biddie
12 December 2023 09:39
1
Hello, I tried an update but got this:
:: installing kholidays5 (1:5.112.0-1) breaks dependency 'kholidays' required by kalarmcal
:: installing kxmlgui5 (5.112.0-1) breaks dependency 'kxmlgui' required by kfloppy
:: installing kcompletion5 (5.112.0-1) breaks dependency 'kcompletion' required by kfloppy
:: installing kio5 (5.112.0-1) breaks dependency 'kio' required by kipi-plugins
:: installing kpeople5 (5.112.0-1) breaks dependency 'kpeople' required by kpeoplevcard
:: installing kcontacts5 (5.112.0-1) breaks dependency 'kcontacts' required by kpeoplevcard
:: installing kxmlgui5 (5.112.0-1) breaks dependency 'kxmlgui' required by libkipi
:: installing kservice5 (5.112.0-1) breaks dependency 'kservice' required by libkipi
:: installing knotifications5 (5.112.0-1) breaks dependency 'knotifications' required by telepathy-kde-approver
:: installing kservice5 (5.112.0-1) breaks dependency 'kservice' required by telepathy-kde-approver
:: installing knotifyconfig5 (5.112.0-1) breaks dependency 'knotifyconfig' required by telepathy-kde-common-internals
:: installing ktexteditor5 (5.112.0-1) breaks dependency 'ktexteditor' required by telepathy-kde-common-internals
:: installing kpeople5 (5.112.0-1) breaks dependency 'kpeople' required by telepathy-kde-common-internals
:: installing krunner5 (5.112.0-1) breaks dependency 'krunner' required by telepathy-kde-contact-runner
:: installing kidletime5 (5.112.0-1) breaks dependency 'kidletime' required by telepathy-kde-integration-module
:: installing kactivities5 (5.112.0-1) breaks dependency 'kactivities' required by telepathy-kde-integration-module
[you@ms-nl4050cu
What happens I think is I used to have KDE ( years ago) and some upgrade went wrong and somehow, with help, I switched to Xfce. If I understand correctly the remnants of KDE are in the way but I don’t know how to solve this.
Grateful for any help…step by step if possible
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
biddie:
Please provide the output of:
cscs
12 December 2023 10:42
3
Use the search if you must.
You have unsupported packages.
You also have packages that require manual intervention.
Remove the offending aliens then run
sudo pacman -Syuu
Teo
12 December 2023 10:54
4
In the add remove programs there is the section installed and “orphans”. And above a button remove all.
biddie
12 December 2023 11:21
5
you@ms-nl4050cu ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.2.0-2-rt3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-rt-x86_64
root=UUID=d783a58b-db39-43b8-9fa0-9e5ac4936521 rw quiet nohibernate
apparmor=1 security=apparmor
resume=UUID=a4e6a4d2-70f4-4b85-8082-35492fd4461c udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 2 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM
Type: Laptop System: Notebook product: NL40_50CU v: N/A
Mobo: Notebook model: NL40_50CU serial: <superuser required> UEFI: INSYDE
v: 1.07.13 date: 10/27/2020
ID-1: BAT0 charge: 41.7 Wh (100.0%) condition: 41.7/48.3 Wh (86.5%)
volts: 16.8 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 85% rechargeable: yes status: discharging
System RAM: total: 12 GiB note: est. available: 11.39 GiB
used: 5.04 GiB (44.2%)
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF8
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1729 high: 2600 min/max: 400/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 819 2: 2600 3: 900 4: 2600
bogomips: 20799
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 5986:9102
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9b41 memory: 11.12 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 1 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:9b41 surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.2.0-2-rt3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f1 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 232.89 GiB used: 66.98 GiB (28.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 28.9 C
scheme: GPT
ID-1: / raw-size: 223.79 GiB size: 219.22 GiB (97.96%)
used: 66.98 GiB (30.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: d783a58b-db39-43b8-9fa0-9e5ac4936521
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 61A3-686A
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: a4e6a4d2-70f4-4b85-8082-35492fd4461c
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7:3 info: Bison BisonCam NB Pro type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:9102 class-ID: 0e02
Device-3: 1-10:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 49.0 C pch: 40.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 287 Uptime: 1h 56m wakeups: 12 Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: 2088 pm: pacman pkgs: 2079 libs: 494 tools: pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 9 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.30
Could you please reformat that between backticks instead? Use the </> button on the toolbar to create a scrollable Preformatted Text box. This will make it more readable for others to help you. Thanks.
biddie
12 December 2023 11:34
7
type or paste code here
```Blockquoteyou@ms-nl4050cu ~]$ inxi --admin --verbosity=7 --filter --no-host --width
serial: Chassis: type: 10 serial:
Mobo: Notebook model: NL40_50CU serial: UEFI: INSYDE
status: full
serial: charge: 85% rechargeable: yes status: discharging
bogomips: 20799
class-ID: 0e02
IF: wlp2s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
class-ID: e001
lanes: 4 tech: SSD serial: fw-rev: S5Z42105 temp: 28.9 C
scheme: GPT
uuid: 61A3-686A
biddie
12 December 2023 11:37
8
no package found in installed orphans
Try this to start with:
sudo pacman -Rs kalarmcal kfloppy kipi-plugins kpeoplevcard telepathy
and post the output.
biddie
12 December 2023 11:57
10
emphasised text error: target not found: telepathy
OK, try again without telepathy.
biddie
12 December 2023 12:00
12
checking dependencies...
