I’m having a conflicting files update problem, and haven’t been able to find any solutions on how to resolve it. I’d appreciate any suggestions on how to resolve this problem. Thank you.
First make sure your package database is up to date. Then if it is you could try and remove smpeg2, update and then try and reinstall it. But odds are another package has replaced it.
Thank you for the help. Problem solved.
