Computer hanging indefinitely on shutdown through start menu
Updated yesterday via pacman and I have not been able to shutdown my computer from the start menu. Updated from Linux 6.1.111-1 to Linux 6.6.52-1 to see if that would fix the issue but it’s still a problem.
I can shutdown perfectly fine if I do shutdown now from console, so it seems like there’s an issue with the DE? I’ve also used fsck to see if it’s a filesystem issue, but it came back okay.
inxi -Fazy:
  Kernel: 6.6.52-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=8e309058-b31e-408b-908b-91b04d512b51 rw quiet apparmor=1
    security=apparmor resume=UUID=a9e1c46e-191e-4909-8e3e-6ad45447f8d9
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-I GAMING v: Rev X.0x
    UEFI: American Megatrends v: 4021 date: 08/09/2021
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3598 min/max: 2200/4950 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3598 2: 3598 3: 3598
    4: 3598 5: 3598 6: 3598 7: 3598 8: 3598 9: 3598 10: 3598 11: 3598 12: 3598
    13: 3598 14: 3598 15: 3598 16: 3598 17: 3598 18: 3598 19: 3598 20: 3598
    21: 3598 22: 3598 23: 3598 24: 3598 bogomips: 177664
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT /
    6900 XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2
    bus-ID: 0b:00.0 chip-ID: 1002:73bf class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4:2
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,right
    model: Samsung C49HG9x serial: <filter> built: 2017 res: 1920x1080 hz: 144
    dpi: 41 gamma: 1.2 size: 1200x340mm (47.24x13.39") diag: 1242mm (48.9")
    modes: max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Samsung C49HG9x
    serial: <filter> built: 2017 res: 1920x1080 hz: 144 dpi: 41 gamma: 1.2
    size: 1200x340mm (47.24x13.39") diag: 1242mm (48.9") modes: max: 1920x1080
    min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
    navi21 LLVM 18.1.8 DRM 3.54 6.6.52-1-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.3.295 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 24.2.2-arch1.1
    device-ID: 1002:73bf surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Razer USA Kraken V3 X driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
    chip-ID: 1532:0537 class-ID: 0300 serial: <filter>
  Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.6.52-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.3 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:4 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 931.51 GiB used: 830.19 GiB (89.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.3 temp: 43.9 C
    scheme: GPT
  ID-1: / raw-size: 55.88 GiB size: 54.7 GiB (97.89%) used: 48.54 GiB (88.7%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-3: /home raw-size: 843.47 GiB size: 829.15 GiB (98.30%)
    used: 781.65 GiB (94.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 31.66 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 38.5 C mobo: 38.0 C gpu: amdgpu temp: 49.0 C
    mem: 48.0 C
  Fan Speeds (rpm): fan-1: 875 fan-2: 4368 fan-5: 0 fan-7: 0 gpu: amdgpu
    fan: 0
  Memory: total: 32 GiB available: 31.25 GiB used: 4.09 GiB (13.1%)
  Processes: 444 Power: uptime: 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1659 libs: 446 tools: pamac,paru pm: flatpak
    pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: yakuake inxi: 3.3.36
journalctl -b0 -p4 --no-pager:
Oct 02 21:14:17 michael-abaoaqu kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Oct 02 21:14:17 michael-abaoaqu kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
Oct 02 21:14:17 michael-abaoaqu kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Oct 02 21:14:17 michael-abaoaqu kernel: vboxdrv: loading out-of-tree module taints kernel.
Oct 02 21:14:17 michael-abaoaqu kernel: VBoxNetAdp: Successfully started.
Oct 02 21:14:17 michael-abaoaqu kernel: VBoxNetFlt: Successfully started.
