So I just installed the Majaro-i3 yesterday and upon booting up the machine this morning, the Conky desktop system monitor and keyboard shortcut reference sheet is gone. Most of the info I can find on Conky is about people wanting to get rid of it, but I actually like the look. I only installed a few applications yesterday: Firejail, Brave, Kate, LibreOffice, and Wordgrinder.
Did have some trouble installing Wordgrinder. Had to install from CLI, because the Package UI Manager said the package didn’t exist. So I don’t know what’s going on with that. Works just fine though.
I did do a full desktop integration of Firejail first thing and I’m thinking that’s what’s causing the problem. When I try to launch an instance of conky from the terminal it throws this error message:
[jpbaiocchi@bruiser ~]$ start_conky_solarized
Reading profile /etc/firejail/conky.profile
Reading profile /etc/firejail/disable-common.inc
Reading profile /etc/firejail/disable-devel.inc
Reading profile /etc/firejail/disable-exec.inc
Reading profile /etc/firejail/disable-interpreters.inc
Reading profile /etc/firejail/disable-passwdmgr.inc
Reading profile /etc/firejail/disable-programs.inc
Reading profile /etc/firejail/disable-xdg.inc
Reading profile /etc/firejail/whitelist-usr-share-common.inc
Parent pid 1934, child pid 1935
Warning: /sbin directory link was not blacklisted
Warning: /usr/sbin directory link was not blacklisted
Child process initialized in 151.33 ms
conky: cannot open /usr/share/conky/conky1.10_shortcuts_solarized: No such file or directory
Parent is shutting down, bye...
So I cd’d to the conky subdirectory in /usr… and the file is right there:
[jpbaiocchi@bruiser ~]$ cd /usr/share/conky
[jpbaiocchi@bruiser conky]$ ls -al
total 60
drwxr-xr-x 2 root root 4096 Oct 19 10:59 .
drwxr-xr-x 199 root root 4096 Oct 28 17:50 ..
-rw-r--r-- 1 root root 950 May 7 2018 conky1.10_shortcuts_green
-rw-r--r-- 1 root root 950 May 7 2018 conky1.10_shortcuts_grey
-rw-r--r-- 1 root root 1011 May 7 2018 conky1.10_shortcuts_maia
-rw-r--r-- 1 root root 993 May 7 2018 conky1.10_shortcuts_solarized
-rw-r--r-- 1 root root 2077 May 7 2018 conky_green
-rw-r--r-- 1 root root 2077 May 7 2018 conky_grey
-rw-r--r-- 1 root root 2099 May 7 2018 conky_maia
-rw-r--r-- 1 root root 1024 May 7 2018 conky_shortcuts_live_green
-rw-r--r-- 1 root root 1024 May 7 2018 conky_shortcuts_live_grey
-rw-r--r-- 1 root root 1094 May 7 2018 conky_shortcuts_live_maia
-rw-r--r-- 1 root root 1067 May 7 2018 conky_shortcuts_live_solarized
-rw-r--r-- 1 root root 2120 May 7 2018 conky_solarized
Clearly the file exists, but I’m guessing Firejail is making it inaccessible. Can anyone tell me what the /sbin directory is and why Firejail thinks it needs to be blacklisted? Thank you.
Oh and fyi, I also did have some trouble configuring the time properly. Took me about an hour to realize that while my timezone was correct, I had local time set to Mexico City, which ends DST about a week before the US. So I switched it to Chicago. Didn’t install anything for that, just repeated attempts to try and sync the time.
and add the two lines from above. (Not tested here, but should work as well).
The conky.profile in your home overrules the file in /etc, the conky.local file adds (is supposed to add ) to the existing /etc/firejail/conky.profile.
Yeah, I was already working on a modified profile. When blacklisting the sbin directories didn’t worked, the only thing I could think of was that Firejail must be blocking access to the conky files. Your solution worked, although I did it for the whole /usr/share/conky directory. Many thanks!
Spoke too soon. Upon reboot, Conky wouldn’t draw the system info widget; though the i3 keyboard reference was back. I can get it to run in the terminal, but not on the desktop. Tried uninstalling Firejail and it was up and running upon reboot. So I’ll need to play around with the configs more.
This the output I get launching from the terminal-
[jpbaiocchi@bruiser ~]$ conky
Reading profile /home/jpbaiocchi/.config/firejail/conky.profile
Parent pid 2091, child pid 2092
Child process initialized in 145.27 ms
conky: no personal or system-wide config file found, using builtin default
conky: desktop window (56d) is root window
conky: window type - desktop
conky: drawing to created window (0x2800001)
conky: drawing to double buffer
conky: X Error: type 0 Display 56160927a6e0 XID 41943044 serial 1940 error_code 152 request_code 143 mi
Note the last 2 lines output upon killing Conky. I’m intrigued as to why it’s not accepting my config file. Here’s where I have it now.
GNU nano 5.2 conky.profile
# Firejail profile for conky
# Description: Highly configurable system monitor
# This file is overwritten after every install/update
# Persistent local customizations
include conky.local
# Persistent global definitions
include globals.local
noblacklist ${PICTURES}
noblacklist /usr/share/conky
noblacklist /usr/lib/liblua*
noblacklist /usr/sbin
noblacklist /sbin
whitelist /usr/share/conky
include disable-common.inc
include disable-devel.inc
include disable-exec.inc
include disable-interpreters.inc
include disable-passwdmgr.inc
include disable-programs.inc
include disable-xdg.inc
include whitelist-usr-share-common.inc
caps.drop all
ipc-namespace
netfilter
no3d
nodvd
nogroups
nonewprivs
noroot
nosound
notv
nou2f
novideo
protocol unix,inet,inet6
seccomp
shell none
disable-mnt
private-cache
private-dev
private-tmp
memory-deny-write-execute
Note: I only just now added the /usr/sbin and /sbin back into the no-blacklist. No effect.
Could you please post your i3 config? You may as well check for yourself if any of the commands listed by ls -la /usr/bin/ | grep "start_conky"
is present in any uncommented “exec”-line in your i3 config.
Just running conky from a terminal won’t load Manjaro’s i3 conky setup.
[jpbaiocchi@bruiser ~]$ cd .config/i3
[jpbaiocchi@bruiser i3]$ ls -al
total 24
drwxr-xr-x 2 jpbaiocchi jpbaiocchi 4096 Oct 30 13:32 .
drwxr-xr-x 32 jpbaiocchi jpbaiocchi 4096 Oct 31 01:07 ..
