Computer immediately wakes after suspending, without input
Hi all, recently switched to Manjaro from Win10, really enjoying it - but have one bug I can’t solve:
Whenever I suspend the PC, the screen will shut off, and the power LED on my case will switch off, but it will then immediately awake. Please can you help me troubleshoot this?
I’m hoping it wasn’t the “no swap” option I selected on installation…
Video of issue
https://streamable.com/re1ml8
Output of inxi:
 Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
 root=UUID=df9330ae-ab5d-4066-b394-83026690db0d rw
 cryptdevice=UUID=fe6b44ac-1829-4ab6-8169-049dc8bf77a2:luks-fe6b44ac-1829-4ab6-8169-049dc8bf77a2
 root=/dev/mapper/luks-fe6b44ac-1829-4ab6-8169-049dc8bf77a2 splash apparmor=1
 bootsplash.bootfile=/bootsplash-themes/vendor/bootsplash
 Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
 Type: Desktop System: Gigabyte product: X570 I AORUS PRO WIFI v: -CF
 serial: <filter>
 Mobo: Gigabyte model: X570 I AORUS PRO WIFI v: x.x serial: <filter>
 UEFI: American Megatrends v: F30 date: 09/15/2020
 RAM: total: 15.57 GiB used: 2.81 GiB (18.0%)
 Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
 family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
 L2: 4 MiB bogomips: 115033
 Speed: 3593 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
 1: 3593 2: 2119 3: 2052 4: 2051 5: 2194 6: 2196 7: 2196 8: 2195 9: 2054
 10: 2051 11: 2194 12: 2194 13: 2194 14: 2195 15: 3604 16: 2051
 fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
 mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
 nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
 pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
 pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
 skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
 succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
 v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
 xsavec xsaveerptr xsaveopt xsaves
 conditional, RSB filling
 Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Gigabyte
 driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0
 chip-ID: 10de:21c4 class-ID: 0300
 Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
 loaded: nvidia resolution: <missing: xdpyinfo>
 OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
 Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
 driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 10de:1aeb
 class-ID: 0403
 Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
 driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
 class-ID: 0403
 Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
 Sound Server-4: PipeWire v: 0.3.33 running: no
 Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
 port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
 IF: enp5s0 state: down mac: <filter>
 Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
 IF: wlp6s0 state: up mac: <filter>
 IP v6: <filter> type: noprefixroute scope: global
 Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-2:3
 Device-1: luks-fe6b44ac-1829-4ab6-8169-049dc8bf77a2 maj-min: 254:0
 type: LUKS dm: dm-0 size: 931.21 GiB
 Components:
 p-1: nvme1n1p2 maj-min: 259:7 size: 931.22 GiB
 Local Storage: total: 1.84 TiB used: 191.04 GiB (10.1%)
 ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
 size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
 lanes: 4 type: SSD serial: <filter> rev: 002C temp: 40.9 C scheme: GPT
 ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital model: WDS100T2B0C
 lanes: 4 type: SSD serial: <filter> rev: 211210WD temp: 49.9 C scheme: GPT
 ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
 used: 191.04 GiB (20.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
 mapped: luks-fe6b44ac-1829-4ab6-8169-049dc8bf77a2 label: N/A
 uuid: df9330ae-ab5d-4066-b394-83026690db0d
 used: 444 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
 label: NO_LABEL uuid: 2A89-AB96
 ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
 uuid: 04C4603AC460305A
 ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 99 MiB fs: vfat label: N/A
 uuid: F660-C6C6
 ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
 label: N/A uuid: N/A
 ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 953.24 GiB fs: bitlocker
 Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
 Device-1: 1-1:2 info: Integrated Express IT8297 RGB LED Controller
 type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
 speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
 Device-2: 1-2:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
 class-ID: e001
 Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
 Device-1: 3-3:2 info: Holtek OBINS type: Keyboard,HID
 driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
 power: 400mA chip-ID: 04d9:a293 class-ID: 0300 serial: <filter>
 Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
 Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
 Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
 Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
 Device-1: 7-2:2 info: Logitech USB Receiver type: Mouse,Keyboard,HID
 driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
 chip-ID: 046d:c547 class-ID: 0300
 Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
 System Temperatures: cpu: 48.1 C mobo: 16.8 C gpu: nvidia temp: 49 C
 Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
 Processes: 513 Uptime: 6m wakeups: 2 Init: systemd v: 248 tool: systemctl
 Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: apt: 0 pacman: 1379 lib: 346
 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Output of journalctl:
journalctl --boot 0 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"                   ✔
Aug 28 23:07:16 H1 systemd[1]: Starting System Suspend...
Aug 28 23:07:16 H1 systemd-sleep[5292]: Suspending system...
Aug 28 23:07:16 H1 kernel: PM: suspend entry (deep)
Aug 28 23:07:16 H1 kernel: Filesystems sync: 0.002 seconds
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "34"
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) event1  - Power Button: device removed
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "37"
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) event0  - Power Button: device removed
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "38"
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) event4  - OBINS OBINS
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: AnnePro2: device removed
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "39"
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) event6  - OBINS OBINS
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "40"
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) event2  - Logitech USB Receiver: device removed
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "41"
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) event3  - Logitech USB Receiver Keyboard: device removed
Aug 28 23:07:16 H1 rtkit-daemon[2134]: Supervising 3 threads of 1 processes of 1 users.
Aug 28 23:07:16 H1 rtkit-daemon[2134]: Successfully made thread 5522 of process 2119 owned by '1000' RT at priority 5.
Aug 28 23:07:16 H1 rtkit-daemon[2134]: Supervising 4 threads of 1 processes of 1 users.
Aug 28 23:07:16 H1 kernel: rfkill: input handler enabled
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:65
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:67
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:64
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:68
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:66
Aug 28 23:07:16 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:70
Aug 28 23:07:16 H1 rtkit-daemon[2134]: Successfully made thread 5523 of process 2119 owned by '1000' RT at priority 5.
Aug 28 23:07:21 H1 kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Aug 28 23:07:21 H1 kernel: OOM killer disabled.
Aug 28 23:07:21 H1 kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Aug 28 23:07:21 H1 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Aug 28 23:07:21 H1 kernel: ACPI: Preparing to enter system sleep state S3
Aug 28 23:07:21 H1 kernel: PM: Saving platform NVS memory
Aug 28 23:07:21 H1 kernel: Disabling non-boot CPUs ...
Aug 28 23:07:21 H1 kernel: IRQ 119: no longer affine to CPU1
Aug 28 23:07:21 H1 kernel: smpboot: CPU 1 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 120: no longer affine to CPU2
Aug 28 23:07:21 H1 kernel: smpboot: CPU 2 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 121: no longer affine to CPU3
Aug 28 23:07:21 H1 kernel: smpboot: CPU 3 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 122: no longer affine to CPU4
Aug 28 23:07:21 H1 kernel: smpboot: CPU 4 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 123: no longer affine to CPU5
Aug 28 23:07:21 H1 kernel: smpboot: CPU 5 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 124: no longer affine to CPU6
Aug 28 23:07:21 H1 kernel: smpboot: CPU 6 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 125: no longer affine to CPU7
Aug 28 23:07:21 H1 kernel: smpboot: CPU 7 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 126: no longer affine to CPU8
Aug 28 23:07:21 H1 kernel: smpboot: CPU 8 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 127: no longer affine to CPU9
Aug 28 23:07:21 H1 kernel: smpboot: CPU 9 is now offline
Aug 28 23:07:21 H1 kernel: IRQ 128: no longer affine to CPU10
Aug 28 23:07:21 H1 kernel: smpboot: CPU 10 is now offline
Aug 28 23:07:21 H1 kernel: smpboot: CPU 11 is now offline
Aug 28 23:07:21 H1 kernel: smpboot: CPU 12 is now offline
Aug 28 23:07:21 H1 kernel: smpboot: CPU 13 is now offline
Aug 28 23:07:21 H1 kernel: smpboot: CPU 14 is now offline
Aug 28 23:07:21 H1 kernel: smpboot: CPU 15 is now offline
Aug 28 23:07:21 H1 kernel: ACPI: Low-level resume complete
Aug 28 23:07:21 H1 kernel: PM: Restoring platform NVS memory
Aug 28 23:07:21 H1 kernel: LVT offset 0 assigned for vector 0x400
Aug 28 23:07:21 H1 kernel: Enabling non-boot CPUs ...
Aug 28 23:07:21 H1 kernel: x86: Booting SMP configuration:
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Aug 28 23:07:21 H1 kernel: microcode: CPU1: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C002: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU1 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Aug 28 23:07:21 H1 kernel: microcode: CPU2: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C004: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU2 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Aug 28 23:07:21 H1 kernel: microcode: CPU3: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C006: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU3 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
Aug 28 23:07:21 H1 kernel: microcode: CPU4: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C008: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU4 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
Aug 28 23:07:21 H1 kernel: microcode: CPU5: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C00A: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU5 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 6 APIC 0xc
Aug 28 23:07:21 H1 kernel: microcode: CPU6: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C00C: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU6 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 7 APIC 0xe
Aug 28 23:07:21 H1 kernel: microcode: CPU7: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C00E: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU7 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 8 APIC 0x1
Aug 28 23:07:21 H1 kernel: microcode: CPU8: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C001: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU8 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
Aug 28 23:07:21 H1 kernel: microcode: CPU9: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C003: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU9 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
Aug 28 23:07:21 H1 kernel: microcode: CPU10: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C005: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU10 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
Aug 28 23:07:21 H1 kernel: microcode: CPU11: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C007: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU11 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
Aug 28 23:07:21 H1 kernel: microcode: CPU12: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C009: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU12 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
Aug 28 23:07:21 H1 kernel: microcode: CPU13: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C00B: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU13 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
Aug 28 23:07:21 H1 kernel: microcode: CPU14: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C00D: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU14 is up
Aug 28 23:07:21 H1 kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
Aug 28 23:07:21 H1 kernel: microcode: CPU15: patch_level=0x08701021
Aug 28 23:07:21 H1 kernel: ACPI: \_PR_.C00F: Found 2 idle states
Aug 28 23:07:21 H1 kernel: CPU15 is up
Aug 28 23:07:21 H1 kernel: ACPI: Waking up from system sleep state S3
Aug 28 23:07:21 H1 kernel: nvme nvme1: 16/0/0 default/read/poll queues
Aug 28 23:07:21 H1 kernel: nvme nvme0: 8/0/0 default/read/poll queues
Aug 28 23:07:21 H1 kernel: ata3: SATA link down (SStatus 0 SControl 300)
Aug 28 23:07:21 H1 kernel: ata7: SATA link down (SStatus 0 SControl 300)
Aug 28 23:07:21 H1 kernel: ata2: SATA link down (SStatus 0 SControl 300)
Aug 28 23:07:21 H1 kernel: ata1: SATA link down (SStatus 0 SControl 300)
Aug 28 23:07:21 H1 kernel: ata6: SATA link down (SStatus 0 SControl 300)
Aug 28 23:07:21 H1 kernel: usb usb5: root hub lost power or was reset
Aug 28 23:07:21 H1 kernel: usb usb6: root hub lost power or was reset
Aug 28 23:07:21 H1 kernel: OOM killer enabled.
Aug 28 23:07:21 H1 kernel: Restarting tasks ... done.
Aug 28 23:07:21 H1 kernel: PM: suspend exit
Aug 28 23:07:21 H1 bluetoothd[1012]: Controller resume with wake event 0x0
Aug 28 23:07:21 H1 systemd-sleep[5292]: System resumed.
Aug 28 23:07:21 H1 rtkit-daemon[2134]: Supervising 3 threads of 1 processes of 1 users.
Aug 28 23:07:21 H1 rtkit-daemon[2134]: Successfully made thread 5644 of process 2119 owned by '1000' RT at priority 5.
Aug 28 23:07:21 H1 rtkit-daemon[2134]: Supervising 4 threads of 1 processes of 1 users.
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got resume for 13:65
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-5): connected
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-5): Internal DisplayPort
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-5): 2660.0 MHz maximum pixel clock
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-6: disconnected
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
Aug 28 23:07:21 H1 /usr/lib/gdm-x-session[1025]: (II) NVIDIA(0): Setting mode "DFP-5:nvidia-auto-select"
Aug 28 23:07:21 H1 systemd[1]: systemd-suspend.service: Deactivated successfully.
Aug 28 23:07:21 H1 systemd[1]: Finished System Suspend.
Aug 28 23:08:04 H1 systemd[1]: Starting System Suspend...
Aug 28 23:08:04 H1 systemd-sleep[6907]: Suspending system...
Aug 28 23:08:04 H1 kernel: PM: suspend entry (deep)
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "26"
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) event1  - Power Button: device removed
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "25"
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) event0  - Power Button: device removed
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "38"
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) event4  - OBINS OBINS
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: AnnePro2: device removed
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "64"
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) event6  - OBINS OBINS
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "41"
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) event2  - Logitech USB Receiver: device removed
Aug 28 23:08:04 H1 kernel: Filesystems sync: 0.003 seconds
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (**) Option "fd" "40"
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) event3  - Logitech USB Receiver Keyboard: device removed
Aug 28 23:08:04 H1 kernel: rfkill: input handler enabled
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:65
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:67
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:64
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:68
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:66
Aug 28 23:08:04 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got pause for 13:70
Aug 28 23:08:04 H1 rtkit-daemon[2134]: Supervising 3 threads of 1 processes of 1 users.
Aug 28 23:08:04 H1 rtkit-daemon[2134]: Successfully made thread 7134 of process 2119 owned by '1000' RT at priority 5.
Aug 28 23:08:04 H1 rtkit-daemon[2134]: Supervising 4 threads of 1 processes of 1 users.
Aug 28 23:08:09 H1 kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Aug 28 23:08:09 H1 kernel: OOM killer disabled.
Aug 28 23:08:09 H1 kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Aug 28 23:08:09 H1 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Aug 28 23:08:09 H1 kernel: ACPI: Preparing to enter system sleep state S3
Aug 28 23:08:09 H1 kernel: PM: Saving platform NVS memory
Aug 28 23:08:09 H1 kernel: Disabling non-boot CPUs ...
Aug 28 23:08:09 H1 kernel: smpboot: CPU 1 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 2 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 3 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 4 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 5 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 6 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 7 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 8 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 9 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 10 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 11 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 12 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 13 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 14 is now offline
Aug 28 23:08:09 H1 kernel: smpboot: CPU 15 is now offline
Aug 28 23:08:09 H1 kernel: ACPI: Low-level resume complete
Aug 28 23:08:09 H1 kernel: PM: Restoring platform NVS memory
Aug 28 23:08:09 H1 kernel: LVT offset 0 assigned for vector 0x400
Aug 28 23:08:09 H1 kernel: Enabling non-boot CPUs ...
Aug 28 23:08:09 H1 kernel: x86: Booting SMP configuration:
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Aug 28 23:08:09 H1 kernel: microcode: CPU1: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C002: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU1 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Aug 28 23:08:09 H1 kernel: microcode: CPU2: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C004: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU2 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Aug 28 23:08:09 H1 kernel: microcode: CPU3: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C006: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU3 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
Aug 28 23:08:09 H1 kernel: microcode: CPU4: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C008: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU4 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
Aug 28 23:08:09 H1 kernel: microcode: CPU5: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C00A: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU5 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 6 APIC 0xc
Aug 28 23:08:09 H1 kernel: microcode: CPU6: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C00C: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU6 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 7 APIC 0xe
Aug 28 23:08:09 H1 kernel: microcode: CPU7: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C00E: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU7 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 8 APIC 0x1
