tengo una tarjeta grafica integrada amd, instale manjaro Kde, con el unico programa que se congela el sistema es con steam.agradeceria alguna ayuda del porque se me congela mi sistema es:
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
Subsystem: Hewlett-Packard Company Device 81e0
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: bdw_uncore
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 5500 (rev 09) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 49
Memory at d0000000 (64-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 6000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
Flags: bus master, fast devsel, latency 0, IRQ 52
Memory at d1418000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:04.0 Signal processing controller: Intel Corporation Broadwell-U Processor Thermal Subsystem (rev 09)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at d1410000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device_pci_legacy
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 46
Memory at d1400000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
Flags: bus master, fast devsel, latency 0, IRQ 47
Memory at d1423000 (64-bit, non-prefetchable) [size=32]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
Flags: bus master, fast devsel, latency 64, IRQ 50
Memory at d141c000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 42
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00005000-00005fff [size=4K]
Memory behind bridge: d1300000-d13fffff [size=1M]
Prefetchable memory behind bridge: 00000000d1000000-00000000d10fffff [size=1M]
Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #2 (rev e3) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 43
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: d1200000-d12fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
00:1c.4 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #5 (rev e3) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 44
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: d1100000-d11fffff [size=1M]
Prefetchable memory behind bridge: 00000000b0000000-00000000bfffffff [size=256M]
00:1d.0 USB controller: Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at d1421000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 45
I/O ports at 6088 [size=8]
I/O ports at 6094 [size=4]
I/O ports at 6080 [size=8]
I/O ports at 6090 [size=4]
I/O ports at 6060 [size=32]
Memory at d1420000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
Flags: medium devsel, IRQ 18
Memory at d1422000 (64-bit, non-prefetchable) [size=256]
I/O ports at 6040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
I/O ports at 5000 [size=256]
Memory at d1300000 (64-bit, non-prefetchable) [size=4K]
Memory at d1000000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
Subsystem: Hewlett-Packard Company Device 81c1
Flags: bus master, fast devsel, latency 0, IRQ 17
I/O ports at 4000 [size=256]
Memory at d1200000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: rtl8723be
Kernel modules: rtl8723be
03:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] (rev 83)
Flags: bus master, fast devsel, latency 0, IRQ 51
Memory at b0000000 (64-bit, prefetchable) [size=256M]
Memory at d1100000 (64-bit, non-prefetchable) [size=256K]
I/O ports at 3000 [size=256]
Expansion ROM at d1140000 [disabled] [size=128K]
Kernel driver in use: radeon
