Gonza
27 March 2023 12:59
1
Buenas, actualice como siempre pacman y yay y me quede sin wifi, solo puedo usar ethernel… algunos de los datos que tengo para proporcionar son…
iwconfig
lo no wireless extensions.
enp45s0 no wireless extensions.
docker0 no wireless extensions.
lspci
2d:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
inxi -N
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: N/A
Device-2: Realtek RTL8125 2.5GbE driver: r8169
probé buscar e instalar iwlwifi pero no lo encuentra asique no lo puedo instalar…
podrían ayudarme? gracias!
switch to a different kernel, for example the 6.1 or 6.2 and try with them…
and iwlwifi is part of the kernel, so theres nothing to install… except the different kernel of course
Gonza
27 March 2023 19:32
3
I try with both of them but dosn’t run anyone… I don’t know why I get a failed to load the kernel… now I’m runing the 5.15.102…
you mean you cant boot with the 6.1 and the 6.2 kernels?
are you having intel+nvidia?
Gonza
27 March 2023 20:50
5
yep… and I have nvidia, yes…
Kernel: 5.15.102-1-MANJARO
CPU: 12th Gen Intel i7-12700H (20) @ 4.600GHz
GPU: Intel Alder Lake-P
GPU: NVIDIA Geforce RTX 3070 Ti Laptop GPU
so add the ibt parameter:
try adding the ibt parameter:
open this file:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
ibt=off
dont remove anything from there!, just add it to existing parameters, save the file, update grub:
sudo update-grub
reboot and try switching…
but i dont think it will help, but give it a try anyway
and then test with the 6.1 kernel
Gonza
27 March 2023 21:04
7
You are amazing man! thaks for all !!! everything is working… the kernel and the wifi… thanks !!
system
Closed
30 March 2023 11:04
8