Oct 02 21:14:17 michael-abaoaqu kernel: iwlwifi 0000:04:00.0: api flags index 2 larger than supported by driver
Oct 02 21:14:17 michael-abaoaqu kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Oct 02 21:14:18 michael-abaoaqu kernel: ------------[ cut here ]------------
Oct 02 21:14:18 michael-abaoaqu kernel: WARNING: CPU: 10 PID: 826 at drivers/net/wireless/intel/iwlwifi/iwl-nvm-parse.c:853 iwl_init_he_hw_capab+0x4c6/0x4e0 [iwlwifi]
Oct 02 21:14:18 michael-abaoaqu kernel: Modules linked in: intel_rapl_msr vfat intel_rapl_common fat edac_mce_amd kvm_amd iwlmvm(+) snd_hda_codec_realtek eeepc_wmi snd_hda_codec_generic asus_wmi kvm sparse_keymap ledtrig_audio platform_profile irqbypass mac80211 snd_hda_codec_hdmi crct10dif_pclmul crc32_pclmul polyval_clmulni snd_hda_intel polyval_generic libarc4 gf128mul snd_intel_dspcfg snd_intel_sdw_acpi ghash_clmulni_intel sha512_ssse3 snd_hda_codec sha256_ssse3 sha1_ssse3 iwlwifi aesni_intel snd_hda_core snd_hwdep crypto_simd asus_ec_sensors snd_pcm cryptd i8042 snd_timer serio rapl cfg80211 sp5100_tco wmi_bmof snd igb ccp acpi_cpufreq soundcore pcspkr k10temp i2c_piix4 rfkill dca mac_hid uinput vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) i2c_dev sg crypto_user fuse dm_mod loop nfnetlink bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid amdgpu i2c_algo_bit drm_ttm_helper ttm video drm_exec drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme drm_display_helper crc32c_intel cec nvme_core xhci_pci xhci_pci_renesas
Oct 02 21:14:18 michael-abaoaqu kernel:  nvme_common wmi
Oct 02 21:14:18 michael-abaoaqu kernel: CPU: 10 PID: 826 Comm: modprobe Tainted: G           OE      6.6.52-1-MANJARO #1 7fd24cb19f2dc7edce5825af0acb3586c0f026f9
Oct 02 21:14:18 michael-abaoaqu kernel: Hardware name: System manufacturer System Product Name/ROG STRIX X570-I GAMING, BIOS 4021 08/09/2021
Oct 02 21:14:18 michael-abaoaqu kernel: RIP: 0010:iwl_init_he_hw_capab+0x4c6/0x4e0 [iwlwifi]
Oct 02 21:14:18 michael-abaoaqu kernel: Code: 1f 44 00 00 66 44 89 20 0f b7 4d 5c 83 c2 01 48 83 e8 80 39 ca 7c ed e9 c2 fd ff ff 0f 0b e9 bb fd ff ff 0f 0b e9 54 ff ff ff <0f> 0b e9 2f ff ff ff e8 6e f9 45 dc 66 66 2e 0f 1f 84 00 00 00 00
Oct 02 21:14:18 michael-abaoaqu kernel: RSP: 0018:ffffc11384def7f8 EFLAGS: 00010246
Oct 02 21:14:18 michael-abaoaqu kernel: RAX: 0000000000000002 RBX: ffff9baa4868c028 RCX: ffffffffc19e8420
Oct 02 21:14:18 michael-abaoaqu kernel: RDX: ffffc11384def80a RSI: ffff9baa6f350000 RDI: 0000000000000003
Oct 02 21:14:18 michael-abaoaqu kernel: RBP: ffff9baa6f350170 R08: 0000000000000002 R09: 0000000000000003
Oct 02 21:14:18 michael-abaoaqu kernel: R10: ffff9baa4868c028 R11: 0000000000000001 R12: ffff9baa6f350000
Oct 02 21:14:18 michael-abaoaqu kernel: R13: 0000000000000003 R14: 0000000000000003 R15: ffff9baa4868c028
Oct 02 21:14:18 michael-abaoaqu kernel: FS:  00007f712c83c740(0000) GS:ffff9bb14ec80000(0000) knlGS:0000000000000000
Oct 02 21:14:18 michael-abaoaqu kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Oct 02 21:14:18 michael-abaoaqu kernel: CR2: 00007f9b7874bfe0 CR3: 0000000108446000 CR4: 0000000000f50ee0
Oct 02 21:14:18 michael-abaoaqu kernel: PKRU: 55555554
Oct 02 21:14:18 michael-abaoaqu kernel: Call Trace:
Oct 02 21:14:18 michael-abaoaqu kernel:  <TASK>
Oct 02 21:14:18 michael-abaoaqu kernel:  ? iwl_init_he_hw_capab+0x4c6/0x4e0 [iwlwifi 4c56fc882a9fa2232ae91fd6cdaa6082c470cc42]
