Thank you for your help! Here is the output of the three commands.
journalctl shows a crash of baloo_file which could be responsible for the issue (there was a crash at about the same time). However the previous entry of journalctl is Dec 21, whereas I experienced the same issue this morning.
System: Kernel: 5.10.7-1-MANJARO-ARM aarch64 bits: 64 compiler: gcc v: 10.2.0
parameters: initrd=/initramfs-linux.img console=tty1 console=ttyS2,1500000 root=LABEL=ROOT_MNJRO rw rootwait
video=eDP-1:1920x1080@60 video=HDMI-A-1:1920x1080@60 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro ARM
Machine: Type: ARM Device System: Pine64 Pinebook Pro details: N/A serial: <filter>
Battery: ID-1: cw2015-battery charge: 91% condition: N/A volts: 4.2/N/A model: N/A type: Li-ion serial: N/A status: Charging
CPU: Info: 6-Core (2-Die) model: N/A variant-1: cortex-a72 variant-2: cortex-a53 bits: 64 type: MCP MCM arch: ARMv8
family: 8 model-id: N/A stepping: 4 microcode: N/A
features: Use -f option to see features bogomips: 0
Speed: 1800 MHz min/max: 408/1416:1800 MHz Core speeds (MHz): 1: 1416 2: 1416 3: 1416 4: 1416 5: 1800 6: 1800
Type: spec_store_bypass status: Not affected
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 mitigation: Branch predictor hardening
Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A bus ID: N/A chip ID: rockchip:display-subsystem
Device-2: rk3399-mali driver: panfrost v: kernel bus ID: N/A chip ID: rockchip:ff9a0000
Device-3: Microdia HP Integrated Webcam type: USB driver: uvcvideo bus ID: 2-1.2:4 chip ID: 0c45:6321
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: modesetting alternate: fbdev
resolution: <xdpyinfo missing>
OpenGL: renderer: Mali T860 (Panfrost) v: 3.3 Mesa 20.3.3 direct render: Yes
Audio: Device-1: simple-audio-card driver: asoc_simple_card bus ID: N/A chip ID: simple-audio-card:es8316-sound
Device-2: simple-audio-card driver: N/A bus ID: N/A chip ID: simple-audio-card:hdmi-sound
Sound Server: ALSA v: k5.10.7-1-MANJARO-ARM
Network: Message: No ARM data found for this feature.
IF-ID-1: anbox0 state: down mac: <filter>
IF-ID-2: wlan0 state: up mac: <filter>
Drives: Local Storage: total: 58.24 GiB used: 50.70 GiB (87.0%)
ID-1: /dev/mmcblk2 model: DA4064 size: 58.24 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 0x8 scheme: MBR
Partition: ID-1: / raw size: 58.00 GiB size: 57.03 GiB (98.32%) used: 50.65 GiB (88.8%) fs: ext4 dev: /dev/mmcblk2p2
ID-2: /boot raw size: 213.6 MiB size: 213.4 MiB (99.89%) used: 44.3 MiB (20.8%) fs: vfat dev: /dev/mmcblk2p1
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 4.00 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
ID-2: swap-2 type: zram size: 4.63 GiB used: 185.2 MiB (3.9%) priority: 5 dev: /dev/zram0
Sensors: System Temperatures: cpu: 43.9 C mobo: N/A
Info: Processes: 200 Uptime: 2h 16m Memory: 3.71 GiB used: 2.75 GiB (74.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1209 lib: 254 Shell: Bash v: 5.1.4 running in: konsole inxi: 3.1.08
Jan 26 20:39:28 pbp kernel: rockchip-dp ff970000.edp: no DP phy configured
Jan 26 20:41:27 pbp systemd-udevd[389]: event3: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[389]: event3: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[389]: event3: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[392]: event5: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[392]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[392]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[407]: event4: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[407]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[407]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[394]: event1: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[394]: event1: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[394]: event1: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[399]: event2: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[399]: event2: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jan 26 20:41:27 pbp systemd-udevd[399]: event2: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jan 26 20:41:27 pbp unknown: Started bpfilter
Jan 26 20:41:28 pbp kernel: ieee80211 phy0: brcmf_netdev_set_mac_address: Setting cur_etheraddr failed, -52
Jan 26 20:43:46 pbp kernel: ieee80211 phy0: brcmf_netdev_set_mac_address: Setting cur_etheraddr failed, -52
Jan 26 20:43:50 pbp kwin_x11[1310]: kwin_core: Compositing is not possible
Jan 26 20:43:51 pbp pulseaudio[1381]: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your configuration.
Jan 26 20:43:51 pbp kded5[1306]: org.kde.plasma.dataengine.geolocation: error: "Unknown host location.services.mozilla.com: Host not found"
Jan 26 20:43:57 pbp systemd-coredump[1551]: Process 1365 (baloo_file) of user 1000 dumped core.
Stack trace of thread 1544:
#0 0x0000ffffa002fbb0 n/a (liblmdb.so + 0x3bb0)
#1 0x0000ffffa003263c n/a (liblmdb.so + 0x663c)
#2 0x0000ffffa0032e98 n/a (liblmdb.so + 0x6e98)
#3 0x0000ffffa0033364 mdb_get (liblmdb.so + 0x7364)
#4 0x0000ffffa15cdd0c _ZN5Baloo12IdFilenameDB3getEy (libKF5BalooEngine.so.5 + 0x16d0c)
#5 0x0000ffffa15c6d10 _ZNK5Baloo13DocumentUrlDB3getEy (libKF5BalooEngine.so.5 + 0xfd10)
#6 0x0000ffffa15da4d0 _ZNK5Baloo11Transaction11documentUrlEy (libKF5BalooEngine.so.5 + 0x234d0)
#7 0x0000aaaad6990f24 n/a (baloo_file + 0x20f24)
#8 0x0000ffffa15e2724 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#9 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#10 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#11 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#12 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#13 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#14 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#15 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#16 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#17 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#18 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#19 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#20 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#21 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#22 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#23 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#24 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#25 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#26 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#27 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#28 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#29 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#30 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#31 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#32 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#33 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#34 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#35 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#36 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#37 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#38 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#39 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#40 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#41 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#42 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#43 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#44 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#45 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#46 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#47 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#48 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#49 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#50 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#51 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#52 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#53 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#54 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#55 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#56 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#57 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#58 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#59 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#60 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#61 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#62 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
#63 0x0000ffffa15e2780 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so>
Stack trace of thread 1382:
#0 0x0000ffffa0ca4974 pselect (libc.so.6 + 0xcc974)
#1 0x0000ffff9f0d77c0 n/a (libusbmuxd-2.0.so.6 + 0x27c0)
#2 0x0000ffff9f0d8ea8 n/a (libusbmuxd-2.0.so.6 + 0x3ea8)
#3 0x0000ffffa0b9bf44 start_thread (libpthread.so.0 + 0x7f44)
#4 0x0000ffffa0cab95c thread_start (libc.so.6 + 0xd395c)
Stack trace of thread 1379:
#0 0x0000ffffa0ca1e64 __poll (libc.so.6 + 0xc9e64)
#1 0x0000ffff9f6fc0e0 n/a (libglib-2.0.so.0 + 0x610e0)
#2 0x0000ffff9f6fc264 g_main_context_iteration (libglib-2.0.so.0 + 0x61264)
#3 0x0000ffffa1353a08 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQ>
#4 0x0000ffffa12e41d4 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2e81d4)
#5 0x0000ffffa10c2f84 _ZN7QThread4execEv (libQt5Core.so.5 + 0xc6f84)
#6 0x0000ffffa16175ac n/a (libQt5DBus.so.5 + 0x185ac)
#7 0x0000ffffa10c4888 n/a (libQt5Core.so.5 + 0xc8888)
#8 0x0000ffffa0b9bf44 start_thread (libpthread.so.0 + 0x7f44)
#9 0x0000ffffa0cab95c thread_start (libc.so.6 + 0xd395c)
Stack trace of thread 1365:
#5 0x0000ffffa12ee900 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2f2900)
#6 0x0000aaaad697db90 n/a (baloo_file + 0xdb90)
#7 0x0000ffffa0bfc538 __libc_start_main (libc.so.6 + 0x24538)
#8 0x0000aaaad697de14 n/a (baloo_file + 0xde14)
#9 0x0000aaaad697de14 n/a (baloo_file + 0xde14)
░░ Subject: Process 1365 (baloo_file) dumped core
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ Documentation: man:core(5)
░░ Process 1365 (baloo_file) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
[Tue Jan 26 20:42:25 2021] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[Tue Jan 26 20:42:25 2021] Linux version 5.10.7-1-MANJARO-ARM (builduser@odroid-n2plus-pm) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP Tue Jan 12 >
[Tue Jan 26 20:42:25 2021] Machine model: Pine64 Pinebook Pro
[Tue Jan 26 20:42:25 2021] efi: UEFI not found.
