The system powers on, but I get a black screen and the system is completely unresponsive to any keyboard shortcuts and I’m forced to power off.
I dual boot and have no such problems under Windows. This is the Nth time I tried to fix this, so once again I went through a lot of posts to see if there was any new solution that might work for me, but so far nada, so I’d really appreciate if anyone has any idea that could help…
Here’s the output of inxi -Fza
Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fea61d67-76f5-4841-9e07-740ab0dd5966 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x
serial: <filter> UEFI: American Megatrends LLC. v: F62 date: 07/13/2021
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB
bogomips: 86279
Speed: 2378 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2378 2: 2051 3: 2195 4: 2193 5: 2049 6: 2192 7: 2194 8: 2193 9: 3201
10: 2050 11: 2052 12: 2196
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASRock driver: amdgpu v: kernel bus-ID: 09:00.0 chip-ID: 1002:731f
class-ID: 0300
Device-2: Microdia Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-3:2 chip-ID: 0c45:6340 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 90
size: 544x303mm (21.4x11.9") diag: 623mm (24.5")
OpenGL: renderer: AMD Radeon RX 5700 (NAVI10 DRM 3.41.0 5.13.8-1-MANJARO
LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 09:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Microdia Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:3 chip-ID: 0cf3:3005 class-ID: e001
Local Storage: total: 2.32 TiB used: 1.16 TiB (50.0%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
rev: 111110WD temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk
model: Ultra USB 3.0 size: 28.65 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
model: DataTraveler G2 size: 14.9 GiB block-size: physical: 512 B
ID-1: / raw-size: 139.84 GiB size: 136.64 GiB (97.72%)
used: 45.35 GiB (33.2%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 25.6 MiB (26.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 704
Processes: 323 Uptime: 5m wakeups: 0 Memory: 15.57 GiB
used: 2.65 GiB (17.0%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1319 lib: 426 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
Here is the output of journalctl --system --boot=-1
, after I suspended and tried to wake up the system again: -- Journal begins at Mon 2020-11-09 22:51:29 WET, ends at Mon 2021-08-16 19:57:5 - Pastebin.com
What I’ve tried:
- Updating to the latest version of the bios.
- All available kernels since 5.4
- Changing ‘Power Idle Control’ from ‘Auto’ to ‘Typical Current Idle’, according to recommendations in the ArchWiki for Ryzen CPUs.. I also tried disabling ‘Global C-State Control’ in the bios, which I assume is the option for disabling C-States mentioned in the wiki.
- Installing and enabling the service from AUR (en) - disable-c6-systemd
