Good Morning/Afternoon/evening
I’m not sure to post this question in the proper category…
I have created a Nextcloud local server and I use a wireguard VPN to access it remotely.
The thing is when I create a config file to access my local network, I can import it on my phone (in the wireguard app) or in the wireguard client of windows. In these cases, the connection works fine, and I’m able to connect to the internet or to my Nextcloud server. But If I import the same config file in a linux system (I tried manjaro and linuxmint) I get a notification when connecting saying: “connection activated” and I’m not able to connect to the internet (let say google_com) or to my local nextcloud server…
Maybe I’m doing something wrong but when I want to import my config file on manjaro, I go to the connection settings, then I click on the + button (add a new connection), then import a VPN connection (from a config file). I also tried to manually create a wireguard VPN but doesn’t work…
So I suppose it’s a configuration problem on linux system that I don’t get and that the issue doesn’t come from the VPN in itself…
But honestly, after a lot of time trying to find a solution… I need your help.
Thanks in advance to anyone that can help me!
Have a nice day,
Best regards,
Manuel34