Oct 02 21:14:18 michael-abaoaqu kernel:  ? __warn+0x81/0x130
Oct 02 21:14:18 michael-abaoaqu kernel:  ? report_bug+0x16f/0x1a0
Oct 02 21:14:18 michael-abaoaqu kernel:  ? handle_bug+0x3c/0x80
Oct 02 21:14:18 michael-abaoaqu kernel:  ? exc_invalid_op+0x17/0x70
Oct 02 21:14:18 michael-abaoaqu kernel:  ? asm_exc_invalid_op+0x1a/0x20
Oct 02 21:14:18 michael-abaoaqu kernel:  ? iwl_init_he_hw_capab+0x3f1/0x4e0 [iwlwifi 4c56fc882a9fa2232ae91fd6cdaa6082c470cc42]
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_init_sbands+0x68b/0x690 [iwlwifi 4c56fc882a9fa2232ae91fd6cdaa6082c470cc42]
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_get_nvm+0x24d/0x2e0 [iwlwifi 4c56fc882a9fa2232ae91fd6cdaa6082c470cc42]
Oct 02 21:14:18 michael-abaoaqu kernel:  ? iwl_run_unified_mvm_ucode+0x235/0x280 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_run_unified_mvm_ucode+0x235/0x280 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  ? asm_sysvec_call_function+0x1a/0x20
Oct 02 21:14:18 michael-abaoaqu kernel:  ? __pfx_iwl_wait_init_complete+0x10/0x10 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_run_init_mvm_ucode+0x1e9/0x390 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_mvm_start_get_nvm+0x88/0x1f0 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_op_mode_mvm_start+0x814/0xa30 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  _iwl_op_mode_start+0x63/0xc0 [iwlwifi 4c56fc882a9fa2232ae91fd6cdaa6082c470cc42]
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_opmode_register+0x6c/0xe0 [iwlwifi 4c56fc882a9fa2232ae91fd6cdaa6082c470cc42]
Oct 02 21:14:18 michael-abaoaqu kernel:  ? __pfx_iwl_mvm_init+0x10/0x10 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  iwl_mvm_init+0x26/0xff0 [iwlmvm 0200f632acf9e55f1158a354d44274509ab246fa]
Oct 02 21:14:18 michael-abaoaqu kernel:  do_one_initcall+0x5d/0x320
Oct 02 21:14:18 michael-abaoaqu kernel:  do_init_module+0x60/0x240
Oct 02 21:14:18 michael-abaoaqu kernel:  init_module_from_file+0x89/0xe0
Oct 02 21:14:18 michael-abaoaqu kernel:  idempotent_init_module+0x121/0x320
Oct 02 21:14:18 michael-abaoaqu kernel:  __x64_sys_finit_module+0x5e/0xb0
Oct 02 21:14:18 michael-abaoaqu kernel:  do_syscall_64+0x5a/0x80
Oct 02 21:14:18 michael-abaoaqu kernel:  ? syscall_exit_to_user_mode+0x22/0x40
Oct 02 21:14:18 michael-abaoaqu kernel:  ? do_syscall_64+0x66/0x80
Oct 02 21:14:18 michael-abaoaqu kernel:  ? exit_to_user_mode_prepare+0x132/0x1f0
Oct 02 21:14:18 michael-abaoaqu kernel:  ? do_user_addr_fault+0x30f/0x620
Oct 02 21:14:18 michael-abaoaqu kernel:  ? exc_page_fault+0x7f/0x180
Oct 02 21:14:18 michael-abaoaqu kernel:  entry_SYSCALL_64_after_hwframe+0x78/0xe2
Oct 02 21:14:18 michael-abaoaqu kernel: RIP: 0033:0x7f712c1261fd
Oct 02 21:14:18 michael-abaoaqu kernel: Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d e3 fa 0c 00 f7 d8 64 89 01 48
Oct 02 21:14:18 michael-abaoaqu kernel: RSP: 002b:00007ffd6ad6f4c8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
Oct 02 21:14:18 michael-abaoaqu kernel: RAX: ffffffffffffffda RBX: 000055fa53c1ed90 RCX: 00007f712c1261fd
Oct 02 21:14:18 michael-abaoaqu kernel: RDX: 0000000000000004 RSI: 000055fa388b0c03 RDI: 0000000000000002
Oct 02 21:14:18 michael-abaoaqu kernel: RBP: 00007ffd6ad6f580 R08: 00007f712c1f6b20 R09: 00007ffd6ad6f510
Oct 02 21:14:18 michael-abaoaqu kernel: R10: 000055fa53c22830 R11: 0000000000000246 R12: 000055fa388b0c03
Oct 02 21:14:18 michael-abaoaqu kernel: R13: 0000000000040000 R14: 000055fa53c1ece0 R15: 000055fa53c1f9b0
Oct 02 21:14:18 michael-abaoaqu kernel:  </TASK>
Oct 02 21:14:18 michael-abaoaqu kernel: ---[ end trace 0000000000000000 ]---
Oct 02 21:14:18 michael-abaoaqu kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Oct 02 21:14:19 michael-abaoaqu (uetoothd)[1316]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 02 21:14:19 michael-abaoaqu (modprobe)[1318]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support bap plugin
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support bass plugin
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support mcp plugin
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support vcp plugin
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support micp plugin
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support ccp plugin
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support csip plugin
Oct 02 21:14:19 michael-abaoaqu bluetoothd[1316]: src/plugin.c:init_plugin() System does not support asha plugin
Oct 02 21:14:20 michael-abaoaqu dbus-broker-launch[1311]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Oct 02 21:14:21 michael-abaoaqu systemd-xdg-autostart-generator[1692]: Configuration file /home/michael/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 02 21:14:21 michael-abaoaqu dbus-broker-launch[1713]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Oct 02 21:14:21 michael-abaoaqu dbus-broker-launch[1713]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Oct 02 21:14:21 michael-abaoaqu dbus-broker-launch[1713]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Oct 02 21:14:21 michael-abaoaqu systemd-xdg-autostart-generator[1723]: Configuration file /home/michael/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 02 21:14:22 michael-abaoaqu ksplashqml[1717]: Texture 0x7f7c78743d60 () used with different accesses within the same pass, this is not allowed.
Oct 02 21:14:22 michael-abaoaqu ksplashqml[1717]: Texture 0x561790ac74b0 () used with different accesses within the same pass, this is not allowed.
Oct 02 21:14:22 michael-abaoaqu baloo_file[1745]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
Oct 02 21:14:22 michael-abaoaqu baloo_file[1745]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.27'
Oct 02 21:14:22 michael-abaoaqu kded6[1801]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Oct 02 21:14:22 michael-abaoaqu kded6[1801]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Oct 02 21:14:22 michael-abaoaqu plasmashell[1891]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 02 21:14:22 michael-abaoaqu plasmashell[1891]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 02 21:14:22 michael-abaoaqu xdg-desktop-por[1750]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Oct 02 21:14:22 michael-abaoaqu xdg-desktop-por[1750]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Oct 02 21:14:22 michael-abaoaqu plasmashell[1891]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:195:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Oct 02 21:14:22 michael-abaoaqu org_kde_powerdevil[1938]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 02 21:14:22 michael-abaoaqu plasmashell[1891]: Toolbox not loading, toolbox package is either invalid or disabled.