[Tue Jan 26 20:42:25 2021] cma: Reserved 256 MiB at 0x00000000e5800000
[Tue Jan 26 20:42:25 2021] Zone ranges:
[Tue Jan 26 20:42:25 2021] DMA [mem 0x0000000000200000-0x000000003fffffff]
[Tue Jan 26 20:42:25 2021] DMA32 [mem 0x0000000040000000-0x00000000f7ffffff]
[Tue Jan 26 20:42:25 2021] Normal empty
[Tue Jan 26 20:42:25 2021] Movable zone start for each node
[Tue Jan 26 20:42:25 2021] Early memory node ranges
[Tue Jan 26 20:42:25 2021] node 0: [mem 0x0000000000200000-0x00000000f7ffffff]
[Tue Jan 26 20:42:25 2021] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[Tue Jan 26 20:42:25 2021] On node 0 totalpages: 1015296
[Tue Jan 26 20:42:25 2021] DMA zone: 4088 pages used for memmap
[Tue Jan 26 20:42:25 2021] DMA zone: 0 pages reserved
[Tue Jan 26 20:42:25 2021] DMA zone: 261632 pages, LIFO batch:63
[Tue Jan 26 20:42:25 2021] DMA32 zone: 11776 pages used for memmap
[Tue Jan 26 20:42:25 2021] DMA32 zone: 753664 pages, LIFO batch:63
[Tue Jan 26 20:42:25 2021] psci: probing for conduit method from DT.
[Tue Jan 26 20:42:25 2021] psci: PSCIv1.1 detected in firmware.
[Tue Jan 26 20:42:25 2021] psci: Using standard PSCI v0.2 function IDs
[Tue Jan 26 20:42:25 2021] psci: MIGRATE_INFO_TYPE not supported.
[Tue Jan 26 20:42:25 2021] psci: SMC Calling Convention v1.2
[Tue Jan 26 20:42:25 2021] percpu: Embedded 23 pages/cpu s55256 r8192 d30760 u94208
[Tue Jan 26 20:42:25 2021] pcpu-alloc: s55256 r8192 d30760 u94208 alloc=23*4096
[Tue Jan 26 20:42:25 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[Tue Jan 26 20:42:25 2021] Detected VIPT I-cache on CPU0
[Tue Jan 26 20:42:25 2021] CPU features: detected: ARM erratum 845719
[Tue Jan 26 20:42:25 2021] CPU features: detected: GIC system register CPU interface
[Tue Jan 26 20:42:25 2021] Built 1 zonelists, mobility grouping on. Total pages: 999432
[Tue Jan 26 20:42:25 2021] Kernel command line: initrd=/initramfs-linux.img console=tty1 console=ttyS2,1500000 root=LABEL=ROOT_MNJRO rw rootwait video=eDP-1>
[Tue Jan 26 20:42:25 2021] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[Tue Jan 26 20:42:25 2021] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[Tue Jan 26 20:42:25 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
[Tue Jan 26 20:42:25 2021] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
[Tue Jan 26 20:42:25 2021] Memory: 3614852K/4061184K available (16384K kernel code, 2496K rwdata, 6804K rodata, 4096K init, 880K bss, 184188K reserved, 2621>
[Tue Jan 26 20:42:25 2021] random: get_random_u64 called from cache_random_seq_create+0x84/0x180 with crng_init=0
[Tue Jan 26 20:42:25 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[Tue Jan 26 20:42:25 2021] rcu: Hierarchical RCU implementation.
[Tue Jan 26 20:42:25 2021] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[Tue Jan 26 20:42:25 2021] Trampoline variant of Tasks RCU enabled.
[Tue Jan 26 20:42:25 2021] Rude variant of Tasks RCU enabled.
[Tue Jan 26 20:42:25 2021] Tracing variant of Tasks RCU enabled.
[Tue Jan 26 20:42:25 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[Tue Jan 26 20:42:25 2021] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[Tue Jan 26 20:42:25 2021] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[Tue Jan 26 20:42:25 2021] GICv3: GIC: Using split EOI/Deactivate mode
[Tue Jan 26 20:42:25 2021] GICv3: 256 SPIs implemented
[Tue Jan 26 20:42:25 2021] GICv3: 0 Extended SPIs implemented
[Tue Jan 26 20:42:25 2021] GICv3: Distributor has no Range Selector support
[Tue Jan 26 20:42:25 2021] GICv3: 16 PPIs implemented
[Tue Jan 26 20:42:25 2021] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[Tue Jan 26 20:42:25 2021] ITS [mem 0xfee20000-0xfee3ffff]
[Tue Jan 26 20:42:25 2021] ITS@0x00000000fee20000: allocated 65536 Devices @40080000 (flat, esz 8, psz 64K, shr 0)
[Tue Jan 26 20:42:25 2021] ITS: using cache flushing for cmd queue
[Tue Jan 26 20:42:25 2021] GICv3: using LPI property table @0x0000000040040000
[Tue Jan 26 20:42:25 2021] GIC: using cache flushing for LPI property table
[Tue Jan 26 20:42:25 2021] GICv3: CPU0: using allocated LPI pending table @0x0000000040050000
[Tue Jan 26 20:42:25 2021] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[Tue Jan 26 20:42:25 2021] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[Tue Jan 26 20:42:25 2021] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[Tue Jan 26 20:42:25 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[Tue Jan 26 20:42:25 2021] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[Tue Jan 26 20:42:25 2021] Console: colour dummy device 80x25
[Tue Jan 26 20:42:25 2021] printk: console [tty1] enabled
[Tue Jan 26 20:42:25 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[Tue Jan 26 20:42:25 2021] pid_max: default: 32768 minimum: 301
[Tue Jan 26 20:42:25 2021] LSM: Security Framework initializing
[Tue Jan 26 20:42:25 2021] Yama: becoming mindful.
[Tue Jan 26 20:42:25 2021] AppArmor: AppArmor initialized
[Tue Jan 26 20:42:25 2021] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[Tue Jan 26 20:42:25 2021] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[Tue Jan 26 20:42:25 2021] rcu: Hierarchical SRCU implementation.
[Tue Jan 26 20:42:25 2021] Platform MSI: interrupt-controller@fee20000 domain created
[Tue Jan 26 20:42:25 2021] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[Tue Jan 26 20:42:25 2021] EFI services will not be available.
[Tue Jan 26 20:42:25 2021] smp: Bringing up secondary CPUs ...