-rw-r--r-- 1 jpbaiocchi jpbaiocchi 15492 Oct 30 22:06 config
[jpbaiocchi@bruiser i3]$ nano config
# i3 config file (v4)
# Please see http://i3wm.org/docs/userguide.html for a complete reference!
# Set mod key (Mod1=<Alt>, Mod4=<Super>)
set $mod Mod4
# set default desktop layout (default is tiling)
# workspace_layout tabbed <stacking|tabbed>
# Configure border style <normal|1pixel|pixel xx|none|pixel>
default_border pixel 1
default_floating_border normal
# Hide borders
hide_edge_borders none
# change borders
bindsym $mod+u border none
bindsym $mod+y border pixel 1
bindsym $mod+n border normal
# Font for window titles. Will also be used by the bar unless a different font
# is used in the bar {} block below.
font xft:URWGothic-Book 11
# Use Mouse+$mod to drag floating windows
floating_modifier $mod
# start a terminal
bindsym $mod+Return exec terminal
# kill focused window
bindsym $mod+Shift+q kill
# start program launcher
bindsym $mod+d exec --no-startup-id dmenu_recency
# launch categorized menu
bindsym $mod+z exec --no-startup-id morc_menu
## sound-section - DO NOT EDIT if you wish to automatically upgrade Alsa -> Pulseaudio later! ##
exec --no-startup-id volumeicon
bindsym $mod+Ctrl+m exec terminal -e 'alsamixer'
#exec --no-startup-id pulseaudio
#exec --no-startup-id pa-applet
#bindsym $mod+Ctrl+m exec pavucontrol
# Screen brightness controls
# bindsym XF86MonBrightnessUp exec "xbacklight -inc 10; notify-send 'brightness up'"
# bindsym XF86MonBrightnessDown exec "xbacklight -dec 10; notify-send 'brightness down'"
# Start Applications
bindsym $mod+Ctrl+b exec terminal -e 'bmenu'
bindsym $mod+F2 exec palemoon
bindsym $mod+F3 exec pcmanfm
# bindsym $mod+F3 exec ranger
bindsym $mod+Shift+F3 exec pcmanfm_pkexec
bindsym $mod+F5 exec terminal -e 'mocp'
bindsym $mod+t exec --no-startup-id pkill picom
bindsym $mod+Ctrl+t exec --no-startup-id picom -b
bindsym $mod+Shift+d --release exec "killall dunst; exec notify-send 'restart dunst'"
bindsym Print exec --no-startup-id i3-scrot
bindsym $mod+Print --release exec --no-startup-id i3-scrot -w
bindsym $mod+Shift+Print --release exec --no-startup-id i3-scrot -s
bindsym $mod+Shift+h exec xdg-open /usr/share/doc/manjaro/i3_help.pdf
bindsym $mod+Ctrl+x --release exec --no-startup-id xkill
# focus_follows_mouse no
# change focus
bindsym $mod+j focus left
bindsym $mod+k focus down
bindsym $mod+l focus up
bindsym $mod+semicolon focus right
# alternatively, you can use the cursor keys:
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# move focused window
bindsym $mod+Shift+j move left
bindsym $mod+Shift+k move down
bindsym $mod+Shift+l move up
bindsym $mod+Shift+semicolon move right
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# workspace back and forth (with/without active container)
workspace_auto_back_and_forth yes
bindsym $mod+b workspace back_and_forth
bindsym $mod+Shift+b move container to workspace back_and_forth; workspace back_and_forth
# split orientation
bindsym $mod+h split h;exec notify-send 'tile horizontally'
bindsym $mod+v split v;exec notify-send 'tile vertically'
bindsym $mod+q split toggle
# toggle fullscreen mode for the focused container
bindsym $mod+f fullscreen toggle
# change container layout (stacked, tabbed, toggle split)
bindsym $mod+s layout stacking
bindsym $mod+w layout tabbed
bindsym $mod+e layout toggle split
# toggle tiling / floating
bindsym $mod+Shift+space floating toggle
# change focus between tiling / floating windows
bindsym $mod+space focus mode_toggle
# toggle sticky
bindsym $mod+Shift+s sticky toggle
# focus the parent container
bindsym $mod+a focus parent
# move the currently focused window to the scratchpad
bindsym $mod+Shift+minus move scratchpad
# Show the next scratchpad window or hide the focused scratchpad window.
# If there are multiple scratchpad windows, this command cycles through them.
bindsym $mod+minus scratchpad show
#navigate workspaces next / previous
bindsym $mod+Ctrl+Right workspace next
bindsym $mod+Ctrl+Left workspace prev
# Workspace names
# to display names or symbols instead of plain workspace numbers you can use
# something like: set $ws1 1:mail
# set $ws2 2:
set $ws1 1
set $ws2 2
set $ws3 3
set $ws4 4
set $ws5 5
set $ws6 6
set $ws7 7
set $ws8 8
# switch to workspace
bindsym $mod+1 workspace $ws1
bindsym $mod+2 workspace $ws2
bindsym $mod+3 workspace $ws3
bindsym $mod+4 workspace $ws4
bindsym $mod+5 workspace $ws5
bindsym $mod+6 workspace $ws6
bindsym $mod+7 workspace $ws7
bindsym $mod+8 workspace $ws8
# Move focused container to workspace
bindsym $mod+Ctrl+1 move container to workspace $ws1
bindsym $mod+Ctrl+2 move container to workspace $ws2
bindsym $mod+Ctrl+3 move container to workspace $ws3
bindsym $mod+Ctrl+4 move container to workspace $ws4
bindsym $mod+Ctrl+5 move container to workspace $ws5
bindsym $mod+Ctrl+6 move container to workspace $ws6
bindsym $mod+Ctrl+7 move container to workspace $ws7
bindsym $mod+Ctrl+8 move container to workspace $ws8
# Move to workspace with focused container
bindsym $mod+Shift+1 move container to workspace $ws1; workspace $ws1
bindsym $mod+Shift+2 move container to workspace $ws2; workspace $ws2
bindsym $mod+Shift+3 move container to workspace $ws3; workspace $ws3
bindsym $mod+Shift+4 move container to workspace $ws4; workspace $ws4
bindsym $mod+Shift+5 move container to workspace $ws5; workspace $ws5
bindsym $mod+Shift+6 move container to workspace $ws6; workspace $ws6
bindsym $mod+Shift+7 move container to workspace $ws7; workspace $ws7
bindsym $mod+Shift+8 move container to workspace $ws8; workspace $ws8
# Open applications on specific workspaces
# assign [class="Thunderbird"] $ws1
# assign [class="Pale moon"] $ws2
# assign [class="Pcmanfm"] $ws3
# assign [class="Skype"] $ws5
# Open specific applications in floating mode
for_window [title="alsamixer"] floating enable border pixel 1
for_window [class="calamares"] floating enable border normal
for_window [class="Clipgrab"] floating enable
for_window [title="File Transfer*"] floating enable
for_window [class="fpakman"] floating enable
for_window [class="Galculator"] floating enable border pixel 1
for_window [class="GParted"] floating enable border normal
for_window [title="i3_help"] floating enable sticky enable border normal
for_window [class="Lightdm-settings"] floating enable
for_window [class="Lxappearance"] floating enable sticky enable border normal
for_window [class="Manjaro-hello"] floating enable
for_window [class="Manjaro Settings Manager"] floating enable border normal
for_window [title="MuseScore: Play Panel"] floating enable
for_window [class="Nitrogen"] floating enable sticky enable border normal
for_window [class="Oblogout"] fullscreen enable
for_window [class="octopi"] floating enable
for_window [title="About Pale Moon"] floating enable
for_window [class="Pamac-manager"] floating enable
for_window [class="Pavucontrol"] floating enable
for_window [class="qt5ct"] floating enable sticky enable border normal
for_window [class="Qtconfig-qt4"] floating enable sticky enable border normal
for_window [class="Simple-scan"] floating enable border normal
for_window [class="(?i)System-config-printer.py"] floating enable border normal
for_window [class="Skype"] floating enable border normal
for_window [class="Timeset-gui"] floating enable border normal
for_window [class="(?i)virtualbox"] floating enable border normal
for_window [class="Xfburn"] floating enable
# switch to workspace with urgent window automatically
for_window [urgent=latest] focus
# reload the configuration file
bindsym $mod+Shift+c reload
# restart i3 inplace (preserves your layout/session, can be used to upgrade i3)
bindsym $mod+Shift+r restart
# exit i3 (logs you out of your X session)
bindsym $mod+Shift+e exec "i3-nagbar -t warning -m 'You pressed the exit shortcut. Do you really want to exit i3? This will end your X session.' -b 'Yes, exit i3' 'i3-msg exit'"
# Set shut down, restart and locking features
bindsym $mod+0 mode "$mode_system"
set $mode_system (l)ock, (e)xit, switch_(u)ser, (s)uspend, (h)ibernate, (r)eboot, (Shift+s)hutdown
mode "$mode_system" {
bindsym l exec --no-startup-id i3exit lock, mode "default"
bindsym s exec --no-startup-id i3exit suspend, mode "default"
bindsym u exec --no-startup-id i3exit switch_user, mode "default"
bindsym e exec --no-startup-id i3exit logout, mode "default"
bindsym h exec --no-startup-id i3exit hibernate, mode "default"
bindsym r exec --no-startup-id i3exit reboot, mode "default"
bindsym Shift+s exec --no-startup-id i3exit shutdown, mode "default"
# exit system mode: "Enter" or "Escape"
bindsym Return mode "default"
bindsym Escape mode "default"
# Resize window (you can also use the mouse for that)
bindsym $mod+r mode "resize"
