant NetworkManager[728]: <info>  [1766356415.8182] audit: op="statistics" interface="wlp2s0" ifindex=3 args="2000" pid=1166 uid=1000 result="success"
dec 21 23:33:35 powerplant kded6[1111]: Failed to notify "Created too many similar notifications in quick succession"
dec 21 23:33:36 powerplant wpa_supplicant[848]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-71 noise=9999 txrate=36000
dec 21 23:33:37 powerplant NetworkManager[728]: <info>  [1766356417.5365] manager: NetworkManager state is now CONNECTED_GLOBAL
dec 21 23:33:38 powerplant geoclue[1011]: Failed to query location: Query location SOUP error: Unknown Error
Do you have any advice? Or can I provide more data to help me figure out what’s wrong?
thanks
Mod edit:- Corrected pre-formatted text presentation. No charge.
Please take care when copying/pasting text.
I’m in a similar situation - but I have a different WiFi card.
A very old (as old as the laptop itself) Intel Centrino Wireless-N 2230
The router/modem my provider gave me works just fine with every other device
and my laptop WiFi works just fine with every other device.
Just not with the Router/Cable Modem my provider gave me.
No amount of fiddling with the options in the router made it work.
My solution was and still is:
use a second router, connected by cable to the first one.
The upside is:
I can place it at a more ideal spot, more in the center instead of in the far corner of my place - better reception …
Some housekeeping.
Please avoid pasting garbage characters along with command output – I refer to anything similar to    ~  – all it takes is a little more care when selecting the text to copy.
Thanks.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a :crystal_ball: at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
Running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
I am thinking - check in the router setup.
The following is a guess…
I only know the following because I had the issue that I couldn’t use WPA3 because then my printer wouldn’t connect.
If the router is set to use WPA3 it will enforce PMF (Protected Management Frames) and this may disconnect devices which do not support this type of connection.
So I had to create two wifi networks - I don’t use extra router or access points, just separate network broadcasts - one for IoT using WPA2 for our printer - and another using WPA3 for phones, tablets and computers.
I see various “set MAC address” and “reset MAC address” in journalctl output. Some routers don’t like MAC address changes at all; you can try disabling it to see if that’s the cause.
sudo nano /etc/NetworkManager/conf.d/disable-random-mac.conf
Copy these two lines inside:
[device]
wifi.scan-rand-mac-address=no
And can you explain more clearly what this means? Can you see the SSIDs? Can you type the password? Did you connect and disconnect or no connection at all? Are you using any MAC filtering?
Both suggestions above are possible. No way to tell with the info.
It’s just restarting over and over, and there’s nothing useful here. So we can only guess.
journalctl -u NetworkManager -b
What would be more useful (on boot up until first connect).
But possibly even more useful, how far along is the device working..
What is the output of the following (the latter ones may not work if the first fail)
nmcli device status
nmcli device show wlp2s0
nmcli device wifi list ifname wlp2s0
I can see all SSIDs, but the Guest network and the 5G networks (Connection Error and High speed blackhole) does not connect at all. They keep asking the password even after disabling random mac as you advised and after a reboot. No MAC filtering at all, all settings on default, except setting up Guest and 5G connection points.
I’ve just realized you’re using a MT7922 card with mt7921e driver, when there is a driver for mt7922e… :thinking:
Is your computer a Lenovo Ideapad Pro? If so, read this (section 2):
Maybe that’s the source of the problem. Just noting that I haven’t chosen mt7921e driver, just installed Manjaro “blindly”.
It is a Lenovo Thinkpad E16 with AMD Ryzen.
Followed section 2, but before I overwrote files in /lib/firmware/mediatek, I checked if they are differ at all, and found, they don’t!
> for i in *.bin.xz; do md5sum $i; md5sum /lib/firmware/mediatek/$i; done
8676c4a5a0d526eb719d3ddcd752bc2d  BT_RAM_CODE_MT7922_1_1_hdr.bin.xz
8676c4a5a0d526eb719d3ddcd752bc2d  /lib/firmware/mediatek/BT_RAM_CODE_MT7922_1_1_hdr.bin.xz
bc5ee35211b5a14cbab8fea4d653aa7e  WIFI_MT7922_patch_mcu_1_1_hdr.bin.xz
bc5ee35211b5a14cbab8fea4d653aa7e  /lib/firmware/mediatek/WIFI_MT7922_patch_mcu_1_1_hdr.bin.xz
c5d6e02079cd371995564f7500fed775  WIFI_RAM_CODE_MT7922_1.bin.xz
c5d6e02079cd371995564f7500fed775  /lib/firmware/mediatek/WIFI_RAM_CODE_MT7922_1.bin.xz
So How to ask the kernel to use the correct driver?
Drivers are called modules, you can see here how to handle it:
You can see the modules loaded with lsmod, or detailed info from one with modinfo mt7921e.
May be you can remove mt7921e driver with modprobe -r mt7921e and then load modprobe mt7922e (temporary). Or using conf files to blacklist mt7921e and load mt7922e permanently.
What is the exact model of the laptop (as appears on the label on the bottom)? Only to check the support page and see the exact network card model (MT7921e or MT7922e).
Of possible interest:
Take a look at section 7.1.6:
QR code on bottom links to here
Text on bottom just says: ThinkPad E16 Gen 3
Done, but still cannot connect and keeps asking wifi password
So this should be your wifi card (MT7922):
But reading some support articles, seems mt7921e and mt7922e use the same drivers so I don’t know what else can we try…
If it’s some kind of incompatibility between the card and the router, as @anon33601770 mentioned at the beginning, discovering it is now a matter of luck. Or it could be the dumbest thing in the world.
Do you also have Windows on the hard drive (to rule out fast boot)? Is secure boot disabled in the Bios?
Do you have any unusual or local characters in your guest & 5G passwords (in case your keyboard is misconfigured and is typing different characters you can’t see)?
In NetworkManager → Configure, delete the guest & 5G wifi connections and let the system create them again.
If your router allows you to choose wifi at 20/40/80 MHz, select 20MHz (I have sometimes seen stability problems with this). If you can choose between wifi a/b/g/n/ac/ax, exclude ac and ax.
If your router has a “smart network switching” option (to the one with the strongest signal), disable it.
Does your router have the latest firmware available (in case the incompatibility has already been resolved)?
Any error message typing sudo dmesg | grep -i "mt79"?
Try also these three commands, let’s see if anything strange appears.
hwinfo --network --verbose
hwinfo --netcard --verbose
hwinfo --wlan --verbose