[Tue Jan 26 20:42:25 2021] Detected VIPT I-cache on CPU1
[Tue Jan 26 20:42:25 2021] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[Tue Jan 26 20:42:25 2021] GICv3: CPU1: using allocated LPI pending table @0x0000000040060000
[Tue Jan 26 20:42:25 2021] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[Tue Jan 26 20:42:25 2021] Detected VIPT I-cache on CPU2
[Tue Jan 26 20:42:25 2021] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[Tue Jan 26 20:42:25 2021] GICv3: CPU2: using allocated LPI pending table @0x0000000040070000
[Tue Jan 26 20:42:25 2021] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[Tue Jan 26 20:42:25 2021] Detected VIPT I-cache on CPU3
[Tue Jan 26 20:42:25 2021] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[Tue Jan 26 20:42:25 2021] GICv3: CPU3: using allocated LPI pending table @0x0000000040100000
[Tue Jan 26 20:42:25 2021] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[Tue Jan 26 20:42:25 2021] CPU features: detected: Spectre-v2
[Tue Jan 26 20:42:25 2021] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[Tue Jan 26 20:42:25 2021] Detected PIPT I-cache on CPU4
[Tue Jan 26 20:42:25 2021] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[Tue Jan 26 20:42:25 2021] GICv3: CPU4: using allocated LPI pending table @0x0000000040110000
[Tue Jan 26 20:42:25 2021] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[Tue Jan 26 20:42:25 2021] Detected PIPT I-cache on CPU5
[Tue Jan 26 20:42:25 2021] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[Tue Jan 26 20:42:25 2021] GICv3: CPU5: using allocated LPI pending table @0x0000000040120000
[Tue Jan 26 20:42:25 2021] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[Tue Jan 26 20:42:25 2021] smp: Brought up 1 node, 6 CPUs
[Tue Jan 26 20:42:25 2021] SMP: Total of 6 processors activated.
[Tue Jan 26 20:42:25 2021] CPU features: detected: 32-bit EL0 Support
[Tue Jan 26 20:42:25 2021] CPU features: detected: CRC32 instructions
[Tue Jan 26 20:42:25 2021] CPU features: detected: 32-bit EL1 Support
[Tue Jan 26 20:42:25 2021] CPU: All CPU(s) started at EL2
[Tue Jan 26 20:42:25 2021] alternatives: patching kernel code
[Tue Jan 26 20:42:25 2021] devtmpfs: initialized
[Tue Jan 26 20:42:25 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[Tue Jan 26 20:42:25 2021] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[Tue Jan 26 20:42:25 2021] pinctrl core: initialized pinctrl subsystem
[Tue Jan 26 20:42:25 2021] DMI not present or invalid.
[Tue Jan 26 20:42:25 2021] NET: Registered protocol family 16
[Tue Jan 26 20:42:25 2021] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[Tue Jan 26 20:42:25 2021] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[Tue Jan 26 20:42:25 2021] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[Tue Jan 26 20:42:25 2021] audit: initializing netlink subsys (disabled)
[Tue Jan 26 20:42:25 2021] audit: type=2000 audit(0.070:1): state=initialized audit_enabled=0 res=1
[Tue Jan 26 20:42:25 2021] thermal_sys: Registered thermal governor 'fair_share'
[Tue Jan 26 20:42:25 2021] thermal_sys: Registered thermal governor 'bang_bang'
[Tue Jan 26 20:42:25 2021] thermal_sys: Registered thermal governor 'step_wise'
[Tue Jan 26 20:42:25 2021] thermal_sys: Registered thermal governor 'user_space'
[Tue Jan 26 20:42:25 2021] cpuidle: using governor ladder
[Tue Jan 26 20:42:25 2021] cpuidle: using governor menu
[Tue Jan 26 20:42:25 2021] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[Tue Jan 26 20:42:25 2021] ASID allocator initialised with 65536 entries
[Tue Jan 26 20:42:25 2021] Serial: AMBA PL011 UART driver
[Tue Jan 26 20:42:25 2021] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[Tue Jan 26 20:42:25 2021] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[Tue Jan 26 20:42:25 2021] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[Tue Jan 26 20:42:25 2021] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[Tue Jan 26 20:42:25 2021] cryptd: max_cpu_qlen set to 1000
[Tue Jan 26 20:42:25 2021] ACPI: Interpreter disabled.
[Tue Jan 26 20:42:25 2021] vcc_12v: supplied by vcc_sysin
[Tue Jan 26 20:42:25 2021] vcc3v3_sys: supplied by vcc_sysin
[Tue Jan 26 20:42:25 2021] vcc5v0_usb: supplied by vcc_sysin
[Tue Jan 26 20:42:25 2021] vcc_0v9: supplied by vcc3v3_sys
[Tue Jan 26 20:42:25 2021] vcca1v8_s3: supplied by vcc3v3_sys
[Tue Jan 26 20:42:25 2021] vcc3v0_sd: supplied by vcc3v3_sys
[Tue Jan 26 20:42:25 2021] vcc3v3_panel: supplied by vcc3v3_sys
[Tue Jan 26 20:42:25 2021] vcc3v3_ssd: supplied by vcc3v3_sys
[Tue Jan 26 20:42:25 2021] vcc5v0_otg: supplied by vcc5v0_usb
[Tue Jan 26 20:42:25 2021] vbus_5vout: supplied by vcc5v0_usb
[Tue Jan 26 20:42:25 2021] iommu: Default domain type: Translated
[Tue Jan 26 20:42:25 2021] vgaarb: loaded
[Tue Jan 26 20:42:25 2021] SCSI subsystem initialized
[Tue Jan 26 20:42:25 2021] libata version 3.00 loaded.
[Tue Jan 26 20:42:25 2021] usbcore: registered new interface driver usbfs
[Tue Jan 26 20:42:25 2021] usbcore: registered new interface driver hub
[Tue Jan 26 20:42:25 2021] usbcore: registered new device driver usb
[Tue Jan 26 20:42:25 2021] mc: Linux media interface: v0.10
[Tue Jan 26 20:42:25 2021] videodev: Linux video capture interface: v2.00
[Tue Jan 26 20:42:25 2021] pps_core: LinuxPPS API ver. 1 registered
[Tue Jan 26 20:42:25 2021] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[Tue Jan 26 20:42:25 2021] PTP clock support registered
[Tue Jan 26 20:42:25 2021] EDAC MC: Ver: 3.0.0
[Tue Jan 26 20:42:25 2021] Advanced Linux Sound Architecture Driver Initialized.
[Tue Jan 26 20:42:25 2021] NetLabel: Initializing
[Tue Jan 26 20:42:25 2021] NetLabel: domain hash size = 128
[Tue Jan 26 20:42:25 2021] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[Tue Jan 26 20:42:25 2021] NetLabel: unlabeled traffic allowed by default
[Tue Jan 26 20:42:25 2021] clocksource: Switched to clocksource arch_sys_counter
[Tue Jan 26 20:42:25 2021] VFS: Disk quotas dquot_6.6.0
[Tue Jan 26 20:42:25 2021] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[Tue Jan 26 20:42:25 2021] AppArmor: AppArmor Filesystem Enabled
[Tue Jan 26 20:42:25 2021] pnp: PnP ACPI: disabled
[Tue Jan 26 20:42:25 2021] NET: Registered protocol family 2
[Tue Jan 26 20:42:25 2021] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[Tue Jan 26 20:42:25 2021] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[Tue Jan 26 20:42:25 2021] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[Tue Jan 26 20:42:25 2021] TCP: Hash tables configured (established 32768 bind 32768)
[Tue Jan 26 20:42:25 2021] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[Tue Jan 26 20:42:25 2021] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[Tue Jan 26 20:42:25 2021] RPC: Registered named UNIX socket transport module.
[Tue Jan 26 20:42:25 2021] RPC: Registered udp transport module.
[Tue Jan 26 20:42:25 2021] RPC: Registered tcp transport module.
[Tue Jan 26 20:42:25 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Tue Jan 26 20:42:25 2021] PCI: CLS 0 bytes, default 64
[Tue Jan 26 20:42:25 2021] Trying to unpack rootfs image as initramfs...
[Tue Jan 26 20:42:25 2021] Freeing initrd memory: 6824K
[Tue Jan 26 20:42:25 2021] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[Tue Jan 26 20:42:25 2021] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[Tue Jan 26 20:42:25 2021] kvm [1]: IPA Size Limit: 40 bits
[Tue Jan 26 20:42:25 2021] kvm [1]: vgic-v2@fff20000
[Tue Jan 26 20:42:25 2021] kvm [1]: GIC system register CPU interface enabled
[Tue Jan 26 20:42:25 2021] kvm [1]: vgic interrupt IRQ18
[Tue Jan 26 20:42:25 2021] kvm [1]: Hyp mode initialized successfully
[Tue Jan 26 20:42:26 2021] Initialise system trusted keyrings
[Tue Jan 26 20:42:26 2021] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[Tue Jan 26 20:42:26 2021] zbud: loaded
[Tue Jan 26 20:42:26 2021] NFS: Registering the id_resolver key type
[Tue Jan 26 20:42:26 2021] Key type id_resolver registered
[Tue Jan 26 20:42:26 2021] Key type id_legacy registered
[Tue Jan 26 20:42:26 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[Tue Jan 26 20:42:26 2021] ntfs: driver 2.1.32 [Flags: R/W].
[Tue Jan 26 20:42:26 2021] fuse: init (API version 7.32)
[Tue Jan 26 20:42:26 2021] SGI XFS with ACLs, security attributes, quota, no debug enabled
[Tue Jan 26 20:42:26 2021] NET: Registered protocol family 38
[Tue Jan 26 20:42:26 2021] Key type asymmetric registered
[Tue Jan 26 20:42:26 2021] Asymmetric key parser 'x509' registered
[Tue Jan 26 20:42:26 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[Tue Jan 26 20:42:26 2021] io scheduler mq-deadline registered
[Tue Jan 26 20:42:26 2021] io scheduler kyber registered
[Tue Jan 26 20:42:26 2021] io scheduler bfq registered
[Tue Jan 26 20:42:26 2021] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[Tue Jan 26 20:42:26 2021] OF: /pcie@f8000000: Missing device_type
[Tue Jan 26 20:42:26 2021] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[Tue Jan 26 20:42:26 2021] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[Tue Jan 26 20:42:26 2021] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[Tue Jan 26 20:42:26 2021] IPMI message handler: version 39.2
[Tue Jan 26 20:42:26 2021] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[Tue Jan 26 20:42:26 2021] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[Tue Jan 26 20:42:26 2021] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[Tue Jan 26 20:42:26 2021] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[Tue Jan 26 20:42:26 2021] vdd_log: supplied by regulator-dummy
[Tue Jan 26 20:42:26 2021] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[Tue Jan 26 20:42:26 2021] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 46, base_baud = 1500000) is a 16550A
[Tue Jan 26 20:42:26 2021] serial serial0: tty port ttyS0 registered
[Tue Jan 26 20:42:26 2021] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 47, base_baud = 1500000) is a 16550A
[Tue Jan 26 20:42:26 2021] printk: console [ttyS2] enabled
[Tue Jan 26 20:42:26 2021] cacheinfo: Unable to detect cache hierarchy for CPU 0
[Tue Jan 26 20:42:26 2021] spi-nor spi0.0: gd25q128 (16384 Kbytes)
[Tue Jan 26 20:42:26 2021] libphy: Fixed MDIO Bus: probed
[Tue Jan 26 20:42:26 2021] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[Tue Jan 26 20:42:26 2021] ehci-pci: EHCI PCI platform driver
[Tue Jan 26 20:42:26 2021] ehci-platform: EHCI generic platform driver
[Tue Jan 26 20:42:26 2021] ehci-platform fe380000.usb: EHCI Host Controller
[Tue Jan 26 20:42:26 2021] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[Tue Jan 26 20:42:26 2021] ehci-platform fe380000.usb: irq 38, io mem 0xfe380000
[Tue Jan 26 20:42:26 2021] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[Tue Jan 26 20:42:26 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[Tue Jan 26 20:42:26 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:26 2021] usb usb1: Product: EHCI Host Controller
[Tue Jan 26 20:42:26 2021] usb usb1: Manufacturer: Linux 5.10.7-1-MANJARO-ARM ehci_hcd
[Tue Jan 26 20:42:26 2021] usb usb1: SerialNumber: fe380000.usb
[Tue Jan 26 20:42:26 2021] hub 1-0:1.0: USB hub found
[Tue Jan 26 20:42:26 2021] hub 1-0:1.0: 1 port detected
[Tue Jan 26 20:42:26 2021] ehci-platform fe3c0000.usb: EHCI Host Controller
[Tue Jan 26 20:42:26 2021] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[Tue Jan 26 20:42:26 2021] ehci-platform fe3c0000.usb: irq 40, io mem 0xfe3c0000
[Tue Jan 26 20:42:26 2021] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[Tue Jan 26 20:42:26 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[Tue Jan 26 20:42:26 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:26 2021] usb usb2: Product: EHCI Host Controller
[Tue Jan 26 20:42:26 2021] usb usb2: Manufacturer: Linux 5.10.7-1-MANJARO-ARM ehci_hcd
[Tue Jan 26 20:42:26 2021] usb usb2: SerialNumber: fe3c0000.usb
[Tue Jan 26 20:42:26 2021] hub 2-0:1.0: USB hub found
[Tue Jan 26 20:42:26 2021] hub 2-0:1.0: 1 port detected
[Tue Jan 26 20:42:26 2021] tegra-ehci: Tegra EHCI driver
[Tue Jan 26 20:42:26 2021] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[Tue Jan 26 20:42:26 2021] ohci-pci: OHCI PCI platform driver
[Tue Jan 26 20:42:26 2021] ohci-platform: OHCI generic platform driver
[Tue Jan 26 20:42:26 2021] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[Tue Jan 26 20:42:26 2021] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[Tue Jan 26 20:42:26 2021] ohci-platform fe3a0000.usb: irq 39, io mem 0xfe3a0000
[Tue Jan 26 20:42:26 2021] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[Tue Jan 26 20:42:26 2021] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:26 2021] usb usb3: Product: Generic Platform OHCI controller
[Tue Jan 26 20:42:26 2021] usb usb3: Manufacturer: Linux 5.10.7-1-MANJARO-ARM ohci_hcd
[Tue Jan 26 20:42:26 2021] usb usb3: SerialNumber: fe3a0000.usb
[Tue Jan 26 20:42:26 2021] hub 3-0:1.0: USB hub found
[Tue Jan 26 20:42:26 2021] hub 3-0:1.0: 1 port detected
[Tue Jan 26 20:42:26 2021] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[Tue Jan 26 20:42:26 2021] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[Tue Jan 26 20:42:26 2021] ohci-platform fe3e0000.usb: irq 41, io mem 0xfe3e0000
[Tue Jan 26 20:42:26 2021] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[Tue Jan 26 20:42:26 2021] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:26 2021] usb usb4: Product: Generic Platform OHCI controller
[Tue Jan 26 20:42:26 2021] usb usb4: Manufacturer: Linux 5.10.7-1-MANJARO-ARM ohci_hcd
[Tue Jan 26 20:42:26 2021] usb usb4: SerialNumber: fe3e0000.usb
[Tue Jan 26 20:42:26 2021] hub 4-0:1.0: USB hub found
[Tue Jan 26 20:42:26 2021] hub 4-0:1.0: 1 port detected
[Tue Jan 26 20:42:26 2021] uhci_hcd: USB Universal Host Controller Interface driver
[Tue Jan 26 20:42:26 2021] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[Tue Jan 26 20:42:26 2021] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[Tue Jan 26 20:42:26 2021] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[Tue Jan 26 20:42:26 2021] xhci-hcd xhci-hcd.0.auto: irq 76, io mem 0xfe900000
[Tue Jan 26 20:42:26 2021] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[Tue Jan 26 20:42:26 2021] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:26 2021] usb usb5: Product: xHCI Host Controller
[Tue Jan 26 20:42:26 2021] usb usb5: Manufacturer: Linux 5.10.7-1-MANJARO-ARM xhci-hcd
[Tue Jan 26 20:42:26 2021] usb usb5: SerialNumber: xhci-hcd.0.auto
[Tue Jan 26 20:42:26 2021] hub 5-0:1.0: USB hub found
[Tue Jan 26 20:42:26 2021] hub 5-0:1.0: 1 port detected
[Tue Jan 26 20:42:26 2021] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[Tue Jan 26 20:42:26 2021] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[Tue Jan 26 20:42:26 2021] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[Tue Jan 26 20:42:26 2021] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[Tue Jan 26 20:42:26 2021] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:26 2021] usb usb6: Product: xHCI Host Controller
[Tue Jan 26 20:42:26 2021] usb usb6: Manufacturer: Linux 5.10.7-1-MANJARO-ARM xhci-hcd
[Tue Jan 26 20:42:26 2021] usb usb6: SerialNumber: xhci-hcd.0.auto
[Tue Jan 26 20:42:26 2021] hub 6-0:1.0: USB hub found
[Tue Jan 26 20:42:26 2021] hub 6-0:1.0: 1 port detected
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver uas
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver usb-storage
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-alauda
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-cypress
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-datafab
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums_eneub6250
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-freecom
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-isd200
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-jumpshot
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-karma
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-onetouch
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-realtek
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-sddr09
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-sddr55
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver ums-usbat
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver usbserial_generic
[Tue Jan 26 20:42:26 2021] usbserial: USB Serial support registered for generic
[Tue Jan 26 20:42:26 2021] mousedev: PS/2 mouse device common for all mice
[Tue Jan 26 20:42:26 2021] rk808 0-001b: chip id: 0x0
[Tue Jan 26 20:42:26 2021] rk808-regulator rk808-regulator: there is no dvs0 gpio
[Tue Jan 26 20:42:26 2021] rk808-regulator rk808-regulator: there is no dvs1 gpio
[Tue Jan 26 20:42:26 2021] vdd_center: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vdd_cpu_l: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcc_ddr: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcc_1v8: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] LDO_REG1: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] LDO_REG2: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcc1v8_pmupll: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV
[Tue Jan 26 20:42:26 2021] vcc_sdio: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcca3v0_codec: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcc_1v5: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcca1v8_codec: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcc_3v0: supplied by vcc_sysin
[Tue Jan 26 20:42:26 2021] vcc3v3_s3: supplied by vcc3v3_sys
[Tue Jan 26 20:42:26 2021] vcc3v3_s0: supplied by vcc3v3_sys
[Tue Jan 26 20:42:26 2021] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[Tue Jan 26 20:42:26 2021] vcc0v9_s3: supplied by vcc_1v8
[Tue Jan 26 20:42:26 2021] vdd_cpu_b: supplied by vcc_1v8
[Tue Jan 26 20:42:26 2021] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[Tue Jan 26 20:42:26 2021] vdd_gpu: supplied by vcc_1v8
[Tue Jan 26 20:42:26 2021] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[Tue Jan 26 20:42:26 2021] random: fast init done
[Tue Jan 26 20:42:26 2021] device-mapper: uevent: version 1.0.3
[Tue Jan 26 20:42:26 2021] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[Tue Jan 26 20:42:26 2021] cpu cpu0: EM: hertz/watts ratio non-monotonically decreasing: em_perf_state 1 >= em_perf_state0
[Tue Jan 26 20:42:26 2021] cpu cpu0: EM: created perf domain
[Tue Jan 26 20:42:26 2021] cpu cpu4: EM: created perf domain
[Tue Jan 26 20:42:26 2021] sdhci: Secure Digital Host Controller Interface driver
[Tue Jan 26 20:42:26 2021] sdhci: Copyright(c) Pierre Ossman
[Tue Jan 26 20:42:26 2021] Synopsys Designware Multimedia Card Interface Driver
[Tue Jan 26 20:42:26 2021] sdhci-pltfm: SDHCI platform and OF driver helper
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe310000.mmc: Version ID is 270a
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
[Tue Jan 26 20:42:26 2021] mmc_host mmc0: card is non-removable.
[Tue Jan 26 20:42:26 2021] ledtrig-cpu: registered to indicate activity on CPUs
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[Tue Jan 26 20:42:26 2021] mmc2: CQHCI version 5.10
[Tue Jan 26 20:42:26 2021] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[Tue Jan 26 20:42:26 2021] hid: raw HID events driver (C) Jiri Kosina
[Tue Jan 26 20:42:26 2021] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[Tue Jan 26 20:42:26 2021] usbcore: registered new interface driver usbhid
[Tue Jan 26 20:42:26 2021] usbhid: USB HID core driver
[Tue Jan 26 20:42:26 2021] ashmem: initialized
[Tue Jan 26 20:42:26 2021] Initializing XFRM netlink socket
[Tue Jan 26 20:42:26 2021] NET: Registered protocol family 10
[Tue Jan 26 20:42:26 2021] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[Tue Jan 26 20:42:26 2021] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[Tue Jan 26 20:42:26 2021] Segment Routing with IPv6
[Tue Jan 26 20:42:26 2021] mip6: Mobile IPv6
[Tue Jan 26 20:42:26 2021] NET: Registered protocol family 17
[Tue Jan 26 20:42:26 2021] Key type dns_resolver registered
[Tue Jan 26 20:42:26 2021] registered taskstats version 1
[Tue Jan 26 20:42:26 2021] Loading compiled-in X.509 certificates
[Tue Jan 26 20:42:26 2021] zswap: loaded using pool lzo/zbud
[Tue Jan 26 20:42:26 2021] debug_vm_pgtable: [debug_vm_pgtable ]: Validating architecture page table helpers
[Tue Jan 26 20:42:26 2021] Key type ._fscrypt registered
[Tue Jan 26 20:42:26 2021] Key type .fscrypt registered
[Tue Jan 26 20:42:26 2021] Key type fscrypt-provisioning registered
[Tue Jan 26 20:42:26 2021] Key type encrypted registered
[Tue Jan 26 20:42:26 2021] mmc2: Command Queue Engine enabled
[Tue Jan 26 20:42:26 2021] mmc2: new HS200 MMC card at address 0001
[Tue Jan 26 20:42:26 2021] mmcblk2: mmc2:0001 DA4064 58.2 GiB
[Tue Jan 26 20:42:26 2021] mmcblk2boot0: mmc2:0001 DA4064 partition 1 4.00 MiB
[Tue Jan 26 20:42:26 2021] mmcblk2boot1: mmc2:0001 DA4064 partition 2 4.00 MiB
[Tue Jan 26 20:42:26 2021] mmcblk2rpmb: mmc2:0001 DA4064 partition 3 16.0 MiB, chardev (236:0)
[Tue Jan 26 20:42:26 2021] mmcblk2: p1 p2
[Tue Jan 26 20:42:26 2021] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[Tue Jan 26 20:42:26 2021] usb 2-1: new high-speed USB device number 2 using ehci-platform
[Tue Jan 26 20:42:26 2021] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[Tue Jan 26 20:42:26 2021] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[Tue Jan 26 20:42:26 2021] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[Tue Jan 26 20:42:26 2021] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[Tue Jan 26 20:42:26 2021] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[Tue Jan 26 20:42:26 2021] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[Tue Jan 26 20:42:26 2021] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Tue Jan 26 20:42:26 2021] usb 2-1: Product: USB2.0 Hub
[Tue Jan 26 20:42:26 2021] hub 2-1:1.0: USB hub found
[Tue Jan 26 20:42:26 2021] hub 2-1:1.0: 4 ports detected
[Tue Jan 26 20:42:26 2021] usb 3-1: new low-speed USB device number 2 using ohci-platform
[Tue Jan 26 20:42:27 2021] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[Tue Jan 26 20:42:27 2021] rockchip-pcie: probe of f8000000.pcie failed with error -110
[Tue Jan 26 20:42:27 2021] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[Tue Jan 26 20:42:27 2021] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[Tue Jan 26 20:42:27 2021] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[Tue Jan 26 20:42:27 2021] xhci-hcd xhci-hcd.1.auto: irq 75, io mem 0xfe800000
[Tue Jan 26 20:42:27 2021] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[Tue Jan 26 20:42:27 2021] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:27 2021] usb usb7: Product: xHCI Host Controller
[Tue Jan 26 20:42:27 2021] usb usb7: Manufacturer: Linux 5.10.7-1-MANJARO-ARM xhci-hcd
[Tue Jan 26 20:42:27 2021] usb usb7: SerialNumber: xhci-hcd.1.auto
[Tue Jan 26 20:42:27 2021] hub 7-0:1.0: USB hub found
[Tue Jan 26 20:42:27 2021] hub 7-0:1.0: 1 port detected
[Tue Jan 26 20:42:27 2021] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[Tue Jan 26 20:42:27 2021] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[Tue Jan 26 20:42:27 2021] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[Tue Jan 26 20:42:27 2021] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[Tue Jan 26 20:42:27 2021] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jan 26 20:42:27 2021] usb usb8: Product: xHCI Host Controller
[Tue Jan 26 20:42:27 2021] usb usb8: Manufacturer: Linux 5.10.7-1-MANJARO-ARM xhci-hcd
[Tue Jan 26 20:42:27 2021] usb usb8: SerialNumber: xhci-hcd.1.auto
[Tue Jan 26 20:42:27 2021] hub 8-0:1.0: USB hub found
[Tue Jan 26 20:42:27 2021] hub 8-0:1.0: 1 port detected
[Tue Jan 26 20:42:27 2021] ALSA device list:
[Tue Jan 26 20:42:27 2021] No soundcards found.
[Tue Jan 26 20:42:27 2021] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[Tue Jan 26 20:42:27 2021] Freeing unused kernel memory: 4096K
[Tue Jan 26 20:42:27 2021] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
[Tue Jan 26 20:42:27 2021] usb 3-1: New USB device found, idVendor=258a, idProduct=001e, bcdDevice= 0.01
[Tue Jan 26 20:42:27 2021] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=255
[Tue Jan 26 20:42:27 2021] usb 3-1: Product: Pinebook Pro
[Tue Jan 26 20:42:27 2021] usb 3-1: Manufacturer: Pine64
[Tue Jan 26 20:42:27 2021] usb 3-1: SerialNumber: ANSI 0.1
[Tue Jan 26 20:42:27 2021] input: Pine64 Pinebook Pro as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:258A:001E.0001/input/input0
[Tue Jan 26 20:42:27 2021] Run /init as init process
[Tue Jan 26 20:42:27 2021] with arguments:
[Tue Jan 26 20:42:27 2021] /init
[Tue Jan 26 20:42:27 2021] with environment:
[Tue Jan 26 20:42:27 2021] HOME=/
[Tue Jan 26 20:42:27 2021] TERM=linux
[Tue Jan 26 20:42:27 2021] hid-generic 0003:258A:001E.0001: input,hidraw0: USB HID v1.10 Keyboard [Pine64 Pinebook Pro] on usb-fe3a0000.usb-1/input0
[Tue Jan 26 20:42:27 2021] input: Pine64 Pinebook Pro Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input1
[Tue Jan 26 20:42:27 2021] input: Pine64 Pinebook Pro Touchpad as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input2
[Tue Jan 26 20:42:27 2021] input: Pine64 Pinebook Pro System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input3
[Tue Jan 26 20:42:27 2021] usb 2-1.1: New USB device found, idVendor=214b, idProduct=7000, bcdDevice= 1.00
[Tue Jan 26 20:42:27 2021] usb 2-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Tue Jan 26 20:42:27 2021] usb 2-1.1: Product: USB2.0 HUB
[Tue Jan 26 20:42:27 2021] hub 2-1.1:1.0: USB hub found
[Tue Jan 26 20:42:27 2021] hub 2-1.1:1.0: 4 ports detected
[Tue Jan 26 20:42:27 2021] input: Pine64 Pinebook Pro Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input4
[Tue Jan 26 20:42:27 2021] input: Pine64 Pinebook Pro Wireless Radio Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/in>
[Tue Jan 26 20:42:27 2021] hid-multitouch 0003:258A:001E.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [Pine64 Pinebook Pro] on usb-fe3a0000.usb-1/input1
[Tue Jan 26 20:42:27 2021] usb 2-1.2: new high-speed USB device number 4 using ehci-platform
[Tue Jan 26 20:42:27 2021] input: gpio-key-lid as /devices/platform/gpio-key-lid/input/input6
[Tue Jan 26 20:42:27 2021] input: gpio-key-power as /devices/platform/gpio-key-power/input/input7
[Tue Jan 26 20:42:27 2021] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 51
[Tue Jan 26 20:42:27 2021] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[Tue Jan 26 20:42:27 2021] usb 2-1.2: New USB device found, idVendor=0c45, idProduct=6321, bcdDevice= 0.00
[Tue Jan 26 20:42:27 2021] usb 2-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[Tue Jan 26 20:42:27 2021] usb 2-1.2: Product: USB Camera
[Tue Jan 26 20:42:27 2021] usb 2-1.2: Manufacturer: Sonix Technology Co., Ltd.
[Tue Jan 26 20:42:27 2021] usb 2-1.1.3: new full-speed USB device number 5 using ehci-platform
[Tue Jan 26 20:42:27 2021] usb 2-1.1.3: New USB device found, idVendor=04d9, idProduct=0024, bcdDevice= 2.00
[Tue Jan 26 20:42:27 2021] usb 2-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Tue Jan 26 20:42:27 2021] usb 2-1.1.3: Product: USB Gaming Keyboard
[Tue Jan 26 20:42:27 2021] usb 2-1.1.3: Manufacturer: HOLDCHIP
[Tue Jan 26 20:42:27 2021] input: HOLDCHIP USB Gaming Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.3/2-1.1.3:1.0/0003:04D9:0024.0003/inpu>
[Tue Jan 26 20:42:27 2021] hid-generic 0003:04D9:0024.0003: input,hidraw2: USB HID v1.10 Keyboard [HOLDCHIP USB Gaming Keyboard] on usb-fe3c0000.usb-1.1.3/i>
[Tue Jan 26 20:42:27 2021] input: HOLDCHIP USB Gaming Keyboard System Control as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.3/2-1.1.3:1.1/0003:04D9>
[Tue Jan 26 20:42:28 2021] input: HOLDCHIP USB Gaming Keyboard Consumer Control as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.3/2-1.1.3:1.1/0003:04>
[Tue Jan 26 20:42:28 2021] input: HOLDCHIP USB Gaming Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.3/2-1.1.3:1.1/0003:04D9:0024.0004/inpu>
[Tue Jan 26 20:42:28 2021] hid-generic 0003:04D9:0024.0004: input,hidraw3: USB HID v1.10 Keyboard [HOLDCHIP USB Gaming Keyboard] on usb-fe3c0000.usb-1.1.3/i>
[Tue Jan 26 20:42:28 2021] hid-generic 0003:04D9:0024.0005: hiddev97,hidraw4: USB HID v1.10 Device [HOLDCHIP USB Gaming Keyboard] on usb-fe3c0000.usb-1.1.3/>
[Tue Jan 26 20:42:28 2021] usb 2-1.1.4: new full-speed USB device number 6 using ehci-platform
[Tue Jan 26 20:42:28 2021] usb 2-1.1.4: New USB device found, idVendor=046d, idProduct=c08b, bcdDevice=27.03
[Tue Jan 26 20:42:28 2021] usb 2-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Tue Jan 26 20:42:28 2021] usb 2-1.1.4: Product: G502 HERO Gaming Mouse
[Tue Jan 26 20:42:28 2021] usb 2-1.1.4: Manufacturer: Logitech
[Tue Jan 26 20:42:28 2021] usb 2-1.1.4: SerialNumber: 077E39723831
[Tue Jan 26 20:42:28 2021] input: Logitech G502 HERO Gaming Mouse as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.0/0003:046D:C08B.0006/i>
[Tue Jan 26 20:42:28 2021] hid-generic 0003:046D:C08B.0006: input,hidraw5: USB HID v1.11 Mouse [Logitech G502 HERO Gaming Mouse] on usb-fe3c0000.usb-1.1.4/i>
[Tue Jan 26 20:42:28 2021] input: Logitech G502 HERO Gaming Mouse Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.1/0003:046D:C0>
[Tue Jan 26 20:42:28 2021] input: Logitech G502 HERO Gaming Mouse Consumer Control as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.1/0003>
[Tue Jan 26 20:42:28 2021] input: Logitech G502 HERO Gaming Mouse System Control as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.1/0003:0>
[Tue Jan 26 20:42:28 2021] hid-generic 0003:046D:C08B.0007: input,hiddev98,hidraw6: USB HID v1.11 Keyboard [Logitech G502 HERO Gaming Mouse] on usb-fe3c0000>
[Tue Jan 26 20:42:28 2021] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
[Tue Jan 26 20:42:29 2021] systemd[1]: System time before build time, advancing clock.
[Tue Jan 26 20:42:29 2021] systemd[1]: systemd 247.2-1-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSET>
[Tue Jan 26 20:42:29 2021] systemd[1]: Detected architecture arm64.
[Tue Jan 26 20:42:29 2021] systemd[1]: Set hostname to <pbp>.
[Tue Jan 26 20:42:29 2021] systemd[1]: Queued start job for default target Graphical Interface.
[Tue Jan 26 20:42:29 2021] random: systemd: uninitialized urandom read (16 bytes read)
[Tue Jan 26 20:42:29 2021] systemd[1]: Created slice system-getty.slice.
[Tue Jan 26 20:42:29 2021] systemd[1]: Created slice system-modprobe.slice.
[Tue Jan 26 20:42:29 2021] systemd[1]: Created slice system-serial\x2dgetty.slice.
[Tue Jan 26 20:42:29 2021] systemd[1]: Created slice User and Session Slice.
[Tue Jan 26 20:42:29 2021] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[Tue Jan 26 20:42:29 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[Tue Jan 26 20:42:29 2021] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[Tue Jan 26 20:42:29 2021] systemd[1]: Reached target Local Encrypted Volumes.
[Tue Jan 26 20:42:29 2021] systemd[1]: Reached target Paths.
[Tue Jan 26 20:42:30 2021] systemd[1]: Reached target Remote Encrypted Volumes.
[Tue Jan 26 20:42:30 2021] systemd[1]: Reached target Remote File Systems.
[Tue Jan 26 20:42:30 2021] systemd[1]: Reached target Slices.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on LVM2 metadata daemon socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on LVM2 poll daemon socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on Process Core Dump Socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on Journal Audit Socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on Journal Socket (/dev/log).
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on Journal Socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on Network Service Netlink Socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on udev Control Socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Listening on udev Kernel Socket.
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounting binderfs...
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounting Huge Pages File System...
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounting POSIX Message Queue File System...
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounting Kernel Debug File System...
[Tue Jan 26 20:42:30 2021] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Create list of static device nodes for the current kernel...
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Load Kernel Module configfs...
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Load Kernel Module drm...
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Load Kernel Module fuse...
[Tue Jan 26 20:42:30 2021] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Load Kernel Modules...
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Remount Root and Kernel File Systems...
[Tue Jan 26 20:42:30 2021] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Coldplug All udev Devices...
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounted binderfs.
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounted Huge Pages File System.
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounted POSIX Message Queue File System.
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounted Kernel Debug File System.
[Tue Jan 26 20:42:30 2021] systemd[1]: Finished Create list of static device nodes for the current kernel.
[Tue Jan 26 20:42:30 2021] systemd[1]: modprobe@configfs.service: Succeeded.
[Tue Jan 26 20:42:30 2021] systemd[1]: Finished Load Kernel Module configfs.
[Tue Jan 26 20:42:30 2021] systemd[1]: modprobe@drm.service: Succeeded.
[Tue Jan 26 20:42:30 2021] systemd[1]: Finished Load Kernel Module drm.
[Tue Jan 26 20:42:30 2021] systemd[1]: modprobe@fuse.service: Succeeded.
[Tue Jan 26 20:42:30 2021] systemd[1]: Finished Load Kernel Module fuse.
[Tue Jan 26 20:42:30 2021] systemd[1]: Finished Load Kernel Modules.
[Tue Jan 26 20:42:30 2021] systemd[1]: Finished Remount Root and Kernel File Systems.
[Tue Jan 26 20:42:30 2021] systemd[1]: Activating swap /swapfile...
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounting FUSE Control File System...
[Tue Jan 26 20:42:30 2021] systemd[1]: Mounting Kernel Configuration File System...
[Tue Jan 26 20:42:30 2021] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[Tue Jan 26 20:42:30 2021] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[Tue Jan 26 20:42:30 2021] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Load/Save Random Seed...
[Tue Jan 26 20:42:30 2021] Adding 4194300k swap on /swapfile. Priority:-2 extents:35 across:8175616k SSFS
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Apply Kernel Variables...
[Tue Jan 26 20:42:30 2021] systemd[1]: Condition check resulted in Create System Users being skipped.
[Tue Jan 26 20:42:30 2021] systemd[1]: Starting Create Static Device Nodes in /dev...
[Tue Jan 26 20:42:30 2021] systemd[1]: Activated swap /swapfile.
[Tue Jan 26 20:42:30 2021] systemd[1]: Finished Coldplug All udev Devices.
[Tue Jan 26 20:42:31 2021] systemd[1]: Mounted FUSE Control File System.
[Tue Jan 26 20:42:31 2021] systemd[1]: Mounted Kernel Configuration File System.
[Tue Jan 26 20:42:31 2021] systemd[1]: Finished Apply Kernel Variables.
[Tue Jan 26 20:42:31 2021] systemd[1]: Finished Create Static Device Nodes in /dev.
[Tue Jan 26 20:42:31 2021] systemd[1]: Reached target Swap.
[Tue Jan 26 20:42:31 2021] systemd[1]: Mounting Temporary Directory (/tmp)...
[Tue Jan 26 20:42:31 2021] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[Tue Jan 26 20:42:31 2021] systemd[1]: Starting Journal Service...
[Tue Jan 26 20:42:31 2021] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[Tue Jan 26 20:42:31 2021] systemd[1]: Mounted Temporary Directory (/tmp).
[Tue Jan 26 20:42:31 2021] systemd[1]: Started Journal Service.
[Tue Jan 26 20:42:31 2021] audit: type=1130 audit(1608522712.260:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald >
[Tue Jan 26 20:42:31 2021] audit: type=1130 audit(1608522712.260:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd com>
[Tue Jan 26 20:42:31 2021] audit: type=1130 audit(1608522712.300:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm>
[Tue Jan 26 20:42:31 2021] random: crng init done
[Tue Jan 26 20:42:31 2021] random: 7 urandom warning(s) missed due to ratelimiting
[Tue Jan 26 20:42:31 2021] es8316 1-0011: Failed to get IRQ 0: -22
[Tue Jan 26 20:42:31 2021] audit: type=1130 audit(1608522712.660:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-se>
[Tue Jan 26 20:42:31 2021] audit: type=1130 audit(1608522712.690:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-networkd >
[Tue Jan 26 20:42:31 2021] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[Tue Jan 26 20:42:31 2021] cfg80211: failed to load regulatory.db
[Tue Jan 26 20:42:31 2021] rk808-rtc rk808-rtc: registered as rtc0
[Tue Jan 26 20:42:31 2021] rk808-rtc rk808-rtc: setting system clock to 2021-01-26T19:39:28 UTC (1611689968)
[Tue Jan 26 20:42:31 2021] power_supply cw2015-battery: cw2015-battery: Found supply : tcpm-source-psy-4-0022
[Tue Jan 26 20:42:31 2021] power_supply cw2015-battery: cw2015-battery: Found supply : dc-charger
[Tue Jan 26 20:42:31 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[Tue Jan 26 20:42:31 2021] usbcore: registered new interface driver brcmfmac
[Tue Jan 26 20:42:31 2021] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[Tue Jan 26 20:42:31 2021] rkvdec ff660000.video-codec: Adding to iommu group 1
[Tue Jan 26 20:42:31 2021] rockchip-rga ff680000.rga: HW Version: 0x03.02
[Tue Jan 26 20:42:31 2021] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[Tue Jan 26 20:42:31 2021] dw_wdt ff848000.watchdog: No valid TOPs array specified
[Tue Jan 26 20:42:31 2021] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[Tue Jan 26 20:42:31 2021] Bluetooth: Core ver 2.22
[Tue Jan 26 20:42:31 2021] NET: Registered protocol family 31
[Tue Jan 26 20:42:31 2021] Bluetooth: HCI device and connection manager initialized
[Tue Jan 26 20:42:31 2021] Bluetooth: HCI socket layer initialized
[Tue Jan 26 20:42:31 2021] Bluetooth: L2CAP socket layer initialized
[Tue Jan 26 20:42:31 2021] Bluetooth: SCO socket layer initialized
[Tue Jan 26 20:42:31 2021] panfrost ff9a0000.gpu: clock rate = 500000000
[Tue Jan 26 20:42:31 2021] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[Tue Jan 26 20:42:31 2021] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[Tue Jan 26 20:42:31 2021] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[Tue Jan 26 20:42:31 2021] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[Tue Jan 26 20:42:31 2021] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[Tue Jan 26 20:42:31 2021] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
[Tue Jan 26 20:42:31 2021] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[Tue Jan 26 20:42:31 2021] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
[Tue Jan 26 20:42:32 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[Tue Jan 26 20:42:32 2021] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
[Tue Jan 26 20:42:32 2021] rockchip-vop ff900000.vop: Adding to iommu group 3
[Tue Jan 26 20:42:32 2021] rockchip-dp ff970000.edp: no DP phy configured
[Tue Jan 26 20:42:32 2021] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[Tue Jan 26 20:42:32 2021] [drm] unsupported AFBC format[3231564e]
[Tue Jan 26 20:42:32 2021] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[Tue Jan 26 20:42:32 2021] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops [rockchipdrm])
[Tue Jan 26 20:42:32 2021] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[Tue Jan 26 20:42:32 2021] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART driver ver 2.3
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol H4 registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol BCSP registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol LL registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol ATH3K registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol Intel registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol Broadcom registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol QCA registered
[Tue Jan 26 20:42:32 2021] Bluetooth: HCI UART protocol Marvell registered
[Tue Jan 26 20:42:32 2021] bootsplash: Loading splash file (606512 bytes)
[Tue Jan 26 20:42:32 2021] bootsplash: Loaded (606512 bytes, 2 pics, 76 blobs).
