Configuring "System Monitor Sensor"
Hello Manjaro KDE users
I hope you can help out an MX Linux KDE user. I am trying to configure the “System Monitor Sensor” widget for the taskbar to monitor CPU, RAM and GPU use. However, there is no entry for “GPU” there:
I also tried with a newer Debian based distro and booted the Kubuntu 22.04 daily build live ISO, but still there was no entry for GPU there. Half a year ago I was using Manjaro KDE, which was then using a slightly older KDE version than Kubuntu 22.04 today, but it already had the “GPU” entry in this widget. So I was wondering where this “GPU” entry comes from and if I can somehow add it to my MX Linux installation.
Thank you for your help.
Here’s my system info from within MX Linux:
Snapshot created on: 20220312_1950
System:    Kernel: 5.15.0-3mx-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.15.0-3mx-amd64 root=UUID=<filter>
           ro quiet splash init=/lib/systemd/systemd
           Desktop: KDE Plasma 5.20.5 wm: kwin_x11 vt: 7 dm: SDDM
           Distro: MX-21_KDE_x64 Wildflower October 20  2021 base: Debian GNU/Linux 11 (bullseye)
Machine:   Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
           Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x serial: <filter>
           UEFI: American Megatrends v: 2423 date: 08/10/2021
CPU:       Info: 8-Core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
           family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000C cache: L2: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 121605
           Speed: 2389 MHz min/max: 1400/3800 MHz boost: enabled Core speeds (MHz): 1: 2389 2: 2624 3: 3480
           4: 2825 5: 2131 6: 2365 7: 3028 8: 3634 9: 2360 10: 4443 11: 2715 12: 2262 13: 2664 14: 2843 15: 2266
           16: 2456
           Type: spectre_v2
           mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
           bus-ID: 08:00.0 chip-ID: 1002:1638 class-ID: 0300
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati
           unloaded: fbdev,modesetting,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
           Monitor-1: DisplayPort-0 res: 3840x2160 hz: 60 dpi: 140 size: 698x393mm (27.5x15.5")
           diag: 801mm (31.5")
           OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.0-3mx-amd64 LLVM 12.0.1) v: 4.6 Mesa 21.2.5
           direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition Audio vendor: ASUSTeK
           driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
           Sound Server-1: ALSA v: k5.15.0-3mx-amd64 running: yes
           Sound Server-2: PulseAudio v: 14.2 running: yes
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel modules: wl bus-ID: 05:00.0 chip-ID: 8086:2723
           class-ID: 0280
           IF: wlan0 state: down mac: <filter>
           Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel port: N/A bus-ID: 06:00.0
           chip-ID: 8086:15f3 class-ID: 0200
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2 chip-ID: 8087:0029
           class-ID: e001
           Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0 lmp-v: 5.2 sub-v: 24bf
           hci-v: 5.2 rev: 24bf
           Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff link-mode: slave accept
           service-classes: rendering, capturing, object transfer, audio
Drives:    Local Storage: total: 12.28 TiB used: 5.08 TiB (41.4%)
           ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB
           block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
           rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
           ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: WD Blue SN570 1TB size: 931.51 GiB
           rev: 234100WD temp: 34.9 C scheme: GPT
           ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWG21C size: 10.91 TiB block-size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 0601
           scheme: GPT
Partition: ID-1: / raw-size: 101.22 GiB size: 99.08 GiB (97.88%) used: 30.17 GiB (30.4%) fs: ext4
           dev: /dev/nvme0n1p2 maj-min: 259:8
           ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 274 KiB (0.1%) fs: vfat
           dev: /dev/nvme0n1p1 maj-min: 259:7
Swap:      Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p4
           maj-min: 259:10
Sensors:   Message: No sensor data found. Is lm-sensors configured?
