Conflicts during for update
Yup, there’s a time sink for sure.
In this case, I suspect it’d actually rather be:
sudo usermod --move-home --home /path/to/new_home username
:wink:
As I understood it while skimming the thread was that there WAS no home directory, it was gone. So not sure what --move-home would do for him.
Otherwise yes, then you don’t have to use mv after.
You read more 'n me, that’s why I said
:wink:
The OP’s /home is not on a separate partition; it exists under /.
Skim more carefully. :wink:
I understood it as the home was gone completely, other partition would not matter.
I clearly misunderstood.
I thought maybe it was a Swedish thing; that skimming and skiing meant the same thing; but, how would I know, anyway, I’m a foreigner!
I usually do :
sudo pacman -Syyu
not sure what the difference is
OK. How do I remove the old kernels? I’ll look it up :slight_smile:
correct: the answer was : there is nothing to do
Thank you all for your help
Use -Syu in daily use for updates or installs.
sudo pacman -Syu = sync with package database and update
sudo pacman -Syu $package = sync with package database and update and install $package
The others should not generally be used unless you have a reason to.
sudo pacman -Syuu = as above, but allows downgrades (such as in the case that a repo package is seen as a lesser version than the one installed)
sudo pacman -Syyu = as above except ‘force refresh’ databse.
EDIT. Typo fixed :wink:
sudo pacman -Syuu
(He forgot the extra u for the downgrading :wink: )
Thank you. You are right I never knew -Syu had to be used daily! Will do now.
thanks. Noted -Syuu
I didnt mean you need to use it literally daily. I just meant thats the standard. Though you should do updates regularly.
I thought so…but regularly.
Just follow the Stable Updates announcements. There’s even an App for that :tm:
that’s what I usually do but that time I ran into trouble :slight_smile:
