Hola.
Desde hace algún tiempo mi sistema se congela y no hay modo de recuperarlo si no es a través de un reinicio a lo bruto. Sucede siempre que el sistema regresa de un período de suspensión.
Salida inxi:
Kernel: 6.0.2-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=7c5861e3-047b-48ca-808f-9d1a02ce3697 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: SLIMBOOK product: PROX14-10 v: Standard
serial: <superuser required>
Mobo: SLIMBOOK model: PROX14-10 v: Standard serial: <superuser required>
UEFI: American Megatrends v: N.1.02 date: 12/13/2019
ID-1: BAT0 charge: 30.8 Wh (71.1%) condition: 43.3/46.7 Wh (92.7%)
volts: 11.6 min: 11.4 model: standard type: Li-ion serial: <filter>
status: discharging
RAM: total: 15.48 GiB used: 3.02 GiB (19.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1945 high: 2300 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 900
4: 2300 5: 2300 6: 863 7: 2300 8: 2300 bogomips: 36812
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Tongfang Hongkong
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d5 built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
Sound API: ALSA v: k6.0.2-2-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: speed: Unknown
lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 4000 bus-ID: 02:00.0
IP v6: <filter> virtual: stable-privacy scope: link
Local Storage: total: 465.76 GiB used: 67.85 GiB (14.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 31.9 C scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 67.85 GiB
(14.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 7c5861e3-047b-48ca-808f-9d1a02ce3697
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 49B0-7850
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 36.0 C pch: 35.0 C mobo: N/A
Processes: 269 Uptime: 15m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1391 libs: 366 tools: pamac,yay Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.22