Aug 28 23:08:09 H1 kernel: microcode: CPU8: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C001: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU8 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
Aug 28 23:08:09 H1 kernel: microcode: CPU9: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C003: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU9 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
Aug 28 23:08:09 H1 kernel: microcode: CPU10: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C005: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU10 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
Aug 28 23:08:09 H1 kernel: microcode: CPU11: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C007: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU11 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
Aug 28 23:08:09 H1 kernel: microcode: CPU12: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C009: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU12 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
Aug 28 23:08:09 H1 kernel: microcode: CPU13: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C00B: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU13 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
Aug 28 23:08:09 H1 kernel: microcode: CPU14: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C00D: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU14 is up
Aug 28 23:08:09 H1 kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
Aug 28 23:08:09 H1 kernel: microcode: CPU15: patch_level=0x08701021
Aug 28 23:08:09 H1 kernel: ACPI: \_PR_.C00F: Found 2 idle states
Aug 28 23:08:09 H1 kernel: CPU15 is up
Aug 28 23:08:09 H1 kernel: ACPI: Waking up from system sleep state S3
Aug 28 23:08:09 H1 kernel: nvme nvme1: 16/0/0 default/read/poll queues
Aug 28 23:08:09 H1 kernel: nvme nvme0: 8/0/0 default/read/poll queues
Aug 28 23:08:09 H1 kernel: ata7: SATA link down (SStatus 0 SControl 300)
Aug 28 23:08:09 H1 kernel: ata1: SATA link down (SStatus 0 SControl 300)
Aug 28 23:08:09 H1 kernel: ata2: SATA link down (SStatus 0 SControl 300)
Aug 28 23:08:09 H1 kernel: ata3: SATA link down (SStatus 0 SControl 300)
Aug 28 23:08:09 H1 kernel: ata6: SATA link down (SStatus 0 SControl 300)
Aug 28 23:08:09 H1 kernel: usb usb5: root hub lost power or was reset
Aug 28 23:08:09 H1 kernel: usb usb6: root hub lost power or was reset
Aug 28 23:08:09 H1 kernel: OOM killer enabled.
Aug 28 23:08:09 H1 kernel: Restarting tasks ... done.
Aug 28 23:08:09 H1 kernel: PM: suspend exit
Aug 28 23:08:09 H1 bluetoothd[1012]: Controller resume with wake event 0x0
Aug 28 23:08:09 H1 systemd-sleep[6907]: System resumed.
Aug 28 23:08:09 H1 gdm[952]: GLib: Source ID 49 was not found when attempting to remove it
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (II) systemd-logind: got resume for 13:65
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-5): connected
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-5): Internal DisplayPort
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-5): 2660.0 MHz maximum pixel clock
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-6: disconnected
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
Aug 28 23:08:09 H1 /usr/lib/gdm-x-session[1025]: (II) NVIDIA(0): Setting mode "DFP-5:nvidia-auto-select"
Aug 28 23:08:09 H1 systemd[1]: systemd-suspend.service: Deactivated successfully.
Aug 28 23:08:09 H1 systemd[1]: Finished System Suspend.
with an ssd and enough RAM you go fine without swap, I would change power management settings in the bios probably ( ACPI, APM …)
Thanks for your input @ycom1 - I appreciate if this is a BIOS issue, it’s slightly outside the realm of this forum’s support. However, the same error doesn’t happen with Windows sleep mode, using the same BIOS settings.
I have upgraded my BIOS to the latest available (F34 - for some reason F35 fails with a “BIOS ID Check Error”).
No settings I found referenced “APM” - All settings referencing ACPI are set to “Auto”:
  • ACPI_CST C1 Declaration: Auto (can set to Enabled/Disabled?)
  • ACPI SRAT L3 Cache As NUMA Domain: Auto
  • ACPI SLIT Distance Control: Auto
  • ACPI SLIP remote relative distance: Auto
Are there any settings in particular that you would recommend experimenting with?
If anyone has any further thoughts on how to diagnose/troubleshoot I’m all ears - thanks in advance.
also a further suggestion could be,
Manjaro also has a very handy Kernel switch
control center. You can try to upgrade or even
downgrade.
Hello @hecter :wink:
So it is not clear by which event the awake process has been triggered.
  1. Input Devices?
  2. Wake on LAN?
Linux just do what ACPI says, it should do. So the problem is really the UEFI.
Please read this:
Then try with 2 LTS kernels.
Please read this
Do both of the above and see if the problem goes away automagically. :grin:
:crossed_fingers:
P.S. Some applications can inhibit sleep state. Spotify is the most notorious one as you cannot turn it off, but VLC, qBittorrent, … can be set to inhibit sleep too.
