Hi all
First my ask is both graphism & display and software & applications, i let the moderators change my post if i’m wrong in the section choice
=> In IceWm and Lxde i have to launch compton to make conky transparency (not displayd in a black background)
But all the windows and menus are transparent and with some effects i don’t want
compton -help returns that
[bozzoh@bozzoh ~]$ compton -help | grep opacity
-o opacity
-m opacity
The opacity for menus. (default 1.0)
Fade windows in/out when opening/closing and when opacity
-i opacity
-e opacity
--inactive-opacity-override
Inactive opacity set by -i overrides value of _NET_WM_OPACITY.
--active-opacity opacity
Default opacity for active windows. (0.0 - 1.0)
--detect-client-opacity
opacity.
1.0 or changing based on opacity, depending on whether you have
--opacity-rule opacity:condition
Specify a list of opacity rules, in the format "PERCENT:PATTERN",
I tried all those options but nothing change so here’s my ask what’s wrong with those options or how apply them correctly?
How to make my windows and menus 100% opacity i don’t want ANY transparency ? (except the conky display)