Oct 02 21:14:23 michael-abaoaqu plasmashell[1891]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Oct 02 21:14:23 michael-abaoaqu kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Oct 02 21:14:23 michael-abaoaqu plasmashell[1891]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Oct 02 21:14:23 michael-abaoaqu kdeconnectd[2084]: 2024-10-02T21:14:23 default: Error sending UDP packet: QAbstractSocket::NetworkError
Oct 02 21:14:23 michael-abaoaqu kconf_update[2113]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Oct 02 21:14:23 michael-abaoaqu kconf_update[2113]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Oct 02 21:14:23 michael-abaoaqu kconf_update[2113]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Oct 02 21:14:23 michael-abaoaqu kconf_update[2113]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Oct 02 21:14:23 michael-abaoaqu kconf_update[2113]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Oct 02 21:14:23 michael-abaoaqu kconf_update[2113]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Oct 02 21:14:23 michael-abaoaqu kded6[1801]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Oct 02 21:14:23 michael-abaoaqu kded6[1801]: kscreen.kded: PowerDevil SuspendSession action not available!
Oct 02 21:14:23 michael-abaoaqu plasmashell[1891]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Oct 02 21:14:23 michael-abaoaqu plasmashell[1891]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Oct 02 21:14:23 michael-abaoaqu backlighthelper[2162]: org.kde.powerdevil: no kernel backlight interface found
Oct 02 21:14:24 michael-abaoaqu org_kde_powerdevil[1938]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 02 21:14:24 michael-abaoaqu org_kde_powerdevil[1938]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Oct 02 21:14:24 michael-abaoaqu plasmashell[1891]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 02 21:14:24 michael-abaoaqu org_kde_powerdevil[1938]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 02 21:14:24 michael-abaoaqu plasma-fallback-session-restore[2215]: QFile::rename: Empty or null file name
Oct 02 21:14:24 michael-abaoaqu plasma-fallback-session-restore[2215]: kf.config.core: Failed to migrate "" -> "/home/michael/.local/state/plasmasessionrestorestaterc"
Oct 02 21:14:24 michael-abaoaqu kwin_x11[1802]: kwin_core: XCB error: 3 (BadWindow), sequence: 7130, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Oct 02 21:14:25 michael-abaoaqu dbus-broker-launch[1311]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Oct 02 21:15:57 michael-abaoaqu plasmashell[1891]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1460 which doesn't exist, creating a new one. This is an application bug!
Oct 02 21:16:22 michael-abaoaqu kioworker[4960]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:22 michael-abaoaqu kioworker[4960]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:24 michael-abaoaqu kioworker[4990]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:24 michael-abaoaqu kioworker[4990]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:24 michael-abaoaqu kioworker[5018]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:24 michael-abaoaqu kioworker[5018]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:26 michael-abaoaqu kioworker[5047]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:26 michael-abaoaqu kioworker[5047]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:37 michael-abaoaqu kioworker[5084]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:37 michael-abaoaqu kioworker[5084]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:38 michael-abaoaqu kioworker[5146]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:38 michael-abaoaqu kioworker[5146]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:39 michael-abaoaqu kioworker[5171]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:39 michael-abaoaqu kioworker[5171]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:43 michael-abaoaqu plasmashell[1891]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1461 which doesn't exist, creating a new one. This is an application bug!
Oct 02 21:16:49 michael-abaoaqu kioworker[5195]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Oct 02 21:16:49 michael-abaoaqu kioworker[5195]: kf.kio.core: An error occurred during write. The worker terminates now.
Oct 02 21:16:52 michael-abaoaqu dolphin[4447]: kf.purpose.externalprocess: Cannot initialize model for plugin type "Export" with data QJsonObject(): missing key "urls"
Oct 02 21:17:01 michael-abaoaqu plasmashell[1891]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Same thing?
This is it, thank you! Don’t know why I didn’t see this when I was searching.
