Yep, I’ve already placed my config files there, anything else I need to do or change?
Here is the config file btw:
# Minimalis Conky 1.3
# Author : archit3x
# Release date : 4 December 2020
# Tested on : Archlinux ARM - XFCE Desktop
# Email : archit3x@archlinux.us
# Feel free to modity this script ;)
conky.config = {
alignment = 'top_right',
background = true,
border_width = 1,
cpu_avg_samples = 2,
default_color = 'gray',
default_outline_color = 'white',
default_shade_color = 'white',
color1 = '#1793d1',
double_buffer = true,
draw_borders = false,
draw_graph_borders = true,
draw_outline = false,
draw_shades = false,
extra_newline = false,
font = 'Roboto Mono:size=7',
gap_x = 30,
gap_y = 30,
minimum_height = 250,
minimum_width = 220,
net_avg_samples = 2,
no_buffers = true,
out_to_console = false,
out_to_ncurses = false,
out_to_stderr = false,
out_to_x = true,
own_window = true,
own_window_class = 'Conky',
own_window_transparent = true,
own_window_argb_visual = true,
own_window_type = 'panel',
own_window_hints ='undecorated,sticky,skip_taskbar,skip_pager,below',
show_graph_range = false,
show_graph_scale = false,
stippled_borders = 0,
update_interval = 1.0,
uppercase = false,
use_spacer = 'none',
use_xft = true,
conky.text = [[
${color1}${font ConkySymbols:size=20}t${font} ${voffset -10}GNU/Linux» $hr ${color}
${color1}${goto 35}OS : ${color}${execi 86400 cat `ls -atr /etc/*-release | tail -2` | grep "PRETTY_NAME" | cut -d= -f2 | sed 's/"//g'}
${color1}${goto 35}Kernel : ${color}$kernel on $machine
${color1}${font ConkySymbols:size=16}f${font} ${voffset -10} System» $hr${color}
${color1}${goto 35}Core 1 : ${color}${freq_g 1}GHz ${alignr}${cpu cpu0}% ${cpubar cpu0 4,100}
${color1}${goto 35}Core 2 : ${color}${freq_g 2}GHz ${alignr}${cpu cpu1}% ${cpubar cpu1 4,100}
${color1}${goto 35}Core 3 : ${color}${freq_g 3}GHz ${alignr}${cpu cpu2}% ${cpubar cpu2 4,100}
${color1}${goto 35}Core 4 : ${color}${freq_g 4}GHz ${alignr}${cpu cpu3}% ${cpubar cpu3 4,100}
${color1}${goto 35}Uptime : ${color}$uptime_short ${alignr}${color1}Load : ${color}${loadavg}
${color1}${font ConkySymbols:size=16}h${font} ${voffset -10} Temperature» $hr${color}
${color1}${goto 35}CPU : ${color}${exec sensors | grep 'temp1' | awk 'NR==1{print $2}'} ${alignr}${color1}GPU : ${color}${exec sensors | grep 'temp1' | awk 'NR==2{print $2}'}
${color1}${font ConkySymbols:size=16}J${font} ${voffset -10}Memory» $hr${color}
${color1}${goto 35}RAM : ${color}$mem/$memmax ${alignr}$memperc% ${membar 4,100}
${color1}${goto 35}SWAP: ${color}$swap/$swapmax $alignr}$swapperc% ${swapbar 4,100}
${color1}${font ConkySymbols:size=16}n${font} ${voffset -10} Processes» $hr${color}
${color1}${goto 35}CPU usage ${alignr}Memory Usage${color}
${color1}${goto 35}${stippled_hr}${color}
${goto 35}${top name 1} ${color}${top cpu 1}% ${alignr}${top_mem name 1}${top_mem mem_res 1}
${goto 35}${top name 2} ${color}${top cpu 2}% ${alignr}${top_mem name 2}${top_mem mem_res 2}
${goto 35}${top name 3} ${color}${top cpu 3}% ${alignr}${top_mem name 3}${top_mem mem_res 3}
${goto 35}${top name 4} ${color}${top cpu 4}% ${alignr}${top_mem name 4}${top_mem mem_res 4}
${goto 35}${top name 5} ${color}${top cpu 5}% ${alignr}${top_mem name 5}${top_mem mem_res 5}
${color1}${goto 35}Processes: ${color}$processes ${color1}Running: ${color}$running_processes
${color1}${font ConkySymbols:size=16}k${font} ${voffset -10} Storage» $hr${color}
${color1}${goto 35}ROOT : ${color}${fs_used /}/${fs_size /} ${alignr}${fs_used_perc /}% ${fs_bar 4,100 /}
${goto 35}
${color1}${font ConkySymbols:size=16}b${font} ${voffset -10} Wireless» $hr${color}
${color1}${goto 35}SSID : ${color}${wireless_essid enp1s0} ${color1}${alignr}Signal: ${color}${wireless_link_qual_perc enp1s0}% ${wireless_link_bar 4,100 enp1s0}
${color1}${goto 35}Bitrate : ${color}${wireless_bitrate enp1s0}
${color1}${goto 35}Total Down/Up : ${color}${totaldown enp1s0}/${totalup enp1s0}
${color1}${goto 35}Speed Down/Up : ${color}${downspeed enp1s0}/${upspeed enp1s0}
