For about a month now I’ve not been able to use the sleep mode on my computer.
Instead I have to actually shutdown.
Here’s some information about the system:
Running: inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.16.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=5bb1cf9a-2580-4843-afbf-e9bc53c81ed8 rw quiet
resume=UUID=9488fea2-c220-490c-b1df-5846836360eb udev.log_priority=3
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z270X-Ultra Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z270X-Ultra Gaming-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F9d
date: 03/09/2018
Device-1: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 23.43 GiB used: 4.26 GiB (18.2%)
RAM Report:
Info: model: Intel Core i5-7600K bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 30409
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-2: Trust USB Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-8:3 chip-ID: 145f:0203 class-ID: 0102
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 156 s-size: 625x352mm (24.61x13.86")
s-diag: 717mm (28.24")
Monitor-1: DP-0 pos: primary res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.58") diag: 698mm (27.49") modes: N/A
Monitor-2: HDMI-1 size-res: N/A modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:4 chip-ID: 0c76:161e
class-ID: 0300
Device-4: Trust USB Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.16.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-a7bbaafbade9 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: br-e22b7b618935 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth17cba1c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth4d03414 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: vethab86e98 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-7:8 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 3.3 TiB used: 852.97 GiB (25.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS128GMTS400S
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6B scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500LM000-SSHD-8GB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: LVD6 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ01ABD075
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1U scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.93 GiB (97.93%) used: 72.76 GiB (74.3%)
fs: ext4 dev: /dev/sde2 maj-min: 8:66 label: N/A
uuid: 5bb1cf9a-2580-4843-afbf-e9bc53c81ed8
used: 332 KiB (0.1%) fs: vfat dev: /dev/sde4 maj-min: 8:68 label: N/A
uuid: 9181-45EA
ID-3: /home raw-size: 128.38 GiB size: 125.37 GiB (97.65%)
used: 56.67 GiB (45.2%) fs: ext4 dev: /dev/sde3 maj-min: 8:67 label: N/A
uuid: 84312cb6-6779-4545-9ec2-28b139a83d95
ID-4: /mnt/storage raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
used: 325.99 GiB (17.8%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
label: storage uuid: 13e5178d-e42f-45ce-8ec5-72d9a980da0c
ID-5: /mnt/timeshift raw-size: 698.63 GiB size: 686.67 GiB (98.29%)
used: 397.55 GiB (57.9%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
label: Timeshift uuid: 1ba35f37-37ef-4eb8-be74-33ba70cd8f8a
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sde1 maj-min: 8:65 label: N/A
uuid: 9488fea2-c220-490c-b1df-5846836360eb
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 7664-5584
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 118.64 GiB fs: ntfs label: N/A
uuid: 488A79078A78F2B4
ID-4: /dev/sda4 maj-min: 8:4 size: 499 MiB fs: ntfs label: N/A
uuid: 72C4E6C8C4E68DA3
ID-5: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ntfs label: Games
uuid: DA6A42046A41DDBF
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-7:8 info: ASUSTek Broadcom BCM20702A0 Bluetooth
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Device-2: 1-8:3 info: Trust USB Camera type: Video,Audio
power: 500mA chip-ID: 145f:0203 class-ID: 0102
Device-3: 1-10:4 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:161e class-ID: 0300
Device-4: 1-13:5 info: Logitech USB Receiver type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c545 class-ID: 0300
Device-5: 1-14:7 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 50 C
Processes: 379 Uptime: 10h 7m wakeups: 38 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1482
pacman: 1453 lib: 451 flatpak: 29 Shell: fish v: 3.4.1 default: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.15
using systemctl suspend give no output.
Doing this sudo dmesg | tail --lines=50 give the following output
[36719.259701] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT0._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36719.259706] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36719.259795] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36719.259800] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36719.259988] ata3.00: configured for UDMA/133
[36719.260238] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT0._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36719.260243] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36719.260568] ata1.00: configured for UDMA/133
[36719.262362] ata2: SATA link down (SStatus 4 SControl 300)
[36719.262405] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[36719.262555] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT5._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36719.262558] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT5._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36719.262607] ata6.00: supports DRM functions and may not be fully accessible
[36719.263144] ata6.00: disabling queued TRIM support
[36719.265148] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT5._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36719.265151] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT5._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36719.265200] ata6.00: supports DRM functions and may not be fully accessible
[36719.265674] ata6.00: disabling queued TRIM support
[36719.267533] ata6.00: configured for UDMA/133
[36719.270624] ahci 0000:00:17.0: port does not support device sleep
[36719.277589] ahci 0000:00:17.0: port does not support device sleep
[36720.225873] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[36720.227190] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36720.227215] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36720.229362] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36720.229386] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36720.230121] ata4.00: configured for UDMA/100
[36721.022893] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[36722.089006] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[36722.090726] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT4._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36722.090751] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT4._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36722.150555] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT4._GTF.DSSP], AE_NOT_FOUND (20210930/psargs-330)
[36722.150579] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT4._GTF due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[36722.186245] ata5.00: configured for UDMA/133
[36722.252332] OOM killer enabled.
[36722.252337] Restarting tasks ... done.
[36722.260117] PM: suspend exit
[36722.477257] audit: type=1130 audit(1652117658.369:366): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36722.477262] audit: type=1131 audit(1652117658.369:367): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36722.528412] usb 1-8: Failed to query (GET_DEF) UVC control 2 on unit 1: -32 (exp. 1).
[36722.588740] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
[36722.616751] audit: type=1130 audit(1652117658.509:368): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36724.299275] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[36724.299350] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s31f6: link becomes ready
[36727.141673] audit: type=1100 audit(1652117663.037:369): pid=54010 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="marco" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[36732.624422] audit: type=1131 audit(1652117668.518:370): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36767.577539] audit: type=1100 audit(1652117703.476:371): pid=54024 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marco" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[36767.577634] audit: type=1101 audit(1652117703.476:372): pid=54024 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="marco" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[36767.578162] audit: type=1110 audit(1652117703.476:373): pid=54024 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[36767.582747] audit: type=1105 audit(1652117703.482:374): pid=54024 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
This is all the information I could gather from similar issues on other threads but I havent found a solution yet.