After update yesterday (some 400 packages) I have two PC’s that won’t shutdown.
The symptom is black screen with cursor.
One PC:
KDE Plasma Version: 6.1.5
KDE Frameworks Version: 6.5.0
Qt Version: 6.7.2
Kernel Version: 6.11.0-6-MANJARO (64-bit)
Graphics Platform: X11
Processors: 6 × AMD FX™-6350 Six-Core Processor
Memory: 15.5 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3060/PCIe/SSE2
The other is the same Manjaro details but different hardware, Intel cpu (both NVIDIA, but different versions.
There was some NVIDIA update in the 400.
I’ve tried several of the things mentioned in threads from 2020, they still don’t shutdown.
inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.11.0-6-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=b1e5a73f-8c3a-41ba-b650-e410abdf8f42 rw plymouth.enable=0
disablehooks=plymouth resume=UUID=6091dcd2-1fa9-4c25-9ce6-ae3c1846a2fc
udev.log_priority=3
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx
serial: part-nu: SKU uuid:
BIOS: American Megatrends v: 2603 date: 06/26/2015
Device-1: hidpp_battery_0 model: Logitech K520 serial:
charge: 70% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial:
charge: 55% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.52 GiB used: 2.52 GiB (16.3%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: spec: 1600 MT/s actual: 800 MT/s volts: N/A width (bits):
data: 64 total: 64 manufacturer: Crucial part-no: BLS4G3D1609DS1S00.
serial:
Device-2: DIMM1 type: DDR3 detail: synchronous unbuffered (unregistered)
serial:
Device-3: DIMM2 type: DDR3 detail: synchronous unbuffered (unregistered)
serial:
Device-4: DIMM3 type: DDR3 detail: synchronous unbuffered (unregistered)
serial:
Info: model: AMD FX-6350 bits: 64 type: MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: cache:
L1: 288 KiB desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1501 min/max: 1400/3900 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1501 2: 1501 3: 1501
4: 1501 5: 1501 6: 1501 bogomips: 46977
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2504 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DP-3 pos: right res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: DP-5 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.120 device-ID: 10de:2504
surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
class-ID: 0403
API: ALSA v: k6.11.0-6-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Local Storage: total: 1.35 TiB used: 66.15 GiB (4.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 0102 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
tech: SSD serial: fw-rev: 0100 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial:
fw-rev: 1A02 scheme: MBR
ID-1: / raw-size: 214.77 GiB size: 210.34 GiB (97.94%)
used: 66.15 GiB (31.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: b1e5a73f-8c3a-41ba-b650-e410abdf8f42
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 6091dcd2-1fa9-4c25-9ce6-ae3c1846a2fc
ID-1: /dev/sdb1 maj-min: 8:17 size: 222.62 GiB fs: ext4 label: N/A
uuid: 17bddbbc-f6c9-4ca1-88a4-93904b18af03
ID-2: /dev/sdb2 maj-min: 8:18 size: 1 KiB fs:
label: N/A uuid: N/A
ID-3: /dev/sdb5 maj-min: 8:21 size: 975 MiB fs: swap label: N/A
uuid: fcd7cda8-a30c-49b6-845e-b15de688b122
ID-4: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ext4 label: N/A
uuid: 8d462e2d-f3bf-41ec-80e2-f18ac6fffd94
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-3: 2-4:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
chip-ID: 1a40:0801 class-ID: 0900
Hub-4: 2-4.2:3 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
Hub-5: 2-4.2.1:4 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 2-4.2.3:5 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Hub-6: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-7: 4-0:1 info: full speed or root hub ports: 4 rev: 2.0
Hub-8: 5-0:1 info: full speed or root hub ports: 5 rev: 1.1
Device-1: 5-1:2 info: Sunplus Innovation Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
Hub-9: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-10: 7-0:1 info: full speed or root hub ports: 4 rev: 1.1