[Tue Jan 26 20:42:32 2021] asoc-simple-card es8316-sound: ASoC: no DMI vendor name!
[Tue Jan 26 20:42:32 2021] input: rockchip,es8316-codec Headphones as /devices/platform/es8316-sound/sound/card0/input18
[Tue Jan 26 20:42:32 2021] dw-apb-uart ff180000.serial: failed to request DMA
[Tue Jan 26 20:42:32 2021] Console: switching to colour frame buffer device 240x67
[Tue Jan 26 20:42:32 2021] Bluetooth: hci1: BCM: chip id 130
[Tue Jan 26 20:42:32 2021] Bluetooth: hci1: BCM: features 0x0f
[Tue Jan 26 20:42:32 2021] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[Tue Jan 26 20:42:32 2021] audit: type=1130 audit(1611689969.210:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-f>
[Tue Jan 26 20:42:32 2021] Bluetooth: hci1: BCM4345C5
[Tue Jan 26 20:42:32 2021] Bluetooth: hci1: BCM4345C5 (003.006.006) build 0000
[Tue Jan 26 20:42:32 2021] Bluetooth: hci1: BCM4345C5 'brcm/BCM4345C5.hcd' Patch
[Tue Jan 26 20:42:32 2021] audit: type=1130 audit(1611689969.240:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm>
[Tue Jan 26 20:42:32 2021] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[Tue Jan 26 20:42:32 2021] FAT-fs (mmcblk2p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[Tue Jan 26 20:42:32 2021] audit: type=1130 audit(1611689969.510:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight>
[Tue Jan 26 20:42:33 2021] audit: type=1130 audit(1611689969.610:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill c>
[Tue Jan 26 20:42:33 2021] audit: type=1130 audit(1611689969.640:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles>
[Tue Jan 26 20:42:33 2021] Bluetooth: hci1: BCM4345C5 Ampak_CL1.5 UART 37.4 MHz BT 5.0 [Version: Version: 0033.0080]
[Tue Jan 26 20:42:33 2021] Bluetooth: hci1: BCM4345C5 (003.006.006) build 0080
[Tue Jan 26 20:42:33 2021] rd 0-5: Disabling EAS, schedutil is mandatory
[Tue Jan 26 20:42:33 2021] zram: Added device: zram0
[Tue Jan 26 20:42:34 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID >
[Tue Jan 26 20:42:34 2021] zram0: detected capacity change from 0 to 4976533504
[Tue Jan 26 20:42:34 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[Tue Jan 26 20:42:34 2021] Bluetooth: BNEP filters: protocol multicast
[Tue Jan 26 20:42:34 2021] Bluetooth: BNEP socket layer initialized
[Tue Jan 26 20:42:34 2021] Adding 4859892k swap on /dev/zram0. Priority:5 extents:1 across:4859892k SSFS
[Tue Jan 26 20:42:34 2021] bpfilter: Loaded bpfilter_umh pid 834
[Tue Jan 26 20:42:34 2021] Started bpfilter
[Tue Jan 26 20:42:34 2021] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need th>
[Tue Jan 26 20:42:34 2021] uvcvideo: Found UVC 1.00 device USB Camera (0c45:6321)
[Tue Jan 26 20:42:34 2021] input: USB Camera: USB Camera as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.2/2-1.2:1.0/input/input19
[Tue Jan 26 20:42:34 2021] usbcore: registered new interface driver uvcvideo
[Tue Jan 26 20:42:34 2021] USB Video Class driver (1.1.1)
[Tue Jan 26 20:42:35 2021] ieee80211 phy0: brcmf_netdev_set_mac_address: Setting cur_etheraddr failed, -52
[Tue Jan 26 20:42:35 2021] loop: module loaded
[Tue Jan 26 20:42:35 2021] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[Tue Jan 26 20:42:36 2021] kauditd_printk_skb: 37 callbacks suppressed
[Tue Jan 26 20:42:36 2021] audit: type=1130 audit(1611690090.163:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="system>
[Tue Jan 26 20:42:38 2021] audit: type=1100 audit(1611690091.713:50): pid=1076 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authenticat>
[Tue Jan 26 20:42:38 2021] audit: type=1101 audit(1611690091.723:51): pid=1076 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting >
[Tue Jan 26 20:42:38 2021] audit: type=1103 audit(1611690091.723:52): pid=1076 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred gra>
[Tue Jan 26 20:42:38 2021] audit: type=1130 audit(1611690091.873:53): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir>
[Tue Jan 26 20:42:38 2021] audit: type=1101 audit(1611690091.943:54): pid=1078 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting >
[Tue Jan 26 20:42:38 2021] audit: type=1103 audit(1611690091.943:55): pid=1078 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred gra>
[Tue Jan 26 20:42:38 2021] audit: type=1006 audit(1611690091.943:56): pid=1078 uid=0 subj==unconfined old-auid=4294967295 auid=974 tty=(none) old-ses=429496>
[Tue Jan 26 20:42:38 2021] audit: type=1105 audit(1611690091.953:57): pid=1078 uid=0 auid=974 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_l>
[Tue Jan 26 20:42:38 2021] audit: type=1334 audit(1611690091.973:58): prog-id=11 op=LOAD
[Tue Jan 26 20:42:45 2021] kauditd_printk_skb: 9 callbacks suppressed
[Tue Jan 26 20:42:45 2021] audit: type=1131 audit(1611690098.393:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-d>
[Tue Jan 26 20:42:45 2021] audit: type=1130 audit(1611690098.963:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bootsplash-hide->
[Tue Jan 26 20:42:45 2021] audit: type=1131 audit(1611690098.963:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bootsplash-hide->
[Tue Jan 26 20:42:57 2021] vcc3v3_ssd: disabling
[Tue Jan 26 20:42:57 2021] vbus_5vout: disabling
[Tue Jan 26 20:42:57 2021] vcc0v9_s3: disabling
[Tue Jan 26 20:42:57 2021] LDO_REG1: disabling
[Tue Jan 26 20:43:04 2021] audit: type=1131 audit(1611690117.963:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostname>
[Tue Jan 26 20:43:04 2021] audit: type=1334 audit(1611690118.263:72): prog-id=10 op=UNLOAD
[Tue Jan 26 20:43:04 2021] audit: type=1334 audit(1611690118.263:73): prog-id=9 op=UNLOAD
