Conky missplace in plasma wayland
Hello
Since a week ago I am having issues with conky rendering in the wrong screen.
I have changed nothing and I have had this exact scripts running for at least 6 years now. I wonder if somebody else has the same issue? If this is the case, were you able to fix it?
If no one else has this problem then it is obviously I did something wrong, but before rolling back a week I want to check if this is really an issue.
Thanks in advance
EDIT: I can correctly place the widgets using conky manager, by disabling enabling them, no change in the configuration.
Can you show your script?
There are some, but basically all of them are like this
double_buffer yes
update_interval 2
background yes
own_window yes
# own_window_type desktop
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
#own_window_type override
own_window_argb_visual true
own_window_argb_value 160
out_to_wayland true
out_to_console no
own_window_transparent no
own_window_class conky-semi
use_xft yes
xftfont cure:size=10
xftfont Rounded Elegance:size=10
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
stippled_borders 1
border_width 0
default_color white
default_shade_color white
default_outline_color 000000
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
xinerama_head 3
pad_percents 2
top_name_width 10
minimum_size 320 100
gap_x 15
gap_y 560
lua_load allcombined.lua
TEXT
${image img/cpu2.png -p 0,0 -s 30x30}
${offset 35}${font Good Times:size=12}${color Tan1}CPU INFORMATION ${color}${hr 2}
${font}${color}${execi 1000 cat /proc/cpuinfo | grep 'model name' | sed -e 's/model name.*: //'| uniq}
${color lightgrey}Temperature  DIE ${texeci 10 sensors | grep Tdie | awk '{ print $2}'}
${color lightgrey}Temperature  CTL ${texeci 10 sensors | grep Tctl | awk '{ print $2}'}
${color lightgrey}CPU Power ${texeci 10 sensors | grep SVI2_P_Core | awk '{ print $2}'} W
${color lightgrey}Fans ${texeci 10 sensors | grep it8686 -A 22 | grep fan | awk '{ print $2}' | awk -v d="; " '{s=(NR==1?s:s d)$0; str=s" RPM"}END{print str}'}
${alignc}${color #000000}${cpugraph 20,318 000000 FFFFFF}${color}
# CPU1
Cpu  1${goto 50} : ${cpu cpu1}%${goto 96}${cpubar cpu1 11,121}${goto 230}${color}${freq 1} MHz${image img/trans-bg240.png -p 93,152 -s 121x11}
# CPU2
Cpu  2${goto 50} : ${cpu cpu2}%${goto 96}${cpubar cpu2 11,121}${goto 230}${color}${freq 2} MHz${image img/trans-bg240.png -p 93,167 -s 121x11}
# CPU3
Cpu  3${goto 50} : ${cpu cpu3}%${goto 96}${cpubar cpu3 11,121}${goto 230}${color}${freq 3} MHz${image img/trans-bg240.png -p 93,182 -s 121x11}
# CPU4
Cpu  4${goto 50} : ${cpu cpu4}%${goto 96}${cpubar cpu4 11,121}${goto 230}${color}${freq 4} MHz${image img/trans-bg240.png -p 93,197 -s 121x11}
# CPU5
Cpu  5${goto 50} : ${cpu cpu5}%${goto 96}${cpubar cpu5 11,121}${goto 230}${color}${freq 5} MHz${image img/trans-bg240.png -p 93,212 -s 121x11}
# CPU6
Cpu  6${goto 50} : ${cpu cpu6}%${goto 96}${cpubar cpu6 11,121}${goto 230}${color}${freq 6} MHz${image img/trans-bg240.png -p 93,227 -s 121x11}
# CPU7
Cpu  7${goto 50} : ${cpu cpu7}%${goto 96}${cpubar cpu7 11,121}${goto 230}${color}${freq 7} MHz${image img/trans-bg240.png -p 93,242 -s 121x11}
# CPU8
Cpu  8${goto 50} : ${cpu cpu8}%${goto 96}${cpubar cpu8 11,121}${goto 230}${color}${freq 8} MHz${image img/trans-bg240.png -p 93,257 -s 121x11}
# CPU9
Cpu  9${goto 50} : ${cpu cpu9}%${goto 96}${cpubar cpu9 11,121}${goto 230}${color}${freq 9} MHz${image img/trans-bg240.png -p 93,272 -s 121x11}
# CPU10
Cpu  10${goto 50} : ${cpu cpu10}%${goto 96}${cpubar cpu10 11,121}${goto 230}${color}${freq 10} MHz${image img/trans-bg240.png -p 93,287 -s 121x11}
# CPU11
Cpu  11${goto 50} : ${cpu cpu11}%${goto 96}${cpubar cpu11 11,121}${goto 230}${color}${freq 11} MHz${image img/trans-bg240.png -p 93,302 -s 121x11}
# CPU12
Cpu  12${goto 50} : ${cpu cpu12}%${goto 96}${cpubar cpu12 11,121}${goto 230}${color}${freq 12} MHz${image img/trans-bg240.png -p 93,317 -s 121x11}
# CPU13
Cpu  13${goto 50} : ${cpu cpu13}%${goto 96}${cpubar cpu13 11,121}${goto 230}${color}${freq 13} MHz${image img/trans-bg240.png -p 93,332 -s 121x11}
# CPU14
Cpu  14${goto 50} : ${cpu cpu14}%${goto 96}${cpubar cpu14 11,121}${goto 230}${color}${freq 14} MHz${image img/trans-bg240.png -p 93,347 -s 121x11}
# CPU15
Cpu  15${goto 50} : ${cpu cpu15}%${goto 96}${cpubar cpu15 11,121}${goto 230}${color}${freq 15} MHz${image img/trans-bg240.png -p 93,362 -s 121x11}
# CPU16
Cpu  16${goto 50} : ${cpu cpu16}%${goto 96}${cpubar cpu16 11,121}${goto 230}${color}${freq 16} MHz${image img/trans-bg240.png -p 93,377 -s 121x11}
Conky dual screen positioning | AskUbuntu
You can completely disable conky’s alignment by setting alignment = none and put absolute gap_x and gap_y values. This will allow widget positioning at any place without weird negative shifting.
As an example: to put a 200px wide widget in the right top corner of the right monitor, calculation will be simple:
gap_x = <left_monitor_width> + <right_monitor_width> - <widget_width>
In my case:
gap_x = 1680 + 1680 - 200 = 3160
and the config will look next:
conky.config = {
    alignment = none,
    gap_x = 3160,
    gap_y = 0,
Also: Conky in the right place with a dual screen – antiX-forum
Thanks, I have tried this but eventually it gets misplaced again. The best I can do right now is using conky manager and disabling reenabling the widgets, That will temporarily place them in the correct position.