Device-1: 7-4:2 info: STMicro duckyPad(2020) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0483:d11c class-ID: 0301
serial:
Hub-11: 8-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-12: 9-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-13: 10-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-14: 10-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Hub-15: 11-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-16: 11-2:2 info: Realtek Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
System Temperatures: cpu: 16.1 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: pm: pacman pkgs: 1752 libs: 453 tools: octopi,pamac,yay pm: flatpak
pkgs: 0
1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
2: http://mirror.fcix.net/manjaro/stable/$repo/$arch
3: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
4: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
5: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
6: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
7: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
8: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 197
1: cpu: 100% command: ps pid: 1970 mem: 3.53 MiB (0.0%)
2: cpu: 11.8% command: firefox pid: 1065 mem: 727.5 MiB (4.5%)
3: cpu: 9.6% command: firefox pid: 1170 mem: 267.7 MiB (1.6%)
4: cpu: 8.6% command: firefox pid: 1331 mem: 278.1 MiB (1.7%)
5: cpu: 5.3% command: konsole pid: 1904 mem: 167.6 MiB (1.0%)
Memory top: 5 of 197
1: mem: 727.5 MiB (4.5%) command: firefox pid: 1065 cpu: 11.8%
2: mem: 487.0 MiB (3.0%) command: plasmashell pid: 738 cpu: 1.8%
3: mem: 286.0 MiB (1.7%) command: systemsettings pid: 1763 cpu: 0.5%
4: mem: 278.1 MiB (1.7%) command: firefox pid: 1331 cpu: 8.6%
5: mem: 267.7 MiB (1.6%) command: firefox pid: 1170 cpu: 9.6%
Processes: 197 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 12 Shell: Zsh v: 5.9
default: Bash v: 5.2.32 running-in: konsole inxi: 3.3.36
journalctl --boot=-1 --priority=3 --catalog --no-pager
Oct 02 08:26:51 ubstwo kernel:
Oct 02 08:26:56 ubstwo dbus-broker-launch[627]: Ignoring duplicate name ‘org.freedesktop.FileManager1’ in service file ‘/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service’
░░ Subject: Invalid service file
░░ Defined-By: dbus-broker
░░ Support: Redirecting to Google Groups
░░ A service file is a ini-type configuration file.
░░ It has one required section
░░ named [D-BUS Service]. The section contains the required key ‘Name’, which
░░ must be a valid D-Bus name that is unique across all service files. It also
░░ contains at least one of the two optional keys ‘SystemdService’ and ‘Exec’,
░░ as well as optionally the key ‘User’. Exec must be a valid shell command and
░░ User must be a valid user on the system.
░░ A service file should be named after the D-Bus name it configures. That is
░░ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.
░░ For backwards compatibility, we only warn when files do not follow this
░░ convention when run as a user bus. The system bus considers this an error
░░ and ignores the service file.
Oct 02 08:27:38 ubstwo dbus-broker-launch[692]: Ignoring duplicate name ‘org.freedesktop.FileManager1’ in service file ‘/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service’
Oct 02 08:27:41 ubstwo pulseaudio[814]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer ‘org.bluez’: unit failed
Oct 02 08:27:41 ubstwo org_kde_powerdevil[820]: busno=9, sleep-multiplier = 1.30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
Oct 02 08:27:41 ubstwo org_kde_powerdevil[820]: busno=10, sleep-multiplier = 1.30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
Oct 02 08:27:44 ubstwo kernel: usb 2-4.2: clear tt 1 (0050) error -71
Oct 02 08:27:44 ubstwo kernel: usb 2-4.2-port3: cannot reset (err = -71)
Oct 02 08:27:44 ubstwo kernel: usb 2-4.2-port3: Cannot enable. Maybe the USB cable is bad?
Oct 02 08:27:44 ubstwo kernel: usb 2-4.2-port3: cannot disable (err = -71)
@drmacro do you also have saved session enabled?
What do you mean “saved session”?
Once I figured out you were talking about the session settings in system settings application, I set as you specify.
It appears to have corrected it on both PC’s.
Thanks you very much!
