I have Manjaro OB on three computers all working well except one can not update.
This is what happens, using pamac:
Blockquote
Warning: dependency cycle detected:
Warning: bashrc-manjaro will be installed before its bash dependency
Warning: harfbuzz will be installed before its freetype2 dependency
Warning: libglvnd will be installed before its mesa dependency
Warning: smbclient will be installed before its cifs-utils dependency
Warning: lib32-keyutils will be installed before its lib32-krb5 dependency
Warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
Warning: lib32-libglvnd will be installed before its lib32-mesa dependency
Warning: usbmuxd will be installed before its libimobiledevice dependency
132.5 mb downoad required
Failed to prepare transaction
conflicting dependencies:
util-linux-libs and libutil-linux are in conflict
libutil-linux isnt in the repos.
So you will have to remove that and/or install util-linux-libs first … or something along those lines.
You can look at what is currently requiring libutil-linux with