:: removing kpeoplevcard breaks dependency 'kpeoplevcard' required by kdeconnectmphasised text*
nikgnomic: post edited to show data in preformatted text
sudo pacman -Sy kpeoplevcard
sudo pacman -Syuu
Try that.
biddie
12 December 2023 12:08
14
[you@ms-nl4050cu ~]$ sudo pacman -Sy kpeoplevcard
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: downgrading package kpeoplevcard (0.1+r38.32d50a9-1 => 0.1-2)
resolving dependencies...
Packages (1) kpeoplevcard-0.1-2
Total Download Size: 0.02 MiB
Total Installed Size: 0.05 MiB
Net Upgrade Size: -0.01 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
kpeoplevcard-0.1... 17.8 KiB 414 KiB/s 00:00 [######################] 100%
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) downgrading kpeoplevcard [######################] 100%
(1/1) Arming ConditionNeedsUpdate...
[you@ms-nl4050cu ~]$ sudo pacman -Syuu
core is up to date
extra is up to date
:: Replace analitza with extra/analitza5? [Y/n] Y
:: Replace appstream-qt with extra/appstream-qt5? [Y/n] Y
:: Replace kdiagram with extra/kdiagram5? [Y/n] Y
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n] Y
:: Replace kgamma5 with extra/kgamma? [Y/n] Y
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n] Y
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n] Y
:: Replace libkcddb with extra/libkcddb5? [Y/n] Y
:: Replace libkdcraw with extra/libkdcraw5? [Y/n] Y
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n] Y
warning: palemoon: downgrading from version 1:31.4.1-2 to version 32.5.1-1
biddie
12 December 2023 12:13
16
Packages (2) kalarmcal-21.12.3-1 kfloppy-23.04.3-1
Total Removed Size: 3.39 MiB
:: Do you want to remove these packages? [Y/n] Y
(1/2) removing kfloppy [######################] 100%
(2/2) removing kalarmcal [######################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating icon theme caches...
(3/3) Updating the desktop file MIME type cache...
Some progress, at least. Not sure if this will work, but try it.
sudo pacman -R telepathy-kde
biddie
12 December 2023 12:18
18
warning: dependency cycle detected:
warning: telepathy-kde-integration-module will be removed after its telepathy-kde-common-internals dependency
Packages (12) telepathy-kde-accounts-kcm-23.04.3-1
telepathy-kde-approver-23.04.3-1
telepathy-kde-auth-handler-23.04.3-1
telepathy-kde-call-ui-23.04.3-1
telepathy-kde-common-internals-23.04.3-1
telepathy-kde-contact-list-23.04.3-1
telepathy-kde-contact-runner-23.04.3-1
telepathy-kde-desktop-applets-23.04.3-1
telepathy-kde-filetransfer-handler-23.04.3-1
telepathy-kde-integration-module-23.04.3-1
telepathy-kde-send-file-23.04.3-1
telepathy-kde-text-ui-23.04.3-1
Total Removed Size: 12.87 MiB
( 1/12) removing telepathy-kde-text-ui [######################] 100%
( 2/12) removing telepathy-kde-send-file [######################] 100%
( 3/12) removing telepathy-kde-filetransfer-ha... [######################] 100%
( 4/12) removing telepathy-kde-desktop-applets [######################] 100%
( 5/12) removing telepathy-kde-contact-runner [######################] 100%
( 6/12) removing telepathy-kde-contact-list [######################] 100%
( 7/12) removing telepathy-kde-call-ui [######################] 100%
( 8/12) removing telepathy-kde-auth-handler [######################] 100%
( 9/12) removing telepathy-kde-common-internals [######################] 100%
(10/12) removing telepathy-kde-integration-module [######################] 100%
(11/12) removing telepathy-kde-approver [######################] 100%
(12/12) removing telepathy-kde-accounts-kcm [######################] 100%
sudo pacman -R kholidays5 kxmlgui5 kcompletion5
KDE packages have been renamed recently, in readiness for Plasma6 in January. I can see this is particularly troublesome here.
biddie
12 December 2023 12:25
20
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by blinken
:: removing kholidays5 breaks dependency 'kholidays' required by calendarsupport
:: removing kholidays5 breaks dependency 'kholidays' required by kalarm
:: removing kxmlgui5 breaks dependency 'kxmlgui5' required by kbookmarks5
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kbruch
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kcalc
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kcolorchooser
:: removing kcompletion5 breaks dependency 'kcompletion' required by kdebugsettings
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kdebugsettings
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kgeography
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kmix
:: removing kcompletion5 breaks dependency 'kcompletion' required by kmix
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kmousetool
:: removing kholidays5 breaks dependency 'kholidays' required by kopeninghours
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by krfb
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by kruler
:: removing kcompletion5 breaks dependency 'kcompletion5' required by ksysguard
:: removing kxmlgui5 breaks dependency 'kxmlgui5' required by ksysguard
:: removing kcompletion5 breaks dependency 'kcompletion5' required by ktextwidgets5
:: removing kcompletion5 breaks dependency 'kcompletion' required by libkdepim
:: removing kxmlgui5 breaks dependency 'kxmlgui' required by libkipi
:: removing kcompletion5 breaks dependency 'kcompletion' required by libkmahjongg
:: removing kholidays5 breaks dependency 'kholidays5' required by plasma-workspace
