Hello, my first post ever here.
After connecting my ds4 via bluetooth to manjaro, my keyboard and mouse doesn’t work, even if I unplug their usb and plug them back. Only after restarting I can go back to using my keyboard again.
Also, the ds4 is not recognized as a gamepad somehow, so my guess is that manjaro is replacing my kb+mouse with the controller.
The ds4 via usb works perfectly, the problem only occurs via bluetooth, sadly.
What do i need to do to make my ds4 controller work via bluetooth and be recognized as a gamepad without disabling my keyboard and mouse?
Let me know if you need any info from the terminal.
Some info about my system:
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=452cc62e-9dea-4f49-aa83-a0740a80786c rw quiet apparmor=1
security=apparmor resume=UUID=a752ebeb-da59-40b6-9153-cfb5a53012c4
udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F50 date: 11/27/2019
Device-1: sony_controller_battery_a4:ae:11:21:29:19 model: N/A serial: N/A
charge: N/A status: Charging
RAM: total: 15.63 GiB used: 2.69 GiB (17.2%)
RAM Report:
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1440 high: 2454 min/max: 1400/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1285 2: 1257
3: 1228 4: 2454 5: 1547 6: 1255 7: 1242 8: 1252 bogomips: 59119
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 3GB] vendor: Gigabyte
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c83 class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: JMTek LLC. USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:2 chip-ID: 0c76:1694
class-ID: 0300 serial: <filter>
Device-4: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid bus-ID: 1-4:5 chip-ID: 054c:09cc
class-ID: 0300
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-9:4 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 2.04 TiB used: 33.17 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: D6SD scheme: GPT
ID-1: / raw-size: 206.08 GiB size: 201.78 GiB (97.92%)
used: 33.17 GiB (16.4%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 452cc62e-9dea-4f49-aa83-a0740a80786c
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 1134-9758
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: a752ebeb-da59-40b6-9153-cfb5a53012c4
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: 2TB
uuid: 64FA64F1FA64C142
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: JMTek LLC. USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:1694 class-ID: 0300
serial: <filter>
Device-2: 1-4:5 info: Sony DualShock 4 [CUH-ZCT2x] type: Audio,HID
driver: snd-usb-audio,sony,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 054c:09cc class-ID: 0300
Device-3: 1-6:3
info: American Power Conversion Uninterruptible Power Supply type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 051d:0002 class-ID: 0300 serial: <filter>
Device-4: 1-9:4 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: SINO WEALTH Gaming KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 258a:002a class-ID: 0300
Device-2: 3-4:3 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
power: 480mA chip-ID: 258a:1007 class-ID: 0301
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 53%
Processes: 255 Uptime: 9m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1270 pacman: 1257 lib: 333
flatpak: 13 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.12
````Preformatted text`