mode "resize" {
# These bindings trigger as soon as you enter the resize mode
# Pressing left will shrink the window’s width.
# Pressing right will grow the window’s width.
# Pressing up will shrink the window’s height.
# Pressing down will grow the window’s height.
bindsym j resize shrink width 5 px or 5 ppt
bindsym k resize grow height 5 px or 5 ppt
bindsym l resize shrink height 5 px or 5 ppt
bindsym semicolon resize grow width 5 px or 5 ppt
# same bindings, but for the arrow keys
bindsym Left resize shrink width 10 px or 10 ppt
bindsym Down resize grow height 10 px or 10 ppt
bindsym Up resize shrink height 10 px or 10 ppt
bindsym Right resize grow width 10 px or 10 ppt
# exit resize mode: Enter or Escape
# Lock screen
bindsym $mod+9 exec --no-startup-id blurlock
# Autostart applications
exec --no-startup-id /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
exec --no-startup-id nitrogen --restore; sleep 1; picom -b
exec --no-startup-id manjaro-hello
exec --no-startup-id nm-applet
exec --no-startup-id xfce4-power-manager
exec --no-startup-id pamac-tray
exec --no-startup-id clipit
# exec --no-startup-id blueman-applet
# exec_always --no-startup-id sbxkb
exec --no-startup-id start_conky_maia
# exec --no-startup-id start_conky_green
exec --no-startup-id xautolock -time 10 -locker blurlock
exec_always --no-startup-id ff-theme-util
exec_always --no-startup-id fix_xcursor
# Color palette used for the terminal ( ~/.Xresources file )
# Colors are gathered based on the documentation:
# https://i3wm.org/docs/userguide.html#xresources
# Change the variable name at the place you want to match the color
# of your terminal like this:
# [example]
# If you want your bar to have the same background color as your
# terminal background change the line 362 from:
# background #14191D
# to:
# background $term_background
# Same logic applied to everything else.
set_from_resource $term_background background
set_from_resource $term_foreground foreground
set_from_resource $term_color0 color0
set_from_resource $term_color1 color1
set_from_resource $term_color2 color2
set_from_resource $term_color3 color3
set_from_resource $term_color4 color4
set_from_resource $term_color5 color5
set_from_resource $term_color6 color6
set_from_resource $term_color7 color7
set_from_resource $term_color8 color8
set_from_resource $term_color9 color9
set_from_resource $term_color10 color10
set_from_resource $term_color11 color11
set_from_resource $term_color12 color12
set_from_resource $term_color13 color13
set_from_resource $term_color14 color14
set_from_resource $term_color15 color15
# Start i3bar to display a workspace bar (plus the system information i3status if available)
bar {
i3bar_command i3bar
status_command i3status
position bottom
## please set your primary output first. Example: 'xrandr --output eDP1 --primary'
# tray_output primary
# tray_output eDP1
bindsym button4 nop
bindsym button5 nop
# font xft:URWGothic-Book 11
strip_workspace_numbers yes
colors {
background #222D31
statusline #F9FAF9
separator #454947
# border backgr. text
focused_workspace #F9FAF9 #16a085 #292F34
active_workspace #595B5B #353836 #FDF6E3
inactive_workspace #595B5B #222D31 #EEE8D5
binding_mode #16a085 #2C2C2C #F9FAF9
urgent_workspace #16a085 #FDF6E3 #E5201D
# hide/unhide i3status bar
bindsym $mod+m bar mode toggle
# Theme colors
# class border backgr. text indic. child_border
client.focused #556064 #556064 #80FFF9 #FDF6E3
client.focused_inactive #2F3D44 #2F3D44 #1ABC9C #454948
client.unfocused #2F3D44 #2F3D44 #1ABC9C #454948
client.urgent #CB4B16 #FDF6E3 #1ABC9C #268BD2
client.placeholder #000000 #0c0c0c #ffffff #000000
client.background #2B2C2B
### settings for i3-gaps: ###
# Set inner/outer gaps
gaps inner 14
gaps outer -2