Repos:     Packages: 2545 note: see --pkg apt: 2539 lib: 1336 flatpak: 6
           No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
           1: deb http://deb.debian.org/debian bullseye-updates main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/debian.list
           1: deb http://deb.debian.org/debian bullseye main contrib non-free
           2: deb http://security.debian.org/debian-security bullseye-security main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/megasync.list
           1: deb https://mega.nz/linux/repo/Debian_11/ ./
           Active apt repos in: /etc/apt/sources.list.d/mx.list
           1: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ bullseye main non-free
           2: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ bullseye ahs
           Active apt repos in: /etc/apt/sources.list.d/onlyoffice.list
           1: deb https://download.onlyoffice.com/repo/debian squeeze main
           Active apt repos in: /etc/apt/sources.list.d/opera-stable.list
           1: deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
           Active apt repos in: /etc/apt/sources.list.d/teams.list
           1: deb [arch=amd64] https://packages.microsoft.com/repos/ms-teams stable main
           Active apt repos in: /etc/apt/sources.list.d/vivaldi.list
           1: deb [arch=amd64] https://repo.vivaldi.com/stable/deb/ stable main
Info:      Processes: 383 Uptime: 37m wakeups: 0 Memory: 30.73 GiB used: 6.78 GiB (22.1%) Init: systemd v: 247
           runlevel: 5 default: 5 tool: systemctl Compilers: gcc: 10.2.1 alt: 10 Shell: bash
           default: Bash v: 5.1.4 running-in: quick-system-info-mx inxi: 3.3.06
Boot Mode: UEFI
Hello,
Yeah, why not. :slight_smile:
First of, you have to select the first field in the Sensors Details.
Then select the GPU
If nothing there, then you must consult the detection of sensors for your Distribution and install the required package and go trough the process of detecting those sensors, so their information is stored, so later the Widget can use that information.
As you can see in your inxi:
have you added sensors-detect ?
Thanks! :grinning:
I actually went through the process of configuring the sensors before with “sudo sensors-detect” , so I am not sure why there is this message in the inxi.
When I run “sensors” in the terminal I get this:
$ sensors
amdgpu-pci-0800
Adapter: PCI adapter
vddgfx:      749.00 mV
vddnb:       999.00 mV
edge:         +32.0°C
power1:      1000.00 uW
nvme-pci-0700
Composite:    +34.9°C  (low  =  -5.2°C, high = +79.8°C)
                       (crit = +84.8°C)
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1:            N/A
k10temp-pci-00c3
Tctl:         +35.8°C
nvme-pci-0400
Composite:    +37.9°C  (low  = -273.1°C, high = +84.8°C)
                       (crit = +84.8°C)
Sensor 1:     +37.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 2:     +36.9°C  (low  = -273.1°C, high = +65261.8°C)
So my GPU is already there. Also, there is actually an entry under “Hardware sensors > amdgpu-pci-0800” which shows these sensor options:
What I am missing is the “GPU” category in the first menu, which contains the GPU usage in % (similar to the “CPU” category for the CPU usage in %).
What I am wondering is: Are these values really supplied by lm-sensors (“a free and open-source application that provides tools and drivers for monitoring temperatures, voltage, and fans.”)? Because measuring CPU and GPU load may be something that is actually supplied by another package?
I actually installed a package called “radeontop” and it shows GPU load and other stuff in the terminal, but it does not seem to connect to the “System monitor Sensor” widget(?)
This is how Manjaro looks like, booted from the “Minimal” Live ISO, without installing anything or configuring any sensors:
This is the output of “sensors” in the Manjaro terminal:
iwlwifi_1-virtual-0
temp1:        +32.0°C
k10temp-pci-00c3
Tctl:         +34.4°C
nvme-pci-0700
Composite:    +31.9°C  (low  =  -5.2°C, high = +79.8°C)
                       (crit = +84.8°C)
amdgpu-pci-0800
vddgfx:      906.00 mV
vddnb:       993.00 mV
edge:         +29.0°C
slowPPT:     1000.00 uW
nvme-pci-0400
Composite:    +29.9°C  (low  = -273.1°C, high = +84.8°C)
                       (crit = +84.8°C)
Sensor 1:     +29.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 2:     +29.9°C  (low  = -273.1°C, high = +65261.8°C)
Also, note there is not even the “GPU” category in Manjaro Ksysguard:
So where does this “GPU” category in the “System Monitor Sensor” with GPU load info come from?
