Computer unexpectedly freezes
I have had problems with my computer for a while. I originally ran Windows 11 when the problems began, then i switched Manjaro with I3. So i cant really know if the problem is with Manjaro or my hardware. One of my attempts at fixing these unexpected freezes was updating my BIOS and that seemed to help a bit but it did not solve my problem. That is the only attempt at fixing the problem that yielded noticeable results. Some of the things i have done, include try different RAM sticks, remount all my hardware, I have checked that all my thermals are stable, I have tried identifying patterns to the freezing but I can’t, I tried changing the kernel with no result. I have tried to understand the journalctl log but i don’t really understand it, so my searching attempts have not been very help full.
When my computer freezes it does not respond to any input and to shut it down i have to force shut it down by holding down the power button for a few seconds. Sometimes i can move my mouse for a few seconds before it freezes but i cant click anything, I can only move the cursor.
Here is the result of the inxi -v7azy:
  Kernel: 6.1.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=dba12cdc-24dc-4ddc-8ce4-78e9940e18dd rw rd.driver.pre=vfio-pci
    amd_iommu=on quiet apparmor=1 security=apparmor udev.log_priority=3
  Desktop: i3 v: 4.23 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 5003
    date: 02/03/2023
  System RAM: total: 32 GiB available: 31.26 GiB used: 2.39 GiB (7.6%)
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 3274 high: 4201 min/max: 2200/4426 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4147 2: 4201
    3: 4198 4: 4198 5: 3398 6: 2316 7: 2098 8: 2188 9: 4135 10: 2474 11: 4200
    12: 4200 13: 4199 14: 2200 15: 2123 16: 2121 bogomips: 115244
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: Micro-Star MSI
    driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 09:00.0 chip-ID: 10de:1f08 class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.9 compositor: Picom v: git-b700a driver:
    X: loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5360x1440 s-dpi: 93 s-size: 1464x385mm (57.64x15.16")
    s-diag: 1514mm (59.6")
  Monitor-1: DP-2 pos: primary,right res: 3440x1440 dpi: 109
    size: 800x330mm (31.5x12.99") diag: 865mm (34.07") modes: N/A
  Monitor-2: HDMI-0 pos: left res: 1920x1200 hz: 60 dpi: 94
    size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 09:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Realtek [] driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:4938
  Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.1.60-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  Device-2: Ralink MT7610U (Archer T2U 2.4G+5G WLAN Adapter driver: mt76x0u
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:4
    chip-ID: 148f:761a class-ID: 0000 serial: <filter>
  IF: wlp2s0f0u3 state: up mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Local Storage: total: 2.05 TiB used: 177.77 GiB (8.5%)
    model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 611100WD temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX4 size: 238.47 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 1.5 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD1001FALS-00J7B0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0K05
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 177.76 GiB (19.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: dba12cdc-24dc-4ddc-8ce4-78e9940e18dd
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 672F-29B9
  ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: N/A
    uuid: 46EEC297EEC27EA5
  ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
    uuid: 9267-28F4
  ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sda4 maj-min: 8:4 size: 237.84 GiB fs: ntfs label: N/A
    uuid: 587E17EE7E17C3A2
  Device-1: 1-1:2 info: Realtek [] type: audio driver: snd-usb-audio
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 100mA chip-ID: 0bda:4938 class-ID: 0102 serial: <filter>
  Device-2: 1-2:3 info: Logitech HD Pro Webcam C920 type: video,audio
  Device-3: 1-3:4 info: Ralink MT7610U (Archer T2U 2.4G+5G WLAN Adapter
    type: Network driver: mt76x0u interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 160mA
  Device-4: 1-5:5 info: [] type: mouse,keyboard driver: hid-generic,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 258a:2022 class-ID: 0301 serial: <filter>
  Device-5: 1-6:6 info: Corsair Gaming K55 RGB Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:1b3d class-ID: 0300
    serial: <filter>
  Device-6: 1-10:7 info: Corsair Lighting Node Pro type: HID
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 1b1c:0c0b class-ID: 0300
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 57.0 C mobo: 43.0 C
  Fan Speeds (rpm): cpu: 1551 case-1: 985 case-2: 985 case-3: 976
  Power: 12v: 9.97 5v: N/A 3.3v: N/A vbat: 3.21
  Processes: 309 Uptime: 20m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1377 libs: 419 tools: pamac,yay Shell: Bash v: 5.2.15
  running-in: urxvtd inxi: 3.3.31
I’m new to forums so if I have missed any information you need please tell me and I will try to provide it.
Even while the cause is unknown, this can help prevent further damage
Gentle shut down a suddenly hanged PC to minimize a chance of getting a broken filesystem and data loss:
https://docs.kernel.org/admin-guide/sysrq.html
:footprints:
Thanks, I will use this, and many it will improve something’s.
just to be clear, this behaviour happened on both windows and linux ? that’s what i understand from here.
Yes that is correct.
The link unfortunately did not work for me, but I found [HowTo] reboot / turn off your frozen computer: REISUB/REISUO which I think might have a similar message. I tried to restart the system using REISUB and REISUO. But it did not work, it is still frozen.
bad contact of the cpu ? release the cpu holder and reconnect the cpu. might be a possible failure.
also check
sudo dmesg
you can redirect it to a file with
sudo dmesg > dmesginfo.txt
any suspicious error-messages inside dmesg ?
I have tried remounting the CPU once before but I could try it again.
When i run sudo dmesg I’m not entirely sure of what to look for but something that looks suspicious to me is:
ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT5._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Which i see a a lot of scattered about in the log.
But there is this aswell:
nvidia-gpu 0000:09:00.3: i2c timeout error e0000000
ucsi_ccg 0-0008: i2c_transfer failed -110
ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
But this only appeared once.
I have no idea what these error means, but maybe they tell you something.
no need, you already checked it.
  • Create a new file with the command: echo "blacklist i2c_nvidia_gpu" > /etc/modprobe.d/blacklist_i2c-nvidia-gpu.conf. This command uses the echo function to output the text “blacklist i2c_nvidia_gpu” and the > operator to redirect this output to the file /etc/modprobe.d/blacklist_i2c-nvidia-gpu.conf. If the file does not exist, it will be created.
  • After creating the file, run the command sudo update-initramfs -u. This command updates the initial ramdisk for preloading drivers. This ensures that the changes you made take effect.
Source:
in the end nothing to worry about, it’s not related to your problem.
This strongly suggests looking for the problem in the
  • hardware or
  • BIOS
    :footprints:
Thanks for the help! I will try to check for faulty hardware.