# Additionally, you can issue commands with the following syntax. This is useful to bind keys to changing the gap size.
# gaps inner|outer current|all set|plus|minus <px>
# gaps inner all set 10
# gaps outer all plus 5
# Smart gaps (gaps used if only more than one container on the workspace)
smart_gaps on
# Smart borders (draw borders around container only if it is not the only container on this workspace)
# on|no_gaps (on=always activate and no_gaps=only activate if the gap size to the edge of the screen is 0)
smart_borders on
# Press $mod+Shift+g to enter the gap mode. Choose o or i for modifying outer/inner gaps. Press one of + / - (in-/decrement for current workspace) or 0 (remove gaps for current workspace). If you also press Shift with these keys, the change will be global for all workspaces.
set $mode_gaps Gaps: (o) outer, (i) inner
set $mode_gaps_outer Outer Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_inner Inner Gaps: +|-|0 (local), Shift + +|-|0 (global)
bindsym $mod+Shift+g mode "$mode_gaps"
mode "$mode_gaps" {
bindsym o mode "$mode_gaps_outer"
bindsym i mode "$mode_gaps_inner"
mode "$mode_gaps_inner" {
bindsym plus gaps inner current plus 5
bindsym minus gaps inner current minus 5
bindsym 0 gaps inner current set 0
bindsym Shift+plus gaps inner all plus 5
bindsym Shift+minus gaps inner all minus 5
bindsym Shift+0 gaps inner all set 0
mode "$mode_gaps_outer" {
bindsym plus gaps outer current plus 5
bindsym minus gaps outer current minus 5
bindsym 0 gaps outer current set 0
bindsym Shift+plus gaps outer all plus 5
bindsym Shift+minus gaps outer all minus 5
bindsym Shift+0 gaps outer all set 0
The only uncommented start_conky commands is the one for Maia under Autostart applications.
That’s weird. The config has the i3bar set at bottom edge of screen, but I have mine at the top position.
Do you, by any chance have a second config in ~/.i3?
Anyway, on my laptop I got all conkies running now by creating a start_conky_maia.profile in both ~/.config/firejail/ and /etc/firejail/ with the same content as the edited conky.profile. After creating those files, do a sudo firecfg
logout and login again, and hopefully your conkies will show up…
Just dropping the last few lines of Terminal output from the sudo firecfg here for later reference-
Adding user jpbaiocchi to Firejail access database in /etc/firejail/firejail.users
User jpbaiocchi already in the database
Loading AppArmor profile
Cache read/write disabled: interface file missing. (Kernel needs AppArmor 2.4 compatibility patch.)
Warning: unable to find a suitable fs in /proc/mounts, is it mounted?
Use --subdomainfs to override.
Configuring symlinks in /usr/local/bin based on local firejail config directory
start_conky_maia created
Warning: cannot create /usr/local/bin/conky - already exists! Skipping...
Fixing desktop files in /home/jpbaiocchi/.local/share/applications
vlc.desktop created
What happens if you run start_conky_maia ?
If the conkies are starting up, then we just need to establish which config your i3 is using and add/uncomment exec --no-startup-id start_conky_maia.
Respectively create matching profiles for whichever start_conky_xxx you’re using in your i3 config.
Regarding apparmor, firejail has a history of breaking apparmor. Firejail 0.9.64-2 and apparmor 3.0.0-2 (both in testing branch) work well together on my side.
So it appears to be working now. After running the sudo firecfg, I had to start_conky_maia from dmenu for the conkies to show up. So I rebooted and they managed to autostart. And for good measure, I rebooted into Windows, then back into Linux. Still works.
Linux should check my .config directory before looking in the .i3 right?
Anyways, thank you very much for your assistance. This would have taken me ages to solve. Much appreciated.
