I am running Manjaro-ARM-xfce-rpi4-20.12.1 on a Raspberry 3B+ and I want to change it to headless and auto login when booting. How do I configure that?
For thé auto login part I guess that you could take a look at https://wiki.archlinux.org/index.php/automatic_login_to_virtual_console
I’m still wondering for the headless part : do you want to remove xfce or just disable it ?
I use this with a 7" touchscreen monitor to run an audio server. I want to duplicate it but without a monitor, and I would access/control it remotely by ssh and VNC.
Autologin to GUI can be configured with lightdm settings.
If it works without a display present, is not certain.
SSH will only autologin, if you use ssh-keys as login method.
great! that worked, and can confirm it works without a display present, thanks.
